Question about Philips 20PT6441 20" TV
Philips 19pr14c225 19" tv NO Power
First Tv would not turn off then it turn off and now will not turn on. I notice for a couple of days that the picture would be distorted and it would take a while before the picture came in. Now no power. What could it be?
  • 54 Answers
Maam i think theres something wrong with its power supply,,kindly check it out thankss and hope to help you!!
Posted on Feb 27, 2008
SOURCE:
There is no power of my philips tv 26pfl4507, how will i do?
Ensure that the plug is inserted in the power socket and the switch is on. Turn on a table lamp or any other visible light near the TV. Then switch on/off the TV manually a couple of times from the control panel of the TV, giving a time-gap in between. If you notice the electric light flicker, and the TV makes a starting noise, the primary section of the TV is switching. If the LED is not glowing, there is a problem with the primary switching section, and might require attention by a qualified service technician. Also try this removing the batteries of the Remote. If it works, then the buttons on the remote are jammed!
Jul 11, 2012 | Televison & Video
I have a Philips 52PFL7422D/37 52" TV. For the last year now the TV will make a clicking sound like it is turning on but never does. After a couple of seconds to a minute the TV makes another...
I have the same model and the same problem... I am told the power display board is is the issue and may need to replacing. New board costs around $80,or a bad capacitor depending on your paitence.
Nov 23, 2010 | Philips 52PFL7422D/37 TV
Hissing sound from speakers and the picture turns off.
That model set was known for Chinese capacitors that failed, replace the power supply or look for bulged caps and replace them if your able to
Jan 06, 2018 | Philips 32MF231D Television
Philips 50pf3691d/37 won't turn on!!!
If you don't have any green lights anymore on the power supply PCB, replace it (part number LJ44-00118A, can be found on-line for approx $180).
Jun 10, 2009 | Philips 50PF9631D 50 in. HD-Ready Plasma...
Philips 42PF7220A/37 42" Plasma TV
After you remove the back cover inspect the power supply board for swollen or bulging capacitors. Pull and check any capacitors that you suspect to be swollen. Next, look for a sticker in the upper right hand side of the TV set. Use the values you find on the sticker to calibrate the voltages on the power supply board.
Feb 09, 2008 | Philips 42PF7220A 42 in. Plasma Television
Tv not powering on
as per your statement there is a loose contact in power supply section of your tv. it is 1oo% sure that allthe parts are ok as tv runs ok when it comes on. but you will have to call tech. as without knowing technology it is dangerous to open tv due to high voltage.
Sep 15, 2007 | RCA HD52W58 52" TV
Tv will not turn on after lightning storm
check IC location 7532, Diode locations: 6536, 6562 IET, Inc.
Aug 06, 2007 | Philips 32PT6441/37 32" TV
Hitachi 32HDL51 Problem
i had the same problem a couple day ago u have to just connect both cables connecing tv and the power box
Sep 17, 2006 | Hitachi 32HDL51 32 in. HD-Ready LCD...
Philips 20PT6441 20" TV Logo
132 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Steve Allison
Steve Allison
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
