Question about Daewoo F227B Monitor
Daewoo monitor about two weeks ago my monitor's on and off switch started to flicker, and three days ago the monitor would not come on at all; please help.{I KNOW A LIITLE BIT ABOUT ELECTRONICS}
  • Anonymous Mar 22, 2014
    one week ago this problume happen with my monitor
    Scholar:
  • 76 Answers
If you know a little bit about electronics, then you can find or buy a multimeter to check the output voltage of the AC/DC power adapter (if it uses one, sometimes the converter/adapter is inside the monitor). In order to get a voltage reading from center "hole" of the end of the power cord, use a paper clip (thicker paper clip if you have it). If the converter voltage is good, then this monitor might be a warranty return candidate. Hope it's only a power adapter problem (you can find a replacement on Ebay) ZT3000 "Beta tester of "0"s and "1's"
Posted on Aug 21, 2007
SOURCE:
All lights flicker whan running it starts batt voltage is 13.43
What is battery voltage now with engine at idle and at 2,000 RPMs ?
Jun 17, 2018 | Cars & Trucks
How to install Dynex Monitors
Take it back for repair or replacement---new gear is sometimes bad.
Jun 17, 2012 | Televison & Video
Monitor often will not power up when power button is pushed. Disconnecting power for 90 seconds corrects problem. This is an intermittent problem that is occuring more frequently over time. Condition...
I think there is a problem in Monitor's Power Supply unit which integrated in the base board of Monitor. If u expertise with the service then carry on. else Pl contact a Local Service professional to solve the problem
Aug 23, 2009 | Computers & Internet
Turn the key but nothing happens all electrics
Not all replacement parts are good. I would guess that the new ignition switch is bad. Its also possible that the wiring harness is loose where its connected to the ignition switch. You could try jiggling the wires.
Jun 27, 2009 | 2006 Chrysler PT Cruiser
Hi, my monitor started to flicker 3times/second persistantly.
its the monitor its the main board may stuff up tomorrow may stuff up next week or in a years time hard to day as its only flickering take in for a check up
Apr 04, 2009 | LG FLATRON L1970HR LCD Monitor
Monitor flickers with changing colors making it almost impossible to see anything, it started & stopped for a while then after maybe three weeks after it started again ! I tried disconnecting & changing...
I suggest upgrading the OS on these problem terminals to the latest on the wyse website. It might be an incompatibility with the monitor and terminal (might have been fixed in later builds), in which case you will need to log it with Wyse directly, as they will need to test this.
Chances are though you either have a faulty monitor cable, a faulty unit, or faulty monitor. Perhaps even a combination of more than one of these above problems. Try to rule out each bit of hardware before blaming anything in particular.
Try a few different monitor resolutions, colour depth and refresh rates too. Cant hurt :)
Mar 31, 2009 | WYSE Winterm S30 Network Terminal
Dell E193FP Problem
Probably a failing power supply
Apr 17, 2017 | Dell E193FP 19" Flat Panel LCD Monitor
Can see screen for one second
I had mine for almost 3 years and last month ran into the same problem and i take good care of it. I turn it on it stays on for a 1-3 sec and goes black. can't figure out what it is
Apr 19, 2007 | Liquid Video L17LCD2 17" Flat Panel LCD...
Daewoo F227B Monitor Logo
155 people viewed this question
Top Daewoo Computers & Internet Experts
Ekse
Paul Bade
JonSnell Electronic
JonSnell Electronic
Are you a Daewoo Computer and Internet Expert? Answer questions, earn points and help others
