Question about Liebherr KGBN 3846 Premium BioFresh Bottom Freezer Refrigerator
Thermometer I just got a brand new Liebherr SC1301. It worked OK for a few hours. Then the temperature on a thermostat started going up for a freezer while it looked like freezer was working OK (thermostat showed 35 F while water was easyly freezing inside.)
  • 291 Answers
YOu have to be more clear on the post it dont make much since, also if its brand new should be under warranty
Posted on Aug 21, 2007
My fridge keeps freezing everything what is the best temp to have it set at. It is an aurora model RB411M3
I recommend moving the thermostat to the exact center position, unplug, then plug in the refrigerator. Wait 24 hours for the fridge thermostat to reset and to thaw automatically. Then, I recommend a fridge thermometer, available at most grocers or kitchen supply stores. If you can't find one, use a digital thermometer with a probe. Place the thermometer hanging from the center of the center shelf. Keep the refrigerator temperature at or below 40° F (4° C). The freezer temperature should be 0° F (-18° C). Allow 24 hours for any thermostat changes.
Apr 08, 2017 | Refrigerators
AFTER FEW POWER OUTAGES, FREEZER TEMPERATURE KEEPS BOUNSING BETWEEN 5 AND 20 DEGREES, REFRIGIRATOR SEEMS TO WORKING FINE AND KEEPS TEMPERATURE.
Check the cabinet temperature with an independent thermometer. If it is does keep a stable temperature the problem would probably be electronic.
A power outage is often accompanied by a voltage surge. Sensitive electronics and computers can be damaged by a voltage surge. People are used to protecting personal computers with surge protectors but fail to realise these days almost everything is a computer or contains a computer. Radios and tv sets are computers and so are cars and even the humble toaster these days has some computing power.
Today almost everything but the cheapest of appliances should be protected. A minimum surge protection can be obtained by using an area surge protector.
Aug 18, 2016 | Liebherr Refrigerators
Why is my food freezing
If you did not put it in a freezer, but in the fridge, you have two options. The best option, because you can change it, is you did put the thermostat on a too low temperature. The other, needs repair is when the thermostat is defect, so it does not react when the temperature you selected is reached. Try to change the setting of your thermostat and buy a cheap thermometer, to monitor the temperature. There are old school min max thermometers, and new digital ones, but just a cheap other thermometer will work. You only have to look more often on the cheaper one.
Your fridge is only allowed to have a variation of a few degrees, when working.
If it is working from +1 Celcius to -2 the thermostat is working, but at least 5 degrees too low. normal would be from 5 to 7. (I don't know what it is in Farenheid, but must be around 40.
Jun 23, 2014 | Maytag MSD2554VE (250 cu ft) Side by Side...
Food is starting to spoil more quickly than it should. The refrig temp on the door is set at 34 degrees which is the lowest it will go. The temp. on the refrig thermometer says it is 60 degrees. What...
You can get a small digital thermometer at your local hardware store for a pittance. ... For most refrigerators, this temperature coincides with the lowestsetting or one of the ... If your refrigerator is really full with items, lower the temperature a bit. ... they're not going to go bad because they were at 41degrees for a few hours.
Sep 12, 2013 | Samsung RF267AE (25.8 cu. ft.) Bottom...
Cooler wavers between 35 and 45 degrees.....even after turning the controls to colder. Would this be the thermostat?
Probably... OK I am going to fill you in on something here that almost no one knows. The True coolers all use a thermostat that reads the coil temperature and has no idea what the box air temperature might be. They are all pretty much the same but have a few different variations. For most beverage coolers though they are getting the coil down to around 13-15 degrees and then shut off and stay off until the coil gets back up to 38-40 degrees.This means that the air temperature can be anywhere from 23 to 50 degrees at any given moment but the product temperature is going to average out in the middle. If the box is full no problem the temperature swing will not be anything like this because the product will keep the temperature more stable. If the box is empty you will need to put SOMETHING in there to help stabilize the temperature before panicking. 3 or 4 gallons of water will do. Also if you want to sleep better at night put a thermometer in a glass of water in the cooler to get a better idea what your product temperature really is and don't put too much faith in the cheap dial thermometer mounted to the outside of the box. Oh and set the dial on 5 and if that doesn't work the thermostat could be a problem... they are the weak link in these units.
Aug 28, 2013 | True T23 Refrigerator
What shld settings be as food is freezing in fridge it has side by side knobs saying colder mid less cold it is a westinghouse fan forced frost free freestyle unit
The settings are "relative". Someone with this fridge in Montana may need to run the same fridge with different settings than someone in Texas to get the same temperatures.
Many manufacturers recommend that the fresh food compartment should be 34 degrees F, and the freezer -10 to 0 degrees F. To set this properly, place a thermometer in the freezer (that can display temperatures as low as the desired temperature). Adjust the thermometer for the correct freezer temperature before going on to the fridge. A fully stocked freezer could take 12 hours or more for temperatures to stabilize after making changes to the thermostat. Once the -10 to 0 degree temperature has been achieved, set the fresh food compartment temperature.
Place a thermometer (that can display below freezing) in a 6 (or so) oz flexible plastic cup of water and place on a shelf in the fridge. A glass of water could break if the temperature gets below 32 degrees if the water turns to ice. The water acts as a buffer to rapidly changing temperatures when the door is opened to read the thermometer. If the fridge is "full", allow 24 hours for the temperature to stabilize before making changes.
If the fridge and freezer are empty, changes may be seen in just a few hours or less. Otherwise, wait the 12 / 24 hours for the freezer / fridge compartments.
I hope this helps and good luck!
Sep 06, 2011 | Freezers
Overheating, and it is not the thermostat. Is this a common problem?
Water pump?
I have had bad thermostats brand new out of the box. Before I put in a "new" thermostat, I put it in a pot with a few cups of water in it. Heat water to opening temp. (ie. 160) degrees using a bakers thermometer. Make sure the stat is opening at, or close to this temperature. Next step is to determine if your waterpump is working. You can look up how to do this or bring it to a reputable shop.
Nov 27, 2009 | 1993 GMC Sierra
The thermometer turns red when i turn on my car, it's normally blue.. what does that mean
That's totally normal, that's just the sensors in you car making their self tests while starting the engine to ensure that they are working ok. It's just testing that the coolant temperature warning system if working ok, hence the red thermometer appearing. After that all the systems go back to normal and give you their true readings, and that's why it goes to blue, which means the engine is cold and just started. After a while when the engine heats up normally and has run for a few minutes, the thermometer should disappear completely. My 2005 toyota echo does exactly the same thing, and so do many newer vehicules. So nothing to worry about, it just means everything on that system is working fine and like it should.:)
Jul 08, 2009 | 2003 Volkswagen New Beetle Convertible
98 328IS OVERHEATING AFTER CHANGING THERMOSTAT
Are you putting the thermostat in correctly? It it will not work backwards.
And to confirm that there isn't a different problem, take the thermostat out all together and see if it overheats.
Engine not fully warming up is not usually caused by the thermostat. Stats usually fail closed, not open.
You will want to check the water temperature sending unit or gauge after verify the water temperature with an external calibrated thermometer. You can attach and insulate the external thermometer to the housing where thermostat is located.
Reply back what you figure out. I will be happy to help you further.
Feb 03, 2009 | 1997 BMW 328
Uline 75R refridgerator stopped working
Sounds like you did everything right
Jan 24, 2009 | U-Line 75R Refrigerator
Liebherr KGBN 3846 Premium BioFresh Bottom Freezer Refrigerator Logo
475 people viewed this question
Top Liebherr Refrigerators Experts
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Liebherr Refrigerator Expert? Answer questions, earn points and help others
