Question about RCA 32V420T 32" TV
Rca 52 inch keeps shutting off and picture is curved
Today i turned on the tv and the picture is curved looking and it keeps shutting off.. we took off the back and cleaned all the dust and this did not fix it..Picture quality is still excellent but doesnt look right when its curved.. It almost acts like its surging when it shuts off then comes back off but the menu doesnt show up its just a black screen then goes back to the show and will be normal for awhile then goes back to being curved. This tv is only 3 years old..
  • cears Nov 03, 2008
    I have the same tv. The only thing it does wrong is trun itself off. No lines or anything. It just shuts off. What do I do now?
    Genius:
  • RCA Master
  • 1,691 Answers
The curved picture indicates failing parts in the pin amp section and probably some faulty parts in the scan amplifier sections. The set is being turned off by the uPC because there is a fault indicated, and it is going in to protect mode.
The set will have to be properly serviced.
Jerry G.
Posted on May 25, 2008
SOURCE:
My rca toshiba 50 inch projection tv is showing a 3d color curve
Need the model number to help as I am not sure of you have a RCA or a Toshiba
Dec 19, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
I own a 52 inch rca projection tv and last week
Most likely the Horizontal output transistor has shorted. When it shorts it causes the power supply to chirp. This is a common problem with this series of TV. Have a shop check it out. It should not be real expensive.
Oct 16, 2009 | RCA P52926 52" Rear Projection Television
RCA P52755BA 52 inch tv looks 3D
You have a problem with convergence and all you may need to do is replace a fuse. Look up convergence for your tv model and hopefully you will get an answer as to where the fuse is located and how to replace it. Very common for RCA tv's
Aug 30, 2009 | RCA P52926 52" Rear Projection Television
52 INCH RCA REAR PROJECTION SHUTS OFF
Your TV is overheating.. easiest remedy is to point a fan at the back of the TV or... clean the inside of the TV, Im sure its full of dust and stuff... this prevents air circulation inside the TV thus creating more heat...
Jun 19, 2009 | RCA HD52W56 52" Rear Projection HDTV
52 inch RCA - green light turns on & off, BUT no picture
CP150 is a capacitor in the power supply circuit....feel top to
see if flat....change if "pooched" or swollen..................T.
Apr 15, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Rca tv
I had this happen to mine and I had to have the high voltage transformer replaced. I took it all apart my self to save money and it only cost me about $285
Jan 14, 2008 | RCA P52926 52" Rear Projection Television
RCA 52" will power on but shuts down immediatley
plz get the picture tube ic's basically when green light mostly appears on the tv it is said that there is a roblem in tv ic's
Feb 28, 2007 | RCA D52W19 52" Rear Projection Television
RCA 32V420T 32" TV Logo
159 people viewed this question
Top RCA Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
