Question about Panasonic PT-53WX54 53" Rear Projection HDTV
My tv is going crazy...major convergence problem
While watching tv the other morning by tv's convergence seemed to instantly go haywire. the red is way off target...way more than can be fixed by the convergence feature on the menu. there are red ghost images about an inch off plus a red band going through the picture. I live in the middle of nowhere Arizona so any help is especially appreciated. thanks
I have a Mitsubishi VS 55601. Any idea where I can get these and is it a difficult job?
Posted on Oct 30, 2012
  • 625 Answers
The convergence ICs are bad. replacing the ICs usually fixes it - they cost about 15 bucks each.
Posted on Aug 21, 2007
Is it a difficult to replace the convergence amplifier modules on a Mitsubishi VS 50609 TV?
Your convergence has failed. This is a very common problem on most projection tv sets. You can read about it here on fixya using this link
http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Feb 20, 2013 | Mitsubishi VS-50609 50" Rear Projection...
Rca big screen 5-8 years old, power shut off this morning while watching then when I powered it back up now blurry and has a red and green outline around everything onscreen
If you have the original remote to that tv, click on menu, then select set up from the on screen menu, then select convergence. you might see auto convergence as well as manual for blue and red convergence.
If you see Auto, select it, this will line up your tubes.
If no auto convergence, you will have to select each one, and follow the instructions to aline your tubes.
Oct 09, 2010 | RCA R52WM24 52" HDTV Projection Television
JVC AV-56WP74 Colors quit working or went out of balance.
Guns or CRT are probably ok. Your TV needs a convergence IC STK392-120 replacement. Lamp are used on LCD and DLP rear projection TV's. Color wheel are for DLP's. :)
Dec 26, 2009 | JVC Televison & Video
Tv Problem
Sony TVs generate an error code. The front panel LED (red) will flash anywhere from one to eight times which can isolate the problem circuit. It is not always accurate.
If you have a test meter which can read DC voltages and resistance in ohms, you can locate the problem area. If you lack the expertice to do so, contact a sony authorized servicer. If you have the ability, start by checking fuses on the "G" board ( power supply board) and the "D" board or deflection board.
A major problem area in this TV is the convergence circuit. There are six fuses around the convergence output ICs on the "D" board.
If any are open, replaces the output ICs.
Feb 13, 2009 | Sony KP-61HS10 61" Rear Projection...
Blue Convergence out of sync
you need to adjust the convergence. you set up convergence 1 then 2. follow the manual. (Its easy, you just align the + signs so they make one white one (instead of three green, red, blue) sounds like something or someone bumped the tv, causing the blue lens to shift a little.
Nov 23, 2008 | Panasonic PT-47WX49 47" Rear Projection...
Colors Misalinged
You have what is known as covergence problems. Ok to begin with. 1 Go into customer menus goto SETUP do you have the "CONVERGENCE" option. If you do not the the likelyhood is you have the fl231 fuse problem and if you can solder and get it i recomend it a simple repair. ok if you have that option then try going in and autoconvergening if that didnt work try manual the red and blue convergence. if in the manual red and blue the crosshair didnt move then you probably have convergence power board problem if only one moved or just move a up and down or left of right then it might be a amp board issue. the other problems it could need a simple factory alignment.
Aug 26, 2008 | RCA HD56W66 56" HDTV
PHILIPS 43P8341 CONVERGENCE OF GREEN AND RED
Jennifer, adjusting it won`t fix it, the convergence IC`s have failed, major job to get them out and unless you have tv tech skills with soldering equipment and volt meter you`ll have to call a tech for this one , sorry to be the bearer of bad news, BMW Rider
Jan 01, 2008 | Philips 60PP9202 60" Rear Projection...
Red ghosts
red convergence went haywire... you need to relace I'm thinking two convergence ICs mounted on heatsink on convergence panel. replace both for usually they both blow replace any burnt resitors too, and hardest of all now you need to reconverge the whole thing.....which is a fine art.....u might be able to do it with the remote ...but u need a manual to go throught the steps really ..but not me i do em in my sleep. take it to shop unless your technical.
Aug 17, 2007 | Sony KP-53HS30 53" Rear Projection...
HELP Please. Symptoms seem so similar to this unit.
This sounds as if one of your convergence IC's has shorted out. There should be 2 large black IC's on a heat sink, probably labeled STK392-040. There is a small fuse next to each IC that looks like a small resistor. The IC that controls red-red-half green is bad, leaving the blue where it should be. Replace that IC and its fuse and your picture should return to normal.
Jun 17, 2007 | Samsung PCN5425R 54" Rear Projection...
Panasonic PT-53WX54 53" Rear Projection HDTV Logo
131 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
