Question about Pioneer PRO-200 60" Rear Projection Television
Pioneer pro-119 just replaced the power assembly/deflection board (for the second time in 2 years) and now I am getting a green somewhat thick line down the middle.
  • ls0985 Jan 30, 2008
    i have a PRO 200 and every 30 minutes it zaps and goes off, when I turn the power button back on it starts working fine again
  • 39 Answers
JDM-RECHECK ALL CONNECTIONS ON POWER/DEF PCB AND ALSO TAP AROUND FLYBACK TO TEST FOR POOR SOLDER JOINTS.CENTER LINES USUALLY INDICATE IMPROPER HORIZONTAL CIRCUIT OPERATION.IF ALL ELSE FAILS RE-REPLACE SAME BD. JOE TV
Posted on Nov 27, 2007
SOURCE:
Have a Pioneer pro elite 730hdi. When you try to turn it on (main power, not standby), the tv cycles from the red (standby) light with the normal click to the green light, then one second later, it cycles...
Your power supply board is dead, u know basic electronics' and soldering? Most of the times, the power supply board just have dead leakages gases capacitors.These capacitors always bulges up on it top,or puff up on it top.Replaced these gases leakages capacitors will get your TV power stable,and work again.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Hoping this will help in solving the problem....
Aug 09, 2011 | Pioneer PRO-730HDi 64 in. Rear Projection...
When you push the main power button on and the standby button it turns green for 2 seconds then turns right back to red what's going on???
1 or 2 things, Blowed Fuse on the Deflection power supply board
6.3 amps will be located in the Middle of chassis.
STK ICs need to be replaced STK392-110 use 120s
Mats Electronics has them 1-800-628-1118
Oct 31, 2010 | Pioneer PRO-700HD 64" Rear Projection...
Pioneer Elite. Loud popping sound and picture disappeared
Power supply board is dead.The board where the power a/c cord plug into it.Replace the power supply board.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
May 30, 2010 | Pioneer Elite PRO-1140HD 50 in. Plasma...
Just got a pioneer elite pro 119 from a buddy of
If you don't mind opening the thing, open it up and follow the power lead inside the TV. Somewhere along the line should be a fuse. I'd start there.
Oct 06, 2009 | Pioneer PRO-119 60" Rear Projection...
Tony Fidaleo's Pioneer PRO-700HD
Once I look at the schematic diagram, I might be able to know the part that is blowing that fuse.
Jul 28, 2008 | Pioneer PRO-700HD 64" Rear Projection...
Pioneer PRO-119 - Mini Burst . . . Then Nothing
Pioneers are fairly easy to troubleshoot. However if he solderd and that fixed it, is the set doing the same symptom as before he solderd it? I would recomend getting the service manual for the set and troubleshoot the start up voltage circuits. Let me know if you would like a link where to get a service manual
Mar 11, 2008 | Pioneer PRO-119 60" Rear Projection...
Replacing power board on pioneer pro 200 elite
364.00 for a new Power/deflection board through pioneer. i am including a link to their site. You may find it cheaper someplace else on line, but pioneer will have better quality parts. hope this helps. heres the link.
http://parts.pioneerelectronics.com/model.asp?modelNum=PRO200
Jan 15, 2008 | Pioneer PRO-200 60" Rear Projection...
Pioneer Pro-119 Rear Projection TV
HEY DF-YOU SET HAS 2 BAD STK392-110 CONVERGENCE ICS.THEY WILL NEED TO BE REPLACED AND IF NO OTHER CONVERGENCE CIRCUIT PARTS HAVE FAILED YOU SHOULD BE ABLE TO SET YOUR CONVERGENCE ALIGNMENT PROPERELY.TV REPAIR ESTIMATE SHOULD BE ABOUT 300.00$.DO IT YOURSELF FOR ABOUT 40.00$.
Nov 24, 2007 | Pioneer PRO-200 60" Rear Projection...
Does not power on
ok on pioneer most of the time it is because of bad connections all over the main power supply board solder these and see what happens like i said most of the times it starts with bad connections.
Nov 18, 2007 | Pioneer PRO-119 60" Rear Projection...
Pioneer PRO-200 60" Rear Projection Television Logo
62 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Marvin
Marvin
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
