Question about Lowrance LMS-480MDF GPS Receiver
Keeps blowing fuses
I have a LMS-480 M that powers up fine. That is until I try to hook up the GPS module (LGC2000). Every time I try to connect the power wires to the source, it blows the fuse. The unit itself works fine as long as I hook it up alone. The problem is trying to get the GPS module hooked up. It is a brand new module that I just got directly from Lowrance. I have tried to hook it up directly to the battery, to the fuse panel, connected to the unit power wires, and completely separate. It still blows fuses. Any ideas? Thanks!!
  • dustlane Aug 21, 2007
    That is funny. I just finished taking it apart and finding some melted wires, etc. It is not under warranty so I will fix it myself with my soldering iron. Provided, of course, that I can get the parts. The guy that had this boat before me had wired the unit directly into the fuse panel using a larger fuse than recommended and he also cut the bare wire off of the power wire rather than connecting with the black ground. I hope I can get it fixed as I sure can't afford a new one. Thanks for the help!!
    Sergeant:
  • 274 Answers
It has a short in the wiring which is "not user fixable". I think the wires are crossed. Take it back, they need to repair or replace it. I suggest you replace it. Take the GPS with you show you can show them the problem. If you bought this on line call Lowrance and find the nearest repair center. Repair it yourself and you loose the warentee.
Posted on Aug 21, 2007
SOURCE:
GPS NOT RESPONDING
My GPS module on the Lowrance 480M does not work, any ideas? Thanks
Aug 06, 2011 | Lowrance LMS-480 GPS Receiver
Lowrance LMS 337
I wonder if the module has failed again, have you tried reseting the device?
I'm looking into this but I suspect that repairs are required again.
Jul 09, 2008 | Lowrance LMS-337CDF GPS Receiver
Lowrance 330c gps not responding
do you have both power and ground wires hooked up?
Jul 27, 2010 | Lowrance LMS-330C GPS Receiver
My LMS-522C keeps losing it's position on the GPS.
I'd suggest calling Lowrance.. Those guys are very helpful with step by step support... I just purchased a used boat with a 525c df on it and been troubleshooting some problems with it. Central time zone and best to call right when they open or turn on the phones at 8:15.
Mar 07, 2010 | Lowrance Lms 522c 5" Screen Color Internal...
Won't power up
Make sure the power is good, and the power connections are clean. Check fuses and connections. You can even get a volt meter, unplug the power cable and test for 12VDC across the two bigger female contacts on the power cable connecter. If you are getting 12VDC, then the LMS-520 is bad. If you are not getting 12VDC, then you have a bad power supply, connection, or cable.
Jul 10, 2009 | Lowrance Lms 520c 5" Screen Color External...
I have a lowrance LMS 332C GPS. After 5 years I
The LGC-2000 is bad would be the most likely cause, but if this started right after you changed the cables, Try connecting the NMEA 2000 network to a different power source than the main power. If you still have the original cables, and you didn't have the problem before, try using those again to make sure there isn't anything wrong with any of the new cables.
But most likely, the LGC-2000 is toast and you will want to contact Lowrance support to see about getting it repaired/replaced.
Jul 04, 2009 | Lowrance LMS-332C GPS Receiver
HAVING A PROBLEM WITH MY LOWRANCE 525C WITH EXTERNAL ANTENNA. IT KEEPS TELLING ME GPS MODULE NOT RESPONDING. I HAVE CHECKED ALL CONECTIONS AND CANNOT FIND A PROBLEM. WHAT NEXT
Make sure that you have powered the NMEA 2000 network. The display unit's power cable has a set of red, black, and sheild wires that need to be hooked up to a 12VDC power source. There is a power diagram somewhere in the manual that should show this.
Make sure that you have the NMEA 2000 network connected properly. If it is a newer version LMS-525, it should just be a single 15ft cable that has two female ends, the module plugs into one end, and the other end plugs into the back of the display.
If it came with some T connecters and 120Ohm Terminator caps, then make sure you have that hooked up correctly. There should be a diagram in the manual for that as well but you just connect the two T's together like TT, put the 120Ohm terminators at each end, and run the extensions to the display and GPS module.
There is a decent troubleshooting guide for checking to make sure power is getting to the module at http://primus.lowrance.com/support/resultDisplay.do?gotoLink=92&docType=1000&contextId=426%3A92.273%2C600.639%2C92.113&clusterName=ClusterPublic&lang=english&docset=%2FDocuments%2FTroubleShooting%2FNew+Utility&contentId=42296cce-4f9b-40c8-9dcf-33d5df754009&responseId=135ccbe2cfd4f608%3A1fe88d%3A1225c5cc17c%3A-bac&groupId=4&answerGroup=1&score=986&page=http%3A%2F%2Fprimus.lowrance.com%2Ficr%2FTroubleShooting%2FNew+Utility%2FNU_GPS_ModNR.htm&result=0&excerpt=Module+Not+Responding+The+GPS+module+not+responding+(early+GPS+products+may+also+indicate+coupler+not+responding)+indicates+that+the+unit+and+module+are+no+longer+communicating.&question=gps+module+not+responding&resultType=5000#Goto92
If this doesn't tell you anything, most likely the GPS module is bad.You will need to contact Lowrance support to get it repaired/replaced. You can call them at 800-324-1356 or email them at http://www.lowrance.com/en/Support/Product-Support/Contact/
Jun 29, 2009 | Lowrance Lms 525c Df 5" Df Sonar...
Alarm says" gps module not responding"
"GPS Module Not Responding" is the display units way of telling you there is basically no GPS module connected. You didn't say which unit you have, so I am assuming this is something like an LMS-520? The GPS module is the LGC-3000? If this is the module you have, make sure that you have powered the NMEA 2000 network. The display unit's power cable has a set of red, black, and sheild wires that need to be hooked up to a 12VDC power source. There is a power diagram somewhere in the manual that should show this.
Make sure that you have the NMEA 2000 network connected properly. If it is a newer version, it should just be a single 15ft cable that has two female ends, the module plugs into one end, and the other end plugs into the back of the display. If it came with some T connecters and 120Ohm Terminator caps, then make sure you have that hooked up correctly. There should be a diagram in the manual for that as well but you just connect the two T's together like TT, put the 120Ohm terminators at each end, and run the extensions to the display and GPS module.
There is a decent troubleshootin guide for checking to make sure power is getting to the module at http://primus.lowrance.com/support/resultDisplay.do?gotoLink=92&docType=1000&contextId=426%3A92.273%2C600.639%2C92.113&clusterName=ClusterPublic&lang=english&docset=%2FDocuments%2FTroubleShooting%2FNew+Utility&contentId=42296cce-4f9b-40c8-9dcf-33d5df754009&responseId=135ccbe2cfd4f608%3A1fe88d%3A1225c5cc17c%3A-bac&groupId=4&answerGroup=1&score=986&page=http%3A%2F%2Fprimus.lowrance.com%2Ficr%2FTroubleShooting%2FNew+Utility%2FNU_GPS_ModNR.htm&result=0&excerpt=Module+Not+Responding+The+GPS+module+not+responding+(early+GPS+products+may+also+indicate+coupler+not+responding)+indicates+that+the+unit+and+module+are+no+longer+communicating.&question=gps+module+not+responding&resultType=5000#Goto92
Apr 05, 2009 | Lowrance Lcx 28c Hd 7" Gps Fish Finder...
I have an lms-530c it keeps coming up gps module not responding?
Your GPS module is not receiving power (12volts). In the instuctions should be an additional red sheet of paper explaining how to wire it correctly. If the wiring is done right, check the 3 amp fuse.
Sep 01, 2008 | Lowrance GPS
GPS module not responding
check the power connections to the antenna
Aug 23, 2008 | Lowrance LMS-330C GPS Receiver
Lowrance LMS-480MDF GPS Receiver Logo
534 people viewed this question
Top Lowrance GPS Experts
Jay Plesset
Are you a Lowrance GPS Expert? Answer questions, earn points and help others
