Cars & Trucks Logo
Posted on Mar 23, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How to reset service indicator on s 550 m.b., 2007
M.B. 2007 S 550, how to reset service indicator
Anonymous
Level 2:
New Friend:
  • Expert 41 Answers
  • Posted on Mar 23, 2009
Anonymous
Expert
Level 2:
New Friend:
Answers
41
Questions
0
Helped
19607
Points
156
You need a scan tool snap on motis or deler master tech to reset service light
How do you reset the B3 service reminder
Mercedes Service Indicator Reset C300 - YouTube
? 3:53
https://www.youtube.com/watch?v=2bLjAhIamyc
Jun 8, 2013 - Uploaded by Liqidarts
Easily reset your service A or service B indicator on you Mercedes Benz. Very useful if you do your own ...
Reset service indicator C300 C350 C63 Mercedes 2008 ...
? 1:47
https://www.youtube.com/watch?v=PdFLoZ1kNYI
May 23, 2012 - Uploaded by Liqidarts
How to reset service A or B indicators on your Mercedes C class, useful when you change your own oil.
How to reset maintenance service reminder without going to dealer ...
mbworld.org/.../473535-how-reset-maintenance-service-reminder-witho...
Reset x type 2.2d service indicator
hold the reset button on fascia, switch on ignition, release reset, press and hold button on end off indicator switch, repress reset button and hold, this should work it may not work if you have a diesel particulate filter fitted, because that has to be reset also so it can regenerate itself, in which case it has to be reset using suitable diagnostic equipment,
2answers
I replaced the battery and now the batt indicator light is on. do i have to have the dealer reset the computer to solve the problem
If this doesnt work theres a reset tool you can buy at most auto part stores $25-$40
    • 1 Turn your key to position 2 to power on the battery or turn the key all the way to start the engine on. Either option will allow you to reset the service indicator.
    • 2 Press either of the two buttons on the left side of your steering wheel featuring arrows pointing to the left and right to find the menu displaying the mileage. The menu options will appear on the screen underneath the speedometer.
    • 3 Press either the up or down arrow button until you see the service symbol displayed.
    • 4 Press the trip odometer reset button on the left side of the instrument panel for three seconds until the menu asks, "Do you want to reset the service interval? Confirm with the R-button."
    • 5 Press the trip odometer reset button again to complete the reset process.
Read more: How to Reset the Service Indicator on Mercedes ' eHow.com http://www.ehow.com/how_6954217_reset-service-indicator-mercedes.html#ixzz1Yp1Necb6
8helpful
2answers
How can I reset service light on 2008 Volvo V50
OTE: If the service interval indicator flashes it may be caused by one of the service interval indicator parameters not being programmed. This can only be carried out using suitable diagnostic equipment. Always check for any stored trouble codes as this may affect the resetting of the service interval indicator.
Ensure all doors are closed. Turn ignition key to position I. Press and hold reset button [A] 104667 07, 116126 07 Immediately turn ignition key to position II (within 2 seconds). Keep button [A] depressed until service message has been reset. A yellow warning light [B] will illuminate when it is time to release button [A]. Release reset button [A] within 4 seconds. There will be an audible signal when reset is complete. If reset button is not released within 4 seconds, the service interval indicator will not be reset.
RESET BUTTON IS TRIP BUTTON
Maintenance reset button, how to turn it off?
NOTE: If the service interval indicator flashes it may be caused by one of the service interval indicator parameters not being programmed. This can only be done with suitable diagnostic equipment. Always check for any stored trouble codes as this may affect the resetting of the service interval indicator.
Turn ignition key to position I. Press and hold reset button [A] 20573 for trip meter. Turn ignition key to position II. Keep button [A] depressed until service interval indicator flashes (approximately 10 seconds). Release reset button [A] within 5 seconds. There will be an audible signal when reset complete. If reset button is not released within 5 seconds, the service interval indicator will not be reset but will stop flashing.
3helpful
Reset the service indicator light - 06 Toyota Sequoia
set the mileage when the odometer is showing. put the key to off position. press and hold the reset button then turn the key to on position, do not start. then continue holding the reset button until the reading stops to zero or blank. turn it off, that should reset the light indicator
2helpful
2answers
How to clear a maintenance request message from a volvo 2006 S60
can you scroll down to the mileage indicator for the oil change and re-set it again to zero miles on the oil change.....just an idea
5helpful
2answers
Reset Service record after servicing peugeot 406 1999
hi there all u need to do is hold on reset button just under mileage clock with the ignition off,then switch on ignition to second turn and you will see mileage clock count down from 10 but keep button held in untill countdown finishes and thats it.
Top Mercedes-Benz Experts
ZJ Limited
ZJ Limited
xxxxxx xxx
Arnie Burke
Arnie Burke
Are you a Mercedes-Benz Expert? Answer questions, earn points and help others
