Question about Hitachi 60V500 60" Rear Projection HDTV-Ready Television
Hitatchi tv i have a problem with the screen yellowing in a large oval shape which occupies like 70% of the tv.
    New Friend:
  • 13 Answers
Most likely your "light engine" needs complete replacement and it is quite an installation...If not under warranty, usually Hitachi will NOT charge you for the light engine assembly (about as big as a bread box) for this particular V500 series because of all the failures they are aware of..However Hitachi will require a technician to do the installation and first verify that the light engine needs replacement...Hitachi will NOT pay for labor unless the tv is still under warranty. Labor varies. I know that for this 3 hour procedure or more, including calibration after replacement as necessary, I charge $400 or more..Above all pick a highly recommended technician.. Sorry for the bad news.. this happens alot to the V500 series. colors vary..sometimes red and sometimes blue ...this problem due to overheating. The replacement should be an improved assembly, sometimes rebuilt, sometimes new and both usually upgraded so this does not happen again. Do not attempt repairs on this yourself as it requires great expertise; and disassembly and reassembly of top portion of TV requires 2 people. And, on top of that, ever so often the lamp for this tv has to be replaced after a certain amount of hours of play (hopefully 2 years depending on hours of use) and just the lamp alone which you CAN replace yourself is $260 give or take more or less money. Always research any NEW TECHNOLOGY TV's thoroughly before you spend mucho bucks so you know what you might be in for. I try to avoid buying cutting edge technology myself as it's not fully tried and true and tested by any means. It cant be avoided if you want to buy the latest and the greatest motherboards for computers and once in a while I get burned like anybody else. But motherboards are usually only a couple hundred bucks, not thousands of dollars!
Posted on Aug 23, 2007
SOURCE:
LIGHT YELLOW OVAL SHAPE PILL WITH 106S ON IT
You are reading it upside down. It is S 901 not 106 S. It's a .5 mg generic Xanax.
May 01, 2015 | Health & Beauty
What is large oval yellow tablet, scored, 44 left of score and 533 right of score
http://www.drugs.com/answers/otc-pill-oval-yellow-with-imprint-44-533-472970.html
Feb 21, 2015 | Health & Beauty
Yellow hue circle in middle of screen. after leaving tv on all night
spherical or oval shaped light starting in the center of your picture is an indication of an led backlit tv.. probably a hitachi. solution, replace light engine..ps no garuntees not with led backlit sets.. was bad idea to begin with. when the leds start going they start at the center and branch out.
Apr 13, 2009 | Hitachi 50V715 50" Rear Projection...
Fuzzy picture, oval shaped, scrolling up slowly
I would start by checking the large filter capacitors in the power supply. I can't be sure since I'm not seeing the set, but it sounds like you're describing AC ripple. In a 20-year-old set, some of those electrolytics will be drying out. A few replacements may take care of the trouble for you.
Jan 01, 2009 | Panasonic PT-56WXF95 56" Rear Projection...
I just replaced my Hitachi T.V's lamp after the first one ran out. Now, there seems to be a blueish glow on the lft side of the screen. It is large and very noticible. is this normal because of the new...
I would have a tv service center come out and look
at.
usually if you have blue or red oval shape on the screen it is a indication . The light engine is bad. cost of light engine is 395.00 on up. Put your tv on a blank screen you will see it,
thanks doctor video since 1987
Jun 14, 2008 | Hitachi Televison & Video
Yellow middle, Blue Exterior
Hi Druaga
This is a Blue LCD Polarizer that will have to be replaced if the spot shows yellow.
You will find that this will only get worse as time goes by.
May 28, 2008 | Panasonic PT-AE700U Multimedia Projector
Bad color
If it is a glass crt then you need to have the set demagnatized with a demagnatizing coil. All tv shops have one. This is worth fixing and usually at the price of a service call.
Mar 15, 2008 | Panasonic CT-32SX12 32" TV
Oval shaped picture problem with Mitsubishi WS55807
Self test: Turn on and Press the input and menu buttons on front panel together and hold for 5 sec. after 5 sec the power LED will blink a 2 digit seq. This will let you know what error code. Count the first blinks then a short pause then the second blinks. Example 2-3, 3-4, 4-1. Let us know what it is
Nov 21, 2007 | Mitsubishi WS-55807 TV
Hitatchi ultravision 53" rear projection lcd tv
You have a problem with the optical engine- The only repair would be to change the engine for about $500-$1,000 plus labor. This is a major repair (sometimes caused by dust particles getting on the LCD panels inside the engine, but disassembling the engine to try and clean it is not a reasonable option)
Aug 21, 2007 | Hitachi 60V500 60" Rear Projection...
Hitachi 60V500 60" Rear Projection HDTV-Ready Television Logo
102 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
