Question about Whirlpool 24 in. DU1100XTP Built-in Dishwasher
Water leak My model is a GU2400XTPB1 The tub of diswasher has small hole where a screw is mounted on bottom of dishwasher. Leak is severe during cycle. I have tried epoxy but it will only hold up for a few washes. Will anyhing seal the leak and hold up? The dishwasher is only 2 years old..
  • 1 more comment
  • goodbyer Jan 16, 2009
    I found that a metal brace underneath the tub is attached to four plastic posts extending from the tub. One of the end posts broke free from the tub and created the hole. After removing the brace....I have plugged the hole by using a 1/4" x 1" long stainless steel carriage bolt (with the square under the head cut down to the diameter of the threads, also I slotted the head with a hacksaw for a screwdriver), and two neoprene washers. I drilled a 1/4 inch hole thru the leak hole and pushed the carriage bolt thru with the neoprene washers on it from the inside. My wife held the carriage bolt from turning with the screwdriver with I put a stainless washer and nylock stainless nut on the underside. I had to lay the washer down on its side to do this. A large pan head stainless screw would probably work better, but that's all I could find at home depot that evening. Also a 3/4" long screw would probably be better, but the 1" carriage bolt I used was still short enough to permit reattachment of the brace over top of it.
    I do not have any further leak results yet, but will report back after testing. Not sure the impact of having only three screws holding the brace on?
  • lsecret May 11, 2010
    Someone from Whirlpool came out and fixed the recall problem about 3 years ago. It is leaking again!
  • Anonymous Mar 29, 2014
    During wash cycle dishwasher is leaking water on the floor
Mine also started leaking. Element also too hot. Mine has a 20 year warrenty on the tub (which I was NOT aware of) Repairman came today and the whole tub unit and element will be fixed for free! Look in your whirlpool instruction book to see if yours is warrentied. BTW, my dishwasher is only three years old.
Posted on May 03, 2008
I've had the exact same problem with our Kenmore Quiet Guard 3, which apparently was manufactured by Whirlpool. The small hole is even in the same spot as described in the Whirlpool service bulletin (figure 13):
http://www.servicematters.com/dm_safety/8178502a.pdf
I removed the four screws holding the metal bracket underneath, sealed the hole with silicon, and replaced the three screws that were still functional (the one was stuck in the plastic piece that had broken off.) So far so good... One week later and no leaks so far.
Chris
Posted on Nov 28, 2009
Just had a repairman look at my 2.5 year old Whirlpool for this exact same problem. The hole IS covered under warranty BUT labor is not. The rate they charge is $100/hr and he said it would likely take all of that if not more. The reorder of this part would take 7 10 days and will cost upwards of $200 so you have to ask yourself is it worth it to spend 150-200 on a 3 year old dishwasher or go buy a new one (same model) for $400.
Posted on Jun 16, 2008
Yes, the loctite has worked for me!
Posted on Mar 06, 2008
I have the same model Whirlpool dishwasher with the exact same water leak problem -- a small hole in the tub bottom, under the element, and directly above a screw on the tub underside. Scanning the web, I discovered a recall titled "Whirlpool & Inglis Plastic Tall-Tub Didhwasher Heater Rework #R17365" which shows that our dishwashers should have a round element instead of an angular one and, somhow, a small hole can occur due to this wrong element. See Figure 13 of the recall. This repair will be covered free of charge by Whirpool.
Posted on Sep 21, 2007
  • 641 Answers
Try the Loctite N27 steel quickest. Good luck!
Posted on Aug 22, 2007
I have the same hole problem on my 3 y/o Kenmore washer. What a crappy design flaw! I am ready to try any epoxy before I have to throw out an expensive dishwasher.
Any success stories with epoxy or heat resistant rubberized compounds...?
I have no way to connect to the granite counter top. Can it be mounted to the side cabinets?
Need prefix for model number. Need complete model number. I believe that the numbers that you have given are stock numbers from your user manual. Kenmore can be several different manufacturers. Some brands have kits to mount unit from the sides using brackets at the top. If stainless steel tub, look for removable plastic caps on the right and left sides of unit. These holes would be used for installing bolts into cabinet. If plastic tub and no kits are available holes can be drilled into sides to secure unit to cabinet. As long as heads of bolts(screws) are flush to allow door closing, unit will not leak because of tub(door gasket.
Feb 15, 2011 | Kenmore 24 in. 17482 / 17484 / 17489...
My water will not dain in my diswasher and then leaks on to the floor. Is there a clog oris it something else
Hi
If your dishwasher leaks, check these:
Main tub seal Note… If the main motor of your dishwasher is mounted vertically, beneath the center bottom of the dishwasher, the following instructions probably apply to you. But if your motor is mounted horizontally, the pump isn't serviceable--you need to replace the entire pump and motor assembly.
The main tub seal is beneath the drain impeller. It prevents the water in the dishwasher from leaking out near the shaft of the motor. To get to the seal, which is inside the dishwasher, remove the:
  • Lower rack
  • Spray arm
  • Spray arm support
  • Wash/drain impellers
Then pry the seal out of its housing and replace it.
Door gasket or seal Over time, door gaskets and seals harden and lose their ability to seal properly. You can't repair the seals. You need to replace them if they've begun to leak.
Water-inlet valve The water-inlet valve, itself, seldom leaks. But, the water-supply line from the house and the rubber tube leading from the valve to the inside of the dishwasher may leak. Tighten or repair/replace these as necessary.
The water-inlet valve could mechanically stick open. When that happens, the water continues to flow into the dishwasher, which then floods your kitchen. Turn off the water supply to the dishwasher, and replace the valve.
Hoses Behind the lower access panel on your dishwasher are several rubber or plastic hoses. If the leak appears at a connection, try a new clamp. If that doesn't work, replace the hose.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Aug 08, 2009 | Magic Chef Dishwashers
Water leaks out of bottom of washer
The screw in the washer tub, is not a factor in this. I'm not sure what brand of machine you have, but several machines have a fill hose that connects to the outer tub of the machine. Sometimes when a machine gets loaded heavily, during the spin cycle items in the machine can actually knock the fill hose right out of the tub. Then when the machine trys to fill the next time, all the water runs down the outside of the tub and leaks out of the bottom of the machine.
Repair is to open up the machine. You'll need to remove the top cover and that will give you access to the hose/tub connection. It may be as simple as reinserting the hose back into the drum or you may need to replace it if it got too damaged and won't stay in the hole correctly.
If you need specific how to's on opening up the machine, get back to us with the make and model info and we'll be happy to help you open that washer up!
K
Aug 01, 2009 | GE Washing Machines
I have a twenty year old Maytag washing machine that is leaking water out of the bottom of the machine. I have checked the hoses and it is not coming from there. Any ideas
hello. i can help you. unfortunately, your problem has numerous possible causes.
Your washer can develop several types of leaks. You can track down a leak based on when it occurs:
During fill only
During drain and spin only
All the time
During fill only If the washer leaks only during the fill cycle, check these:
  • Air-gap device -The air gap is a small device found on most washers that prevents the wash water from being siphoned into the household water supply. It's located either mid-way along or at the end of the black rubber hose that comes from the water-inlet valve. Often it's made of translucent plastic. If one of the air-gap components deforms or cracks, you may need to replace it.
  • The tube -There's a rubber tube that runs between the water-inlet valve and either the air-gap or the inlet spout. If it cracks or breaks, it can cause a leak.
  • Inlet spout -Most washers have a plastic spout near the top of the main clothes tub that directs the water into the tub. If the spout cracks or breaks free of its mounting, it can cause a leak.
During drain and spin only A washer that leaks only during the spin cycle often has a leak in the main drain hose. Inspect the entire hose and correct any problem you find. Alternatively, the steel or plastic outer tubs can rust, split, or be punctured. This may be most visible during large loads and high water levels. If this happens, you may have to replace the entire outer tub--but that may not be an economical repair to make. Consult a qualified appliance repair technician for further details.
All the time If the washer leaks all the time, check these:
  • Hot and cold water fill hoses - Check the hot and cold water hoses from the household plumbing. If either hose is leaking, tighten it or replace it, as appropriate.
  • Main tub seal - The main tub seal is located between the transmission and the outer tub. It's the primary water seal in the outer tub for the transmission-shaft entry point. If this seal leaks, you can see the leak by opening up the machine's main access panel while the machine is full of water with a small amount of detergent in it. The leak appears at the underside of the outer tub, at or near the center. This seal is difficult to replace. You probably should call a qualified appliance repair technician.
  • Pump - If the pump leaks, you can probably spot the leak when the tub is full of water. The pump has two or more black rubber or plastic hoses attached to it and usually has a drive belt that spins the pump. If the pump is leaking, you need to replace it.
  • Outer tub - Over time, the steel or plastic outer tubs can rust, split, or be punctured. If this happens, you may have to replace the entire outer tub--but that may not be an economical repair to make. Consult a qualified appliance repair technician for further details.
Jul 02, 2009 | Washing Machines
Brand new dishwasher installed and water leaks out bottom of door
Main tub seal
Door gasket or seal
Water-inlet valve
Hoses
Main tub seal Note…If the main motor of your dishwasher is mounted vertically, beneath thecenter bottom of the dishwasher, the following instructions probablyapply to you. But if your motor is mounted horizontally, the pump isn'tserviceable--you need to replace the entire pump and motor assembly.
Themain tub seal is beneath the drain impeller. It prevents the water inthe dishwasher from leaking out near the shaft of the motor. To get tothe seal, which is inside the dishwasher, remove the:
  • Lower rack
  • Spray arm
  • Spray arm support
Door gasket or seal Overtime, door gaskets and seals harden and lose their ability to sealproperly. You can't repair the seals. You need to replace them ifthey've begun to leak.
Water-inlet valve Thewater-inlet valve, itself, seldom leaks. But, the water-supply linefrom the house and the rubber tube leading from the valve to the insideof the dishwasher may leak. Tighten or repair/replace these asnecessary.
The water-inlet valve could mechanically stick open.When that happens, the water continues to flow into the dishwasher,which then floods your kitchen. Turn off the water supply to thedishwasher, and replace the valve.
Hoses Behindthe lower access panel on your dishwasher are several rubber or plastichoses. If the leak appears at a connection, try a new clamp. If thatdoesn't work, replace the hose.
Dec 04, 2008 | Maytag 24 in. MDB8600AW Jetclean II...
Water leaking from bottom of front lode washing machine
It leaksYour washer can develop several types of leaks. You can track down a leak based on when it occurs:
During fill only
All the time
During fill only
All the time
Dec 01, 2008 | Frigidaire FTF530FS Front Load Washer
Leaking washing machine
During fill only
All the time
During fill only
All the time
Nov 12, 2008 | Danby DDW1805W Designer Series...
Dishwasher Leaking
hi there,
dishwasher leaking might be due to either of these causes, check these:
Main tub seal
remove the:
* Lower rack
*Spray arm
* Spray arm support
* Wash/drain impellers
Then try the seal out of its housing and replace it.
Door gasket or seal
Water-inlet valve
Hoses
Aug 27, 2008 | Kenmore 16602 / 16604 / 16609 Built-in...
Leaking water
hi there,
Main tub seal
remove the:
* Lower rack
*Spray arm
* Spray arm support
Door gasket or seal
Water-inlet valve
Hoses
Jun 30, 2008 | GE GSD1180X Dishwasher
Whirlpool 24 in. DU1100XTP Built-in Dishwasher Logo
2,812 people viewed this question
Top Whirlpool Dishwashers Experts
Mike
Archie Ferrarini
Archie Ferrarini
Smitty
Level 1 Expert
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
