Question about RCA TH1101 MP3 Player
Flash memory problems
I'm trying to add 2 GB of flash memory to a 1 GB MP3 and my computer isn't recognizing that there is more memory. It still says that I've only got 1 GB, yet the player says it has both. What do I do to get the computer to recognize the extra memory? And I don't have a card slot reader on my computer, so I can't try that.
When you add external memory(MicroSD), the computer recognizes it as a separate flash drive. If your MP3 player is F:, then MicroSD is G:.
Posted on Sep 19, 2007
When I put in extra 1 gig of memory on my 1 gig unit and then looked at it in my computer the extra memery showed up as another drive. I had 1 gig from the unit as 1 drive and on another drive I had another 1gig
Posted on Sep 18, 2007
SOURCE:
How do i reformat a data traveler kingston 2 gb usb flash drive? i tried formatting but it shows that it is Chipsbank usb flash drive with only 8 mb memory and then it wont complete formatting when i...
Are you positive there isn't a flash drive stuck in a USB port somewhere else on the computer? Very peculiar for the computer to be recognizing a completely different device.
May 18, 2011 | Electronics - Others
I'm using a 1gb sandisk sd memory card to sync mp3 song on it. THe mp3 songs go on it fine and play on the computer and on the mp3 player ok. The problem is I have about 533mb of space used and have about...
You may have reached the maximum number of files allowed in the root directory of the file system. If you already have a folder on the card, try moving some of the MP3 files into that folder. If you can copy 1 new MP3 file onto the card, that is your problem. Hopefully your MP3 player supports folders!
Oct 04, 2009 | Kingston 1GB Secure Digital Memory Card
Write protected flash memory
do you know its a problem occur
when device ejected harshly
try to plug it may solve your problem
or try this
go to my computer> properties>hardware > device manager >universal bus driver>right click on it> update driver>
then1
1.yes this time only> next 2.choose advanced option>next 3don't search i"ll update from........>next4.click on show campatible> next> next 5. now it updated then restart you computer
your problem will now soved
Oct 22, 2008 | iLO (2 GB) MP3 Player
Usb flash pen drive
Often it is due to electrostatic charges on usb. Unplug all USBs.Unplug PC from power cable for 10/15/ minutes. plug back computer to power outlet and restart. Plug back usb.
If it still does not work , flash memory may be faulty, test it on a different computer.
Mar 17, 2008 | Toshiba 1GB USB 2.0 High-Speed Flash Drive...
Won't turn on correctly-flashes on and off
My ilo will not turn on! I've tried changing the battery - but no luck.
Feb 20, 2008 | iLO (2 GB) MP3 Player
Flash Drives
Try to use a new Computer having Windows Vista, Dual core, 2 Gb RAM, and at least 160 Gb Hardware.
Your problem is solved.
He! Ha Ha Haa Haaa!
Jan 25, 2008 | Electronics - Others
USB Flash memory
i think your flash memory is damaged. Some times When you suddenly unplug your flash disk from USB this might happens. Due to this Operating system cannot read File allocation table from your Flash memory. Just connect with another Pc whether it can read the flash memory. if still fails. then your USB flash memory is damaged.
Dec 22, 2007 | Kingston (SDCZ2-512-A10-KT)...
Adding SD card to my ILO
What, you actually hotwired a flash card into the Ilo? Impressive. Or are you trying to get the Ilo to play music from an SD card, when you have both plugged into the computer? If you're talking about the first, then I'd say you did a good job at NOT destroying your Ilo. If its the second, then unplug your Ilo, put your headphones into the headphones jack in the computer, and play the music from your computer.
Aug 22, 2007 | iLO (2 GB) MP3 Player
Usb flash pen drive
i have bought kingston pen drive 8 GB..d problem is that files get corrupted...there r all sorts of different symbols instead of the actual file name...the space occupied by it also changes somehow....i tried formatting it but the problem persists.. i encountered same problem with my earlier SONY 4 GB PEN DRIVE(vaio)... please suggest some remedy..
Jul 12, 2007 | Lexar 64MB FLASH MEMORY DRIVE USB 2.0 -...
RCA TH1101 MP3 Player Logo
102 people viewed this question
Top RCA Audio Players & Recorders Experts
Ekse
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
