Question about Hitachi 61SDX01B 61" Rear Projection Television
Picture blanks out
This has been happening more frequently lately: The sound and picture goes out for a short period of time. Also sometimes when the TV is started there is no sound, the only way to remedy this is to cycle power from the outlet.
  • jpf1715 Nov 06, 2008
    Same thing here as well. No audio when I first turn on the set, then sometimes have intermittent picture on different video input channels.
    Novelist:
    Scholar:
  • 149 Answers
Check your powercord. Unplug it overnight, then plug the power cord back in the morning. If that doesnt help, it means that something is going on with your set. Sometimes your power cord has shorted out and needs to be replaced. Generally you can find them under $100 depending upon your set...
Posted on Sep 27, 2007
SOURCE:
TV loses picture
Sounds like your picture tube or bulb is going out. It depends on what kind of tv ( rp, lcd, plasma) it could also be a component issue.
Nov 22, 2013 | Televison & Video
I have a Westinghouse SK-32H240S 32" flat screen
First when tapping changes the picture you have somewhere a bad connection; in electrical board or wiring.
When the screen goes blank after a while means some capacitor is bad/old.
Mar 13, 2011 | Westinghouse SK-32H240S Television
Looking to buy a Samsung HP-S5073 Plasma, and the owner says that the screen goes blank sometimes. (But the sound still works while the screen is blank). This could happen for 5 minutes or an hour. Then it...
There is a possibility that this comes from poor signal quality. Re-booting the television may stop this behavior for a period of time, but if the problem is not corrected, it will return.
There could also be an internal problem with the television.
(Personally, I would look to buy something else.)
Hope this helps!
Jun 17, 2010 | Samsung HP-S5073 50 in. Plasma HDTV
Samsung HP-4252 screen goes black
I have the same problem, and it will get worse. I have read and seen video on youtube, stating that it is capacitors on the power board, that need to be replaced. I watched the tutorial video it seems pretty easy, I am going to try it this weekend. Will update.
Jun 02, 2010 | Samsung HP-R4252 42 in. Plasma HDTV
TV freezes for a short period of time.
First a couple of questions:
1) What is the make and model please?
2) When the picture freezes, is it like a snapshot photo? or does the screen blank?
This sounds like an interruption in the digital data stream. If the picture remains on the screen, the "new" frame information is not being received nor processed. This can be as simple as a bad cable connection or noise on the digital information data lines.
Check to see if there is any pattern to when this occurs. For example, does it happen more frequently after the set has been on for a while? Try cooling down the set to see if temp effects the behavior.
Please update this and we'll work to resolve it.
Thanks,
Dan
Mar 16, 2009 | Televison & Video
TV SREEN GOES BLANK, BUT AUDIO CONTINUES NORMAL,
Try unplugging for 36 hours. I had the same problem but with no sound and picture
Mar 03, 2009 | Sony KP-53HS10 TV
Picture fades to black when it goes to commercial
The sleep timer may be set to fade and a short time span.
Feb 08, 2009 | Sony FD Trinitron WEGA KV-36FS120 36" TV
No picture but has sound
My LG TV
switch on no picture but short period of sound then nothing
Jan 20, 2008 | Sony KP-51HW40 51" Rear Projection...
Sound but no picture - intermittant
I have lost video as well. I am probably taking mine in to the shop. What is the source of video? Does it matter? What are the connections for those sources? Component? S-Video? Any pattern there... Wish I had more info for you.
Dec 29, 2006 | Denon AVR-1804 Receiver
No picture
You have an intermittant vertical sweep circuit! It could be the vertical out put IC solder connections on the printed circuit board, or maybe the IC itself has poor connections between the IC and the contact legs that mount the IC, or another componet in the vertical sweep circuit. If you know how to solder and unsolder, work on printed circuit boards, then you shoul have no problem replacing the vertical sweep circuit. Good Luck
Oct 09, 2006 | Panasonic CT-25G6 25" TV
Hitachi 61SDX01B 61" Rear Projection Television Logo
Top Hitachi Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
