Question about Olympus AS-4000 Desktop Digital Voice Recorder
Configuring folders I am having some problems configuring the network folder to which we would like to save voice files to. These files will then be accessed by another user who will transcribe.
  • shakra Aug 22, 2007
    several instances of the software were all using the same single user license number.
  • jackib Nov 30, 2007
    I have the same problem but do have seperate licenses for each user. My "Folder A" (which is connected to a network folder) has a red X in the upper right hand corner and is not accesible.
Right Click Folder A, then select Properties, then click on RESTORE DEFAULTS. That should remove that red X.
Posted on Apr 11, 2008
HP1020 problem with a livebox and WIN7 configuration
I found it somewhat difficult to completely Unshare files and folders on my HomeGroup Network and still allow Printer sharing in Windows 7 (Home Premium).
Initial UnSharing still allowed files like those below to be viewed on other home network computers:
C:/Users/
{user x} (folder)
AppData (folder)
Default (folder
Public (folder)
desktop.ini (file)
Other computers on the home network could step through many levels of hiarchy in the AppData folder and appeared to have "Delete" access!!
To completely decouple the computers, I had to go through the following several different Sharing/Unsharing assignment locations, till I could completely break the linkage.
I would appreciate any clarifications or simplifications.
File UnShare Confusion on HomeGroup Network
There are several different Network Sharing/Protection assignment locations in Windows 7.
To prevent all sharing between computers on the Homegroup Network, but allow Printer Sharing:
1) Start->Control Panel ->Network and Sharing Center->Choose Homegroup and sharing options.
Uncheck sharing boxes that you don't want to share. Save changes.
2) Start->Control Panel ->Network and Sharing Center->Choose Homegroup and sharing options->Change advanced sharing settings.
Click "Turn off Public folder sharing (people logged on to this computer can still access these folders)".
3) Start->Control Panel ->Network and Sharing Center->Choose Homegroup and sharing options->Change advanced sharing settings.
Choose Media streaming options.
Click "Block All" button. Turn off. Click OK.
Anomaly Note: You have to close Control Panel and repeat all step 3 again for the change to take effect.
4) Open Windows Explorer.
a) Select "C:/", select "Users" folder with single click, then click "Share with" in toolbar.
b) Select Advanced sharing.
Under Sharing tab, select Advanced Sharing. Uncheck box labeled "Share this folder". Apply and close.
5) Open Windows Explorer.
Select "C:/Users/", select all folders and files under "Users", then click "Share with" in toolbar, then click "Nobody".
6) Verify success by going to other home network computer(s) and trying to access your files and folders. You should only be able to see there is a computer and not be able to see any folders of files.
smooth printer service
Dec 16, 2012 | HP LaserJet 1020 Printer
Xerox scanning error 027-516:server connection error in smb
This means that your machine cannot connect to the network share to which it is supposed to write the scanned documents.
There may be several causes:
- if it worked before, perhaps the server or computer with shared folder to which the Xerox unit is configured to write files is unavailable/switched off, or the shared folder is not shared anymore or has changed security permissions, preventing the Xerox from writing, or the share name has changed
- if it never worked, perhaps the Xerox needs configuring prior to use (how it should deliver the faxes, via network share or email). Refer to it's manual on how to configure scan delivery.
Jul 24, 2011 | Computers & Internet
How to set up a wireless file transmitter(WFT-E4 II) to canon eos 5D mark II
Configuring communications settings in FTP mode1. Select [Address setting] with the camera's Quick Control Dial.
2. If you choose [Disable] for DNS server setting, enter IP address. For [Auto assign], enter server name. For [Manual setting], set up IP address.
3. Set up [Port No.] usually at 0021.
4. Configure [Proxy server].
5. Configure [Login method].
6. Set [Target folder] to [Root folder] or select folder using [Select folder] menu.
7. FTP server connection is established.
Note: Settings can be stored in the camera.
Configuring automatic image file transfer in FTP mode1. Select [Set up] in [WFT settings] menu.
2. Choose [Automatic transfer].
Configuring communications settings in PTP mode1. Select [OK] from Pairing screen.
2. Start WFT Pairing software on PC.
3. Double-click the icon inside PC task bar.
4. Select the WFT-E2/E2A/E3/E3A/E4/E4A [MAC address] you want from on-screen list of cameras.
5. Connection to camera is established.
Remote control of cameraOnce you start EOS Utility, you can control the camera remotely, using all available functions.
May 05, 2011 | Canon EOS 5D Mark II Digital Camera with...
How can i set up network file sharing
First step is to check if the file sharing option is checked in my computer folder options.
Start- My computer- TOOLS - FOLDER OPTIONS- and click on the second tab VIEW- scroll down to the last option which will show as USE SIMPLE FILE SHARING.
Level 1: My Documents (Private) loadTOCNode(3, 'moreinformation'); The owner of the file or folder has read and write permission to the file or folder. Nobody else may read or write to the folder or the files in it. All subfolders that are contained in a folder that is marked as private remain private unless you change the parent folder permissions.
If you are a Computer Administrator and create a user password for your account by using the User Accounts Control Panel tool, you are prompted to make your files and folder private.
Note The option to make a folder private (Level 1) is available only to a user account in its own My Documents folder.
To configure a folder and all the files in it to Level 1, follow these steps:
  1. Right-click the folder, and then click Sharing and Security.
  2. Select the Make this Folder Private check box, and then click OK.
Local NTFS Permissions:
  • Owner: Full Control
  • System: Full Control
Network Share Permissions:
  • Not Shared
Level 2 (Default): My Documents (Default) loadTOCNode(3, 'moreinformation'); The owner of the file or folder and local Computer Administrators have read and write permission to the file or folder. Nobody else may read or write to the folder or the files in it. This is the default setting for all the folders and files in each user's My Documents folder.
To configure a folder and all the files in it to Level 2, follow these steps:
  2. Make sure that both the Make this Folder Private and the Share this folder on the network check boxes are cleared, and then click OK.
  • Administrators: Full Control
  • Not Shared
Level 3: Files in shared documents available to local users loadTOCNode(3, 'moreinformation'); Files are shared with users who log on to the computer locally. Local Computer Administrators can read, write, and delete the files in the Shared Documents folder. Restricted Users can only read the files in the Shared Documents folder. In Windows XP Professional, Power Users may also read, write, or delete any files in the Shared Documents Folder. The Power Users group is available only in Windows XP Professional. Remote users cannot access folders or files at Level 3. To allow remote users to access files, you must share them out on the network (Level 4 or 5).
To configure a file or a folder and all the files in it to Level 3, start Microsoft Windows Explorer, and then copy or move the file or folder to the Shared Documents folder under My Computer.
  • Power Users: Change
  • Restricted Users: Read
  • Not Shared
Level 4: Shared on the Network (Read-Only) loadTOCNode(3, 'moreinformation'); Files are shared for everyone to read on the network. All local users, including the Guest account, can read the files. But they cannot modify the contents. Any user can read and change your files.
To configure a folder and all the files in it to Level 4, follow these steps:
  2. Click to select the Share this folder on the network check box
  3. Click to clear the Allow network users to change my files check box, and then click OK.
  • Everyone: Read
  • Everyone: Read
Level 5: Shared on the network (Read and Write) loadTOCNode(3, 'moreinformation'); This level is the most available and least secure access level. Any user (local or remote) can read, write, change, or delete a file in a folder shared at this access level. We recommend that this level be used only for a closed network that has a firewall configured. All local users including the Guest account can also read and modify the files.
To configure a folder and all the files in it to Level 5, follow these steps:
  2. Click to select the Share this folder on the network check box, and then click OK.
  • Everyone: Change
  • Everyone: Full Control
Note All NTFS permissions that refer to Everyone include the Guest account.
All the levels that this article describes are mutually exclusive. Private folders (Level 1) cannot be shared unless they are no longer private. Shared folders (Level 4 and 5) cannot be made private until they are unshared.
If you create a folder in the Shared Documents folder (Level 3), share it on the network, and then allow network users to change your files (Level 5), the permissions for Level 5 are effective for the folder, the files in that folder, and the subfolders. The other files and folders in the Shared Documents folder remain configured at Level 3.
Jul 20, 2010 | Microsoft Windows Vista Ultimate Edition
Olympus ds 40 can't display recorded voice folders on pc
There are a total of eight folders in the recorder that are in a tree format. Under the “Root” folder
are “Folder A” through “Folder E”, “Audible” and “Music” folders, and recorded or transferred
Language and music data from a computer can be saved as “files”. “Folder A” through “Folder E”
are voice-recording folders, so choose one of these five folders when recording on this recorder.
Up to 200 files can be saved in each folder, and up to two layers can be created within the “Music” folders.
Feb 14, 2010 | Olympus DS-40 Digital Voice Recorder
Configuring MC9090 default settings
Hi
When you set the wireless profile you set the SSID, WEP, IP etc. Which I'm sure you already know. Now you want to make them persist through either a cold boot or when the terminal has been left without a battery for a substantial amount of time.
This can be done 2 ways. When the profile has been set up highlight it by holding down the stylus on it and from the menu select export. This saves the registry key to the Application folder; a folder which persist through a cold boot. When it does cold boot it takes all the registry keys from the Application folder and builds 1 complete key.
The other way is to close the WLAN profile and selection options, from the pull down menu select export and save all profiles.
Hope this helps.
If you need any more help then please do not hesitate to contact us:-
http://www.biastechnology.com/
or TEL 01202 620955
Dec 08, 2009 | Symbol MC9090 Barcode Scanner
Copystar cs 305 scanner is not connecting to computer
I do not know much about the situation but, I'll give it a try. First turn the pwr off to the scanner and try to ping agian just to make sure you are not trying to use an ip adress that is aleady being used. You should not recieve a responce untill you turn the power back on but, if you do get a reponce while the scanner is off change the ip adress on the scanner. Next if that did not help, you will need a correct path to your computer from the scanner like example( \\server\public\scans ) next you will need a username and password to gain access to the shared folder..
Mar 30, 2009 | Copystar - CS-3035 Printer
File sharing
it is possible
If you have multiple computers in your home and they are connected through a home network, you can share files among your computers. That means you no longer have to copy files to a floppy disk or USB flash drive to transfer them to another computer. Once you configure your computer to share files, you (or another user with the appropriate permissions) can, by using Windows Explorer, open them from other computers connected to the network, just like you’d open files that are stored on a single computer. You can also choose to have folders visible—but not modifiable—from other computers on the network.
To share files on your computer with other computers on a network, you need to:
Share a folder on your computer. This will make all of the files in the folder available to all the computers on your network (you can’t share individual files).
Set up user accounts on your computer for everyone who needs to connect to your shared folder. If any of the accounts are Limited User accounts (unless an account is a Computer Administrator account, it is a Limited User account), follow the steps in Set permissions for files and folders to enable them to open your files.
To access shared files that are on another computer on your network, you need to:
• Connect to the shared folder from other computers on the network. This procedure is described in Map a network drive.
Note: By default, file permissions only allow your user account and administrators on your local computer to open your files, regardless of whether a person is sitting at your keyboard or at another computer. It may help to keep these three things in mind when setting up file sharing:
• Files have user permission settings.
• Every computer has its own user database.
• Some accounts are administrator accounts and some aren’t.
Configure your computer to share files To share a folder on your computer so that files stored in the folder can be accessed from other computers on your home network
1.
Log on to your computer as an administrator. For more information, see Access the administrator account from the Welcome screen.
2.
Click Start, and then click My Documents.
68599-click-my-documents.gif 3.
Right-click the folder that you want to share, and then click Sharing and Security.
68599-click-sharing-and-security.gificotip.gif Tip: If you want to share your entire My Documents folder, open My Documents, and then click the Up button on the toolbar. You can then select the My Documents folder.
4.
If you see a message that reads, As a security measure, Windows has disabled remote access to this computer, click the Network Setup Wizard link. Then follow the instructions in How to set up your computer for home networking. On the File and printer sharing page of the Network Setup Wizard, be sure to select Turn on file and printer sharing. If you do not see this message, skip this step and go to step 5.
68599-click-network-setup-wizard.gif Note: If you do not see the Network Setup Wizard link or the Share this folder on the network check box, your computer probably has Simple File Sharing disabled. This is a common change made to computers used for business. In fact, it happens automatically when a computer joins an Active Directory domain. You should follow these instructions to share a folder instead.
5.
In the Properties dialog box, select the Share this folder on the network check box.
68599-click-share-this-folder.gif 6.
If you want to be able to edit your files from any computer on your network (instead of just being able to open them without saving any changes), select the Allow network users to change my files check box.
68599-click-allow-network-users-to-change-my-files.gif 7.
Click OK.
68599-click-ok.gif Windows Explorer will show a hand holding the folder icon, indicating that the folder is now shared.
To connect to the shared folder from another computer, follow the steps described in How to map a network drive.
Note: By default, only you and other people with an administrator account on the computer sharing the folder will be able to open your files. To limit access of specific users with an administrator account on the computer sharing the folder, read How to set permissions for files and folders.
Aug 14, 2008 | Microsoft Windows XP Professional
Voice recorded
You can open the device thru My Computer.
My Computer>Device Name (c250)>RECORD Folder
Best of Luck.
Nov 01, 2007 | SanDisk Sansa c250 (2 GB) MP3 Player...
How to Assign Specific HDD space to individual shared folders?
What do you mean by "Specific hdd space"? Is this a partitioning problem or just a files and folders problem?
May 29, 2007 | LaCie Biggest F800 (300942U) 250 GB Hard...
Olympus AS-4000 Desktop Digital Voice Recorder Logo
55 people viewed this question
Top Olympus Audio Players & Recorders Experts
pankaj rautela
pankaj rautela
Are you an Olympus Audio Player and Recorder Expert? Answer questions, earn points and help others
