Question about RCA 20F420T 20" TV
FDA Lock The FDA lock is on and i think its affecting some keys on the remote such as the Input and menu key
  • 398 Answers
I have never heard of FDA lock. If you mean FPA lock, this is the Front Panel Access lock (also called Child Lock) built into the TV. To unlock FPA, turn the set on with the original remote, enter the menu, navigate to the page with FPA and set it to off.
Posted on Aug 21, 2007
    New Friend:
The fpa is locked and i dont have a remote...is there a way that i can fix this without the remote
Posted on Jun 16, 2010
    New Friend:
I have tried that. I have the same problem I bought an universal remote and it is not working. It will not let me access anything at all on my GT2011S model. I know the TV is old, but dang! It is a good TV and my husband is going to KILL me!
Posted on Nov 01, 2011
    New Friend:
Simple univ remote
Posted on Apr 10, 2011
SOURCE:
How can I unlock the function keys without the remote control?
Hi
How to Release the System Lock
Turn on the power. If the system lock is applied, the system-resetting screen appears. Press the following keys in this
order.
MENU ? ENTER ? ENTER ? MENU ? UNDO ? UNDO ? MENU
After pressing the MENU key first, press the remaining six keys within 10 seconds.
Mar 19, 2016 | Sharp Notevision PG-M20X Multimedia...
KEY LOCK ON
Key lock applies only on manual buttons on tv set try with another remote and go to menu and change the setting of key lock from on to off
Jul 15, 2014 | LG 42LG30 42 in. LCD HDTV
Technkia 32-630showing key lock how do i fix this
Press the Power key& Volume - key at the front panel of the TV simultaneously. For most Technica brand TVs, will be unlocked by this procedure. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy.
Unlock procedure to most popular brand TVs are given by one post.
Feb 06, 2014 | Televison & Video
When i turn on the video projector and send me this message"the panel keys are locked "
Your projector key panel locked you have two option to operate the projector
1 . Use remote control press MENU the menu window displayed.
use DOWN ARROW key and select SET SETTING.
press ENTER
use DOWN ARROW key to select PANEL KEY LOCK.
press RIGHT ARROW key to OFF the panel key lock
press ENTER and then press MENU key to exit the menu.
now you panel keys are working
2. If you loss your remote control then;
When the key panel lock is ON keeping the power key on the projector key panel pressed for 10 seconds turns the projector ON when it is in standby mode, and turns the projector to standby mode when the power is on. If you keep pressing the MENU key for about 10 seconds when the power is ON, the lock will be released and "panel key lock" is automatically set to OFF.
Feb 05, 2011 | Sony VPL-CS7 Multimedia Projector
Cant turn on set and remote wont work, how can I reset tv and remote to work after our grandchildren locked the fromt buttons ans remote?
hello it sound like the key lock has been activated
The TV can be set up so that it can only be operated with
the remote control.
This feature can be used to prevent unauthorized viewing.
This TV is programmed to remember which option it was
last set to even if you turn the TV off.
Press the MENU button on the remote
control, then use the UP/DOWN arrow
button to select the Special menu.
Press the RIGHT arrow button to activate
the Special menu.
Use the UP/DOWN arrow button to
choose Key lock, then press the RIGHT
arrow button.
Use the UP/DOWN arrow button to select
On or Off.
Press EXIT button to save and return to
TV viewing or press the MENU button to
save and return to the previous menu.
the remote control.
Language
Main Source
PIP Source
Captions
Caption/Text
ARC
Key lock G
Auto Convergence
Auto Move
F Back Next G
SETUP
VIIDEO
AUDIIO
TIIME
LOCK
SPECIIAL
On
Off
With the KEY LOCK ON, the display
'KEY LOCK' appears on the screen if
any button on the front panel is
pressed while viewing the TV.
which option it was last set to
even if you turn the TV off. good luck
regards
shaun
Dec 12, 2010 | Zenith R56W36 56" Rear Projection...
Keys mounted on projector got locked accidently
With System-Lock input window onscreen, press the "MENU", "ENTER", "ENTER", "MENU", "ENTER", "ENTER" and "MENU" keys, in this order,
on the remote controller.
Jun 17, 2009 | Sharp XR-30S Projector
Mitsubishi tv
I found this online somewhere and it cleared my problem.
(my problem was a blue screen that said my input was locked enter in your code using the 10 key pad. Both inputs were locked, I used the steps below and it cleared it. We are now watching a dvd for the first time in months!) Thank you Bob Waterman whoever you are!)
MITSUBISHI CS3114R
Parental Lock
This system can lock each channel or different channels on ANT A and ANT B
as well as locking each of the EXT inputs, so you should confirm what is
locked before trying to unlock.
1 On the remote, set the TV/VCR switch to the TV position
Or . Depending on which remote is being used
Press the TV mode button at the top.
2. Turn on the TV and using the SCAN buttons (or 10 KEY FAD) and the INPUT
buttons check each channel and input to establish which channels and inputs
are locked. The screen will tell you if the channel or input is locked.
3. Press the button labeled MENU. The screen will show the main TV menu.
4. Press the #5 button (channel lock option).
The screen will change to show the channel lock System Menu. This screen
will indicate that the lock system is either ON or OFF.
IF THE SCREEN INDICATES LOCK IS ON, GO TO STEP 5
OR:
IF THE SCREEN INDICATES THE LOCK IS OFF, GO TO STEP 5A
5. Press the #3 button. (SELECT CHANNELS TO LOCK option). The screen will
ask for the code number. Press the #9 and QV buttons at the same time.
Notes: The screen will change to show an information display that will show
the selected antenna and channel or input. The display is superimposed over
the picture. This display will indicate that the channel or input is either
locked or unlocked. In the lower middle will be instructions to use the
10-key pad or SCAN buttons to select the desired channels (or the INPUT
button to change antennas or select the EXT inputs). At the bottom of the
screen will be instructions on how to change the current LOCK status (if
unlocked use the ENTER button to lock, or if locked use the CANCEL button to
unlock).
NOW GO TO STEP #6.
5a. Press the #1 button (channel lock ON option). The screen will ask for a
code number. Use the 10-KEY PAD to enter a new code number (We suggest 1111)
and then press the ENTER button.
unlock).
NOW GO TO STEP #6.
6. Use the 10 KEY PAD or SCAN buttons to select the channels that are
locked, or, use the INPUT button to select the external inputs that are
locked.
7. At each locked channel or input press the CANCEL button.
The screen will indicate that the channel or input is either locked or
unlocked.
8. When all of the channels and/or inputs are unlocked, press the MENU
button again. TV main menu will be displayed.
9. Press the #5 button (CHANNEL LOCK option).
10. Press the #2 button (channel lock OFF option). The screen will now ask
for a code number again.
11. Press the #9 and QV buttons at the same time. The screen will return
to the CHANNEL LOCK MENU and indicate that the lock is OFF
12. Press the MENU button twice to return to normal viewing.
The parental lock is now entirely cancelled.
Bob Waterman, CET® #RI-28
Master Technician License #9109
Service Manager / Parts Manager
Gemini Computer, TV, & Security Alarms
(508)695-7302
(508)695-7769 FAX
[email protected]
[email protected]
www.geminicomputertvsecurityalarms.com
Nov 18, 2007 | Mitsubishi VS-5043 50" Rear Projection...
Mitsubishi tv
Without the code, you must get an original remote and press the "QV" and the "9" buttons together to unlock the TV.
Oct 16, 2007 | Televison & Video
Turn off child lock
To unlock the Panel Lock, Parent Lock, or Child Lock, follow these steps:
  1. Turn on your TV.
  2. On the remote, press the Menu button. The Set-Up Menu appears.
  3. Scroll to the Key Lock function and set function to Off.
  4. Press the Exit button to exit.
Note: If you don't have a remote, you may be able to do the same thing by pressing the Menu button on the front or side panel of your TV and using the volume or channel up and down buttons on the TV to scroll to the Key Lock function and set it to Off.
Oct 02, 2007 | Televison & Video
RCA 20F420T 20" TV Logo
1,163 people viewed this question
Top RCA Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
