Question about Panasonic AJ-D230H DV/Mini DV VCR
Error Codes E-2, E-41, E-61
Hello. My DVC pro deck won't move forward. When I try and record using Final Cut Pro edit to tape, it gets about 3 seconds in that shuts of and gives me error code E-61, The SUpply Reel Motor has Locked Up, or E-41, The FG (rotational speed) signal has not ben output from the cylinder motor, and E-2 - which doesn't have a definition listed in the manual. What can I do myself to fix this??? I can't afford to spend the mega dollars that the repair shop will require!
    Champion:
  • 221 Answers
If you're experienced in capacitor replacement, check the capacitors on the mechanical interface board. When these caps fail, you get mechanical errors like you described. I generally replace all the capacitors on this board as a precaution; I've never had a callback when I replace them all.
Posted on Aug 22, 2007
SOURCE:
Tip
Import MTS to Final Cut Pro X-Convert Sony PJ30V 60p MTS to H.264 MOV for...
The Sony PJ30V has more compression options than your average camcorder. Most of its video is recorded using AVCHD compression, which is today's industry standard. The HDR-PJ30V has 32GB of internal flash memory and it can record Full HD video using 60p, 60i, or 24p frame rates. The PJ30V comes with the same version of Picture Motion Browser (PMB) software that shipped with the Sony HDR-CX700V, which we reviewed earlier this year. The new version of the software is nearly identical to previous versions of PMB, except version 5.5 does allow you to import and work with 60p and 24p clips (something that is essential for the HDR-PJ30V). One big downside, we noticed in terms of editing, is that the 60p clips recorded by the PJ30V don't always play nice with mac editing software. Final Cut Pro version 5.0, for example. And Now <b>Final Cut Pro X</b> is available could be Downloaded from the Mac App Store. However <b>Log and Transfer was removed</b> in the X version of Final Cut. So all Pro mts camcorder owners who use Final Cut are looking for <b>HD Camcorder MTS Converter Software</b>. <br /><br />Here is the step-by-step guide to quickly use Final Mate for Mac to <b><a href="http://sony-mts-converter.com/2011/06/import-mts-to-final-cut-pro-x-convert-sony-pj30v-60p-mts-to-h-264-mov-for-editing-in-fcp-x/">Import/Convert Sony PJ30V 1080/60p MTS to H.264 MOV for editing in FCP X</a></b> on Mac. <br /><br />Step 1. <b>Capture native MTS from Sony PJ30V to Aunsoft Final Mate for Mac</b>. <br />Run Aunsoft Final Mate for Mac as the fast <b><a href="http://www.aunsoft.com/final-mate-mac/">Import AVCHD MTS to Final Cut Pro X</a></b> on Mac, and drag the .mts files already backup all mts recordings from Sony PJ30V to your computer, and can browse the .mts video path and the software will automatically show your AVCHD clips in "Resource Tab". <br /><br />Step 2. <b>Create a Movie for combine and convert Sony PJ30V AVCHD MTS 1080p footage</b>. <br />Just select one or multiple video files you would like to convert and then drag and drop them to Movie tab. In this way, a Movie for conversion will be created. <br /> <br />Step3. <b>Convert MTS files to H.264 MOV for Final Cut Pro X</b>. <br />Click the Export button. Follow HD Video &gt; H.264 HD Video (*.mov) to choose output format for editing in Final Cut Pro X. You can then adjust video parameters to keep original video resolution, bitrate, framerate, etc with highest quality. The <b><a href="http://www.aunsoft.com/final-mate-mac/">Mac MTS to Final Cut Pro X Conversion</a></b> will start <b><a href="http://www.aunsoft.com/final-mate-mac/">converting MTS to H.264 MOV</a></b>. <br /> <br />After the conversion, the AVCHD videos could be imported to Final Cut Pro X with 60fps highest quality. Of course, you also can choose <b>Final Cut Pro &gt; Apple ProRes 422 (*.mov)</b> as output format for without rendering. ProRes is advertised codecs to result in less compression and higher data rate/higher quality files for HD editing in Final Cut Pro. <br /><br /><b>Tips:</b> The Final Mate For Mac support camcorder includes but not limited to Panasonic HDC-TM900,TM90,SD90,HDC-TM700/HS700/SD700, SD60/HS60, DMC-GH2,GH1,GF2,ZS7/TZ10; Sony HDR-CX700, CX550, XR550, XR520, CX350, CX305, CX150,CX360, Alpha NEX-5,DSC-HX5V; Canon Vixia HF200, HF S100,HG10,HG20,HF R10,HF R11,HF R100.etc If you want to know more about Camcorder, please visit the <b><a href="http://www.aunsoft.com/camera/sony.html">Camcorder column</a></b> for more information.
on Jun 27, 2011 | Sony Alpha DSLR-A580 Body Only Digital...
Get Final Cut Pro 5.04 to communicate with my XH A1
Many HDV cameras and decks are able to play and record DV as well as the higher-resolution HDV format. Additionally, many of these HDV devices will attempt to automatically change their settings to match the format of the tape that it's playing. Here are some tips for using these types of devices with Final Cut Pro / Final Cut Express.
Tip: Make explicit settings on your HDV device. Instead of using an "Auto" setting, make your own settings on your HDV device to keep the communication going between it and Final Cut Pro / Final Cut Express. This also helps Final Cut Pro / Final Cut Express keep things running smoothly with HDV devices that handle both DV-NTSC and DV-PAL.
For example, say you're using an HDV deck to capture footage from a tape that was recorded as DV-NTSC. Before capturing in Final Cut Pro / Final Cut Express, make sure that you set the deck to DV mode specifically—don't rely on Auto mode. With some devices, you may need to disconnect it from FireWire to change the mode.
For a common capture workflow, this sequence of steps can provide the best results:
  1. Quit Final Cut Pro / Final Cut Express if it's open.
  2. Insert your tape into your HDV deck or camcorder.
  3. Use the device's menus to set it to match the format that's recorded on the tape.
  4. Connect your HDV device to your computer with a FireWire cable.
  5. Open Final Cut Pro / Final Cut Express.
  6. Choose an Easy Setup for DV or HDV (whichever matches the format recorded on your tape).
  7. Proceed to Log and Capture.
Tip: Quit Final Cut Pro / Final Cut Express before changing modes. It's generally a good idea to quit Final Cut Pro / Final Cut Express before you change the mode on your device from DV to HDV, or from HDV to DV, and then re-open the application again.
Tip: Use an Easy Setup to play back non-default HDV format footage on your HDV device. You can use Final Cut Pro / Final Cut Express to make your HDV device play back footage in its non-default HDV format. For example, maybe you have a 1080i60 HDV device and want to play back footage that was recorded as 1080i50. Or perhaps you have a 1808i50 HDV device and you want to play back footage that was recorded as 1080i60. To do this, follow these steps:
  1. Connect your camera to your computer.
  2. In Final Cut Pro / Final Cut Express, choose an HDV preset Easy Setup that matches the format of the tape's footage (you don't need to restart Final Cut Pro / Final Cut Express).
  3. Your device's LCD display should automatically display a switch to 60 or 50, indicating the type of media that's being played.
Playing back non-default DV format footage on your HDV device You can also use your HDV device to play back footage in its non-default DV format too. For example, maybe you have a 1080i60 HDV device and want to play back footage that was recorded as DV-PAL. Or maybe you have a 1080i50 HDV device and want to play back footage that was recorded as DV-NTSC. If so, follow these steps:
  1. Make sure that your device is in DV/DVCAM mode.
  2. Put your device into Play/Pause mode, then open the Log and Capture window in Final Cut Pro / Final Cut Express.
  3. Make sure that your device's LCD (or other readout screen) displays the same format as your tape or Final Cut Pro / Final Cut Express will misinterpret what type of device you have.
Tip: Avoid recording both HDV and DV formats on the same tape. Use separate tapes whenever you want to record in a different format. If you need to record over existing footage in a different format (for example, you have a tape with DV-PAL on it, but you want to record over it with HDV 1080i50), it's a good idea to black and code the tape, or completely record over the old footage with contiguous recording in the new format. If the tape contains even a second of, say, DV in the middle of an HDV tape (or vice versa), it could cause unexpected results later when you try to capture video from that tape.
For more information, see HD and Broadcast Formats and the Final Cut Pro / Final Cut Express User Manual, available under the Final Cut Pro / Final Cut Express Help menu
Dec 04, 2007 | Canon XH A1 Mini DV Digital Camcorder
Audio Problem with Firewire
The input select switch on the front of the AJ-D230H needs to be in the "OPTION" position, not "LINE". That may help if all the other settings are correct. You will also have to make sure that you have selected the right codecs for the deck that you are using in the software. I am speaking as a Final Cut Pro user so only offer this as a suggestion as these are the things that work from out of Final Cut.
Good luck. It can be very frustrating, but awesome when it all comes together and works right!!!
Helen
Oct 24, 2007 | Panasonic AJ-D230H DV/Mini DV VCR
Tip
How to import Kodak video to Final Cut Pro and edit Kodak video with Final Cut...
How to import Kodak video to Final Cut Pro and edit Kodak video with Final Cut Pro?
Final Cut Pro is a professional and all in one video editing, compositing and special effects package for the Macintosh. The software logs and captures video onto a hard drive (internal or external), where it can be edited and processed.
If you are a Kodak video fan and you want to give professional editing to your Kodak videos, Final Cut Pro is the best choice for you. However, Final Cut Pro can edit any QuickTime compatible file format including DV, HDV, MOV, MPEG-4. That is to say, in order to edit your Kodak video with Final Cut Pro, you have to convert Kodak videos to the supported formats by Final Cut Pro with Kodak video to Final Cut Pro Converter for Mac.
Tips:
Kodak records the video files with mov files (i.e. Quicktime files) does not mean they are perfect for editing in FCP. The fact is, all of the small video cams, including the Kodak Zi8 Cams, records highly compressed codecs that are known as delivery codecs, not editing codecs. You need one third-party software to convert HD mov files to some formats like DV, HDV , MPEG-4 that FCP is happy to edit.
Kodak video to Final Cut Pro Converter for Mac is one simple-to-use solution with the minimum amount of buttons and a small menu for converting Kodak video (Kodak Zx1, Kodak zi6, Kodak Zi8 and Kodak PLAYSPORT) to DV, HDV, MPEG-4, etc., for importing Kodak videos to Final Cut Pro. Besides, it is also an easy-to-use editing tool that assist you for making personalized video. You can trim the video to a certain length to convert, adjust video aspect ration by using crop function, add special effect like Gray, Emboss, Old film into video to make it more artistic, join several files or set the video output parameters. All this can be done with a few mouse clicks.
Part one: How to import Kodak video to Final Cut Pro and edit Kodak video with Final Cut Pro?
Step 1:Free download and install Mac Kodak video to Final Cut Pro Converter
Download Kodak Video to Final Cut Pro Converter For Mac and double click the downloaded . dmg files to install. A user-friendly interface will pop up.
Step 2:Load Kodak video files
First: Connect Kodak camcorder to computer and transfer mov files to iMac, Mac book.
Second: Hit the File button on the top left panel or click "Add Video" button to select Kodak MOV files to this converter.
Step 3:Select the output format and destination
Click the downward arrow beside Settings to choose the proper Final Cut Pro format from the drop-down list. And then click Browse button to specify the output location.
Tips: Select DV, HDV or MOV format for FCP in the pull-up list next to Profile field. And then click Browse button to specify the output location.
Step 4:Start the conversion
After all the necessary setting has been done, hit the "Start" button to start converting. Click the Open button to select the converted DV, HDV files to Final Cut Pro for further editing upon completion.
Part Two: Import Kodak videos to Final Cut Pro and edit Kodak video in Final Cut Pro.
Step 1:Import Kodak videos to Final Cut Pro
Launch Final Cut Pro and click "Import"-"Files" and then select the converted Kodak files. Find the file in the resources list for the project and drag the file into the Timeline, and then save the project.
Step 2:Edit Kodak video in Final Cut Pro
Apple's Final Cut Pro Software is an all in one video editing, compositing, and special effects package for the Macintosh. The following steps will show you how to use the Timeline:
One: Edit video and audio timing
There are three tracks on the Timeline, one for video and the other two for audio. And you can cut the video and audio tracks all at once in the same place.
Choose the razor blade tool in your menu, and click the times that you want to split it. You can also set input and output times on the Viewer window. Final Cut Pro also allows you to layer video tracks on top of each other.
Two: Add transitions
For Kodak videos, you might want to use simple and non-distracting transitions. Then you can just select Fade Out or Cross-Fade transitions.
Three: Export video
Once you are finished with editing your video, click on File and point to Export, then you will see a list of options of how you can export the edited file. For example, if you want to publish your video to the web, you can click on "Export using QuickTime Conversion". When you see the naming dialog box, input the name you prefer and at the bottom, select "MPEG-4" at the bottom, and then select "Broadband-High" under the format setting. And now click on Save.
on Sep 17, 2010 | Computers & Internet
Tip
Import flip video to Final Cut Pro and edit flip video Final Cut Pro Final Cut...
Final Cut Pro is a professional video editing application for Mac users and it is widely used even by many Hollywood people on professional movie post-production. If you are a flip video fan and you want to give professional editing to your flip videos, Final Cut Pro is a great choice. However, Final Cut Pro does not allow raw flip videos to be imported to Final Cut Pro and you will need to convert flip video to Final Cut Pro supported formats. Thus, to edit flip video in Final Cut Pro, you can follow the three parts below:
Part One: Convert flip to Final Cut Pro video
Download Doremisoft Mac Flip Converter and refer to the following steps to import flip video to Final Cut Pro.
Step 1: Add flip videos
Click the "Add File" button to add the flip videos you want to edit in Final Cut Pro to Mac Flip Converter.
Step 2: Select a Final Cut Pro supported output format
Click the Profile drop-up list and select
Step3: Convert flip video to Final Cut Pro
Click the "Start" button on the lower right of the interface to start converting flip video to Final Cut Pro.
Part Two: Import converted videos to Final Cut Pro
Step 1: Launch Final Cut Pro and you can see the layout of the Final Cut Pro Interface. From under the File command at the top of the interface, select "Import" and "Files". Thenselect one converted file from the Choose a File window and press the "Choose" button to choose this file.
Step 2: Find the file in the resources list for the project.
Step 3: Drag the file into the Timeline and then save the project.
Part Three: Edit flip video in Final Cut Pro
Final Cut Pro is a very professional tool with many functions. The following steps will show you how to use the Timeline:
Step1: Edit video and audio timing
Step2: Add transitions
For flip videos, you might want to use simple and non-distracting transitions. Then you can just select Fade Out or Cross-Fade transitions.
Step3: Export video
As mentioned above, Final Cut Pro is a very good tool for professionals. If you want to know better about using Final Cut Pro, you can go to certain Final Cut Pro forums. The most popular one is Los Angeles Final Cut Pro User Groupn and you can find a lot of useful info there.
You might also want to buy a book and study how to use Final Cut Pro, such as Apple Pro Training Series: Final Cut Pro 7 and learn how to professional edit your videos with Final Cut Pro.
If you just want to do some basic editing such as cropping, length trimming and video effect adjustments, you can just use Doremisoft Mac Flip Converter to get the job done by following How to edit flip video with Doremisoft Ma Flip Converter.
on Aug 13, 2010 | Computers & Internet
Tip
Import MOD to FCP ? How to import MOD to Final Cut Pro to edit your MOD files
Final Cut Pro is a very sophisticated video editing program made by Apple and provides professional editing of any QuickTime compatible video format including DV, HDV, P2 MXF (DVCProHD), XDCAM, QuickTime MOV, QuickTime MP4 etc. It has become the choice for multimedia journalists using Apple computers and many Hollywood film makers.
However, Final Cut Pro does not support MOD files, which poses a problem if you are using JVC, Panasonic or Canon camcorders that take MOD videos. So if you want to edit MOD in Final Cut Pro, you will need to convert MOD to Final Cut Pro supported formats.
Doremisoft Mac MOD converter provides the perfect solution to letting you import MOD to FCP by converting MOD to Final Cut Pro supported formats.
The four steps below will guide you to import MOD to Final Cut Pro:
Step 1: Add MOD files
Click the "Add File" button to add the MOD files you want to import to Final Cut Pro from your Mac hard disc. Then double click a file or select a file and click on "Open" to add it.
Step 2: Select the output format
Click the small arrow at the end of the Profile field, and you will see the Profile drop-up list. Move your mouse cursor to "HD Video" and click on the "HD MOV" profile. This option will let you convert MOD to FCP MOV. Then you can tick the "Apply to all" option that will convert all added MOD files into selected Final Cut Pro supported format. You can also convert MOD to FCP MP4 if it is what you prefer.
Step 3: Start to convert MOD to Final Cut Pro
Find the round Start button on the lower right part of the main interface to start the conversion. On the conversion window you can see the elapsed time and the remaining time. Now you can decide how to kill the time before the conversion is finished. Then just don’t forget to come back for the converted files you want to import to FCP.
Tip: You can also use Doremisoft Mac MOD Converter to do easy editing such as cropping, trimming, and video effects to your MOD files, click here to see how.
Step 4: Import converted MOV to Final Cut Pro
Launch Final Cut Pro and you can see the layout of the Final Cut Pro Interface. From under the File command at the top of the interface, select "Import" and "Files". Then select one converted file from the Choose a File window and press the "Choose" button to choose this file. Then find the file in the resources list for the project and drag the file into the Timeline and then save the project.
Now you have successfully imported MOD to Final Cut Pro and just start editing!
on Jul 21, 2010 | Cell Phones
Panasonic AJ-D230H DV/Mini DV VCR Logo
1,391 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
