Question about Samsung HC-P4241W 42" Rear Projection HDTV-Ready Television
TV picture not straight
I have a 42-inch project TV model HC-P4241W and the picture seems to be slanting to the right. When there is a horizontal line on TV, the left side is about ½ inch higher than the right side and I was wondering if there are any manual adjustments inside? Also, color does not seem to be converging.
  • Super6574 Nov 17, 2007
    I have the same tv but with a diffrent problem.the tv turns on and when the pic comes on i get the pic bending downwards from the top and upwards from the bottom at the same time im getting double images with the colors all over the place.
    Any ideas?
  • jvasanth May 18, 2009
    I have a 29-inch color TV model CS29M50 and the picture seems to be
    side is about ½ inch lower than the right side and I was wondering if
    there are any software or manual adjustments
    New Friend:
  • 13 Answers
There are no manual adjustments inside. this problem happens to many sets of all different manufacturers and models of c.r.t proj. type tv's. What has happened to your tv is most likely that one of the ic's (large black modular looking things about 2" by 1" by 3/8" fastened to a large aluminum slab of metal called a heat sink) on one of the large circuit boards has SHORTED OUT. The number on these ic's is stk392-***. If the asterisks shown are 110 then there is an upgrade of 180. If say the last 3 numbers are 040 then there is no upgrade. Anyway both Ic's need to be replaced and any associated resistors in the circuit area that have burned open or got hot and changed value also must be replaced..in addition a calibration of the convergence may need to be done either according to your operators manual or factory service manual by using your remote control and/or buttons on the front panel of the tv. Sometimes a samsung will have a small circuit board separate from all neighboring circuit boards that only has the convergence circuit on it. In that case the complete board should be replaced if possible. Do not attempt to do this repair yourself unless you are expert in electronics or guided by one. Above all do not attempt to make any repairs without being sure that the set is NOT plugged in.
Posted on Aug 23, 2007
  • Ken Sheftel
    Ken Sheftel Aug 23, 2007
    Also I had not mentioned why this happens...Invariably the heat sink compound (white pasty looking material sandwiched in between the ic metal backing and the heat sink) has dried out or was not ample enough and/or the screws fastening the ic's were not tight enough to secure properly the ic's mentioned. This heat sink compound material is PARAMOUNT to allow proper heat transfer and needs also to be replaced with known excellent silicon heat sink compound that exhibits excellent heat transfer properties and will not dry out. Careful soldering and de-soldering measures must be taken as well to insure a no-damage repair procedure as well as being careful to create no solder bridges between the pins of the ic's when the new ones are inserted. Be very careful of static charge when handling all delicate electronics boards and their parts. Before beginning also make sure there are no large charged capacitors that have not been discharged using a 1k ohm resistor and a piece of wire usually an alligator type test lead.
    This entire procedure usually takes up to 3 hours if done properly. In addition before new compound is applied the old compound must be thoroughly removed with anhydrous alcohol(99% isopropyl
    ). Finally because of this problem it is highly recommended that cool airflow around the back of the tv is insured. Good Luck
SOURCE:
When i turned on my Hc-p4241w i smelled a burning smell then the color started looking 3d, i took a flashlight & looked through the left side of the tv and saw a orange glowing inside and i shut the tv...
Your Convergence output is burnt.DONT turn that TV on until convergence IC's are replaced,orange glowing inside that you see it is resistors that overheating and burning.Unplug TV from outlet before more damage is done
Aug 23, 2011 | Samsung HC-P4241W 42" Rear Projection...
I m looking for samsung projection repairer at surat.
Call Samsung for information 1-800-627-4368
What seems to be your problem with TV?
Jun 23, 2011 | Samsung HC-P4241W 42" Rear Projection...
Hi, my tv hc-p4241w was ok but one day, the picture in the screen become wide and then I saw smoke from the rear panel. I switched off the TV, and I found that the C407 have exploded, there's a Diode...
Look to see if any coolant fluid has leaked from any of the CRT's. This is a common cause of multiple component failures in these models. Look real close at the CRT mounting bracket, the wires coming from the CRT's and look at the particle board below to see if you can see any staining or puffed up wood particles. My experience with the Samsung bds is when you have a multiple compoment failure due to fluid leakage it is best to replace the boards instead of component level repair because other components will fail at a later time. Coolant fluid is real hard to spot since it is ultra clear. Hope this helps.
Jul 13, 2009 | Samsung HC-P4241W 42" Rear Projection...
Samsung hc-p4241w - No picture
samsung tv model hc-p4241w good picture no sound
May 22, 2009 | Samsung HC-P4241W 42" Rear Projection...
Samsung LCD TV HCP4363WX/XAA Black screen no sound.
check out the link below ... sounds like a similar problem:
http://www.dslreports.com/forum/r20889230-Samsung-LCD-TV-No-Picture-but-has-Sound
Aug 21, 2008 | Samsung HC-P4241W 42" Rear Projection...
Samsung hc-p4241w problem
Look for 2 Big black chips they will be together on convergence broad STK-392-110s,120s replace both ics.Use STK-392-180s
Mar 29, 2008 | Samsung HC-P4241W 42" Rear Projection...
Samsung HC-P4241W 42 in. Rear Projection CRT aging
First off, do you not know Internet etiquette? Caps are considered yelling or shouting! So please! head You have the typical convergence failure of the convergence correction IC's. They BOTH need to be replaced. If you have no solid state printed circuit board experience, play it safe and call in a pro to assist you in this repair. Good Luck
Jul 28, 2007 | Samsung HC-P4241W 42" Rear Projection...
SAMSUNG 42inch HC-P4241W MODEL CRT AGING
explain what the picture looks like? Does it look like the edges are in 3-D?
Jul 25, 2007 | Samsung HC-P4241W 42" Rear Projection...
Open Questions:
Samsung HC-P4241W 42" Rear Projection HDTV-Ready Television Logo
368 people viewed this question
Jerry Greenberg
Jerry Greenberg
Demonic-2011
Demonic-2011
