Question about Marshall Computers & Internet
Parking Only. What is it and how do i get my monitor back to normal?
While exploring the settings of the monitors, I changed the "EXT. WIRE" setting which was previously set to "Power On" to "CAR PARKING" with out knowing what that ful well meant. And now it will not let me change the setting back rather it gives me a blue screen that says "PARKING ONLY". How do I change it back to "POWER ON" if it wont allow me to access the menu? HELP!
  • ryn_mts Feb 07, 2009
    i have the same problem in Marshall V-R842P-AFHD 8.4" LCD Monitor.. it won't allow me to access the menu.. when turning it on a signal will appear less than a second then it post' PARKING ONLY again...
SOURCE: Problem with Control Panel
Try doing the following Keep the exit button pressed for a few seconds untill you see a change on the screen when the control pannel is locked and the locked screen appears on the screen..... try it and lemme know about
Posted on Sep 02, 2006
  • 9098 Answers
SOURCE: monitor color changed
Assuming you can rule out the PC and the cable (are the pins ok?) then it sounds like it needs component-level electrical troubleshooting.
Posted on Jan 12, 2007
SOURCE: proview 900 series black flat panel monitor
Same problem, and solution 1 given here fixed my Proview 900W. A few of the 470uF caps on the power board were oozing dielectric probably due to overheating. Hopefully the replacements will hang in there for a couple more years...
Posted on Dec 11, 2007
  • 45 Answers
SOURCE: Monitor Menu Settings
there is in the menu that calls for " RECALL ", press this to go to original setting, and change setting again to your choice, individually.
Posted on Oct 01, 2008
  • 62 Answers
SOURCE: hcl make monitor hcm780m have problem of displaying monitor basic hardware setting menu
1. change the control panel Micro switchs.
2. cheak the plastic panel
Posted on Nov 08, 2008
How to adjust the controls on asus ve206 monitor in order
Most of these settings are done through a software panel - check this site for your specific ASUS monitor :!downloads/c1wax
Jun 11, 2014 | ASUSTeK COMPUTER Asus 20" Lcd Monitor Mpn:...
Dear Anonymous,
This seems to be normal. When a monitor is not connected to a VGA or other source, it goes to test mode in some configuration. But if you can find the menu, setting or configuration button, there is a way to configure not to go to test mode. On my monitor there are only 4 buttons. But they are labled Menu, <>, Return.
The configuration for the modes is under monitor setting. This could vary from monitor to monitor. You should explore your equipment with a little help of noting down your way. The way I do is a notepad and pencil. I note down my action and follow back my steps if my requirement is not met or I did something very wrong.
Best of luck and let me know us know your results. This could help others with there troubles :).
May 19, 2014 | Dell Computers & Internet
Why my monitor screens is color green
Your RGB settings has most likely been altered, resulting in some problems. Check your settings menu on the monitor itself and reset the settings to default. If that is not the problem, it's probably the computer's settings that has caused this change. You will need to go to the computers monitor settings and reset that to default to get back to normal colours.
Nov 04, 2012 | Samsung SyncMaster 915N 19" Flat Panel LCD...
Ecs geforce6100sm-m motherboard video card problem
Well there is 2 scenarios, first one: pci-e port is not good, or is not making any contact with the pins of the GC; second one, GC is not working properly or you have a warranty to claim!
Jan 23, 2012 | Computers & Internet
@the monitor appearance changed to pink shade and we are not able to see in this colour pl give me a solution to sent it back to normal mode
probably the color setting of the monitor has been changed.
on the monitor panel press the menu button and go to the color option.
see if increasing or decreasing the RED GREEN and BLUE color options sets back the monitor to normal.
usually some monitors have a reset option also, by selecting it everything will get back to normal.
Aug 02, 2011 | Computers & Internet
I change the resolution of my packard bell netbook KAV60 and after that i shut it down and open it, and the screen is blank.. i can't see anything..
try connecting to an external monitor, you may have changd the screen resolution to an unsupported one. Use the ext. monitor to change it back to the lowest setting and go up from there.
Jan 18, 2010 | Packard Bell Easy One Silver 2101 Notebook
Blue lines on dell lap top inspiron
Check whether blue lines are present in bios screen, if Present then Hardware issue
If Blue line not present in bios screen, Software issue = Restore system back to factory settings
Connect External Monitor, use Fn + F8 to extend display on external Monitor ,
if display is fine on Ext Monitor = Replace LCD Kit
if Blue lines are displayed, on Ext Monitor = Replace Motherboard
Jan 09, 2010 | Dell Computers & Internet
Broken screen on laptop wont stay on external monitor when its on laptop monitor it still shows parcial screen of the desktop
Using Fn + F8 should go through 3 different positions: Laptop screen, Both screens, Ext Screen --- and back to Laptop screen, etc. This is set up in the computer's internal operating parameters and can not be changed.
Oct 01, 2009 | Toshiba Satellite M115-S3094 Notebook
I have a 7322gz gateway laptop.back lts work but nothing displaye
On most notebooks, switching between the internal display and the external display is done by pressing Fn+F4.
Aug 02, 2009 | Gateway 7322GZ Notebook
Adding multiple monitors from my HP pavilion
you have an ext monitor connection which you can use another monitor or get s-video lead and connect to a tv.
use fn + f4(or f key that has little square icon printed on it)
this combination switches from laptop screen to ext screen/tv
Jan 28, 2009 | HP Pavilion dv1000 Notebook
Computers & Internet Logo
Top Marshall Computers & Internet Experts
David Payne
David Payne
Are you a Marshall Computer and Internet Expert? Answer questions, earn points and help others
