Question about iRiver E10 Digital Media Player
IRiver E10 Player update required
My E10 doesn't work - i reset it 100 times a day - just black screen and "Player update required". If I connect the USB - "Emergency USB v1.40" - my computer even can't find it.
  • Anonymous Dec 19, 2007
    Player won't turn on or off, it's just stuck with a black screen and white writing which says:
    "Player update required!!! Please refer to the manual" It has "v1.40"' in the bottom right hand corner of the screen as well.
    I checked the manual and tried to 'initialise' the player like it said and that didn't work .. when I connected it to my computer a new message came up saying "Emergency USB" and the "v1.40" was still in the bottom right hand corner ...
    I tried charging it in case the battery was flat or something but that didn't work ..
I took mine to JB Hi-Fi where I bought it from and they're sending it to the service centre for me ... if your 1 year standard warranty hasn't expired you can take it to the place you bought it from and they can ship it off for you and they log all your details and give you a number so you can call and check the status of the repairs ... that's the only thing that will solve the problem as far as I'm aware ... they need to actually replace parts in the iriver ...
Posted on Dec 23, 2007
    New Friend:
Hi my e10 irivera mp3 says player update required what should i do
Posted on Mar 17, 2011
Im having same problem!!! i need help!
[email protected]
if you have any answers <3
Posted on Dec 22, 2007
SOURCE:
How to fix iriver E10 it says on the screen is emergency usb
  1. If your PC does recognize the iRiver as a USB device/drive, there is an issue with the Hard Drive.
  2. If your computer doesn't recognize the iRiver as a USB device/drive and can read the files, there is an issue with the Circuitry in your e10.
  3. Turn the lock off and connect it to the usb port and press the reset button (small hole in lower left of unit, use a small object like a paperclip. The screen should change eventually to the "USB connected" screen. Disconnect the USB at the PC to get the "Ok to disconnect" message. Pull out the usb cable and hold down the "off" button. Eventually the unit will turn off. Turn it on and then off to verify it is working.
If nothing works, your iRiver needs to be returned to the manufacturer.
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
Feb 22, 2011 | iRiver E10 Digital Media Player
Emergency usb mode
Have you tried connecting the usb and loading an update on it at all?
Let me know if you have or if trying that doesn't work and if it doesn't then I will provide further help based on the situation
Thank you for using Fixya and Good Luck
Apr 21, 2008 | iRiver E10 Digital Media Player
Not possible actualization firmware E10
Device may require on-line firmware upgrade. Try updating firmware while connected to Internet.
Jul 15, 2009 | iRiver E10 Digital Media Player
Downloading videos onto the iriver E100
Software / Media Transfer The E100 comes packaged with a disc containing iriver plus 3 media player, firmware updater, video converter, and Windows Media Player 11. If you have owned an iriver player, you are familiar with this software with the included iriver media player. This is a standard media player much like any other but has a few features catering to the iriver family of players, such as a firmware updater, ebook txt manager, and video converter. This media player is a bit different from Windows Media Player but still is straightforward and easy to use. If you don’t care for iriver’s media player you can always use any other MTP based media player to manage playlists and load your E100 since also included on the disc is a video converter and firmware updating utility.
If you don’t like to use media players to transfer the E100 will allow you to select either MTP or MSC transfer mode. This means it is drag and drop and also compatible with any OS. Drag and drop will work fine in MTP mode as well, but only if you are using Windows XP SP2 or Vista.
and the difference between e10 / e100 your guess is just as good as mine
Sep 22, 2008 | iRiver E10 Digital Media Player
E10 Blackscreen
Looks lo\ike the OS crashed in the player. It is probably asking for a restore procedure. It is located on the CD or in the setup program that came wiht the Iriver.
Mar 09, 2008 | iRiver E10 Digital Media Player
Repair
update your iriver plus program. then in the tools menu there should be a firmware update button.
moz-screenshot.jpgmoz-screenshot-1.jpgi think it is in the tools dropdown submenu. try that.
Jan 19, 2008 | iRiver E10 Digital Media Player
E10 Problem
You need to upgrade the firmware by using iriver plus 3 in the 'tools' section it should have upgrade firmware.
Nov 13, 2007 | iRiver E10 Digital Media Player
Iriver plus software closes down when I plug in my iriver E10 to the computer
Using Explorer try copying one song over into the music folder of the device. Then restart Plus so that it searches and finds a song present.
Sep 13, 2007 | iRiver E10 Digital Media Player
IRiver E10 - Error screen - Emergency USB
Hi There,
There are 2 conditions related to the e10 Emergency USB message.
1. If your PC does NOT recognise the iriver as a USB device/drive, there is an issue with the Hard Drive.
2. If your PC DOES recognise the iriver as a USB device/drive and can read the files, there is an issue with the Circuitry in your e10.
In either case, your iriver needs to be returned to the manufacturer. If in warranty you can get this repaired at no cost (of course).
Sep 06, 2007 | iRiver E10 Digital Media Player
iRiver E10 Digital Media Player Logo
872 people viewed this question
Top iRiver Audio Players & Recorders Experts
Steven Wander
Steven Wander
Ekse
Peter Dragonetti
Are you an iRiver Audio Player and Recorder Expert? Answer questions, earn points and help others
