Question about Garmin iQue 3600 GPS Receiver
Not receiving satellite signal.
If my atenna has gone bad, is there a way I can repair it? I am very good with small electronics.
  • 2 more comments
  • cjburt Sep 06, 2007
    Yes it does. I just received an external antenna and it works perfect. Now I would like to be able to fix the internal one so that I don't have to be tied to a cable all the time. Garmin wants $150 to fix it. I'm hoping there's another route I can take.
    Please advise,
    Casey
  • gpsnav Dec 01, 2007
    I have the same problem. My unit doesn't acquire any satellites with the internal antenna, but works just fine with an external antenna. I took the unit apart, but I can't figure out how to remove the internal antenna.
    Anybody know how to remove/replace the internal antenna?
  • Go Cool Dec 18, 2007
    iQue 3600 will not acquire satelites. It was working great, and then next time i used it---KaPoof!!!! . It works great on everything else, but the antenna is not working
  • Anonymous Feb 13, 2008
    I have garmin 660, I can not receive any signal from sat.
    Please help
I too fixed my IQ 3600 satellite-acquiring problem, with a $20 Gilsson external antenna. This was after I'd paid Garmin $150 just last year to repair the same problem. They ended up sending me a different unit.
I'm not very happy with Garmin. I bought my IQ 3600 in 2004 for what seemed to me like big bucks. Just 2 1/2 years later I paid $150 to get it repaired. If Garmin had its way, just a year later I'd again pay for another repair (now $200!) Hmmm, is it worth it? I don't think so!
I love Ginger when she works, but she don't work so good! Thank goodness the external antenna fixes the problem! Otherwise, I'd be a-fussin' and a-fumin'.
Posted on Jan 06, 2008
  • 174 Answers
1st check to see if an external antenna will work.
Posted on Sep 05, 2007
Millermatic 211 when its plugged into 110 it welds fine but when i plug it into 220 the fan kicks on like normal but i get nothing on the gun and no wire feed shop said board miller says its a relay.
This machine is an auto adjust for different voltages.
The front end of the circuity is a PMPS or pulse mode power supply. No matter the input, the output is the same.
Most all small appliances today are built around this technology. I bet a small IC on the circuit board has gone bad. A good electronics repair man could fix this or you can get the board from Miller.
Jun 20, 2018 | Miller Welding Tools
Isuzu 300l 2007 model is not reving
just try the given link for service and repair manual this link provide the original manual not copy http://toolsnyou.com/
May 27, 2018 | Isuzu Cars & Trucks
Is there a fuel pump reset button on this car ,if so wheres it at?
no reset start by checking ignition key if its worn down vehicle wont recognize it also is key an electronic key may have gone bad if good recheck fuses if good pull fuses and check for power if good recheck relay if good pull relay and check for power if good than check lines and connections and power at pump connections if good than pump bad if anything bad leading up to pump repair replace and recheck connections up to pump also check battery connections for corrision
Jun 02, 2015 | 2007 Pontiac Grand Am
When cooking a frozen dinner for 5 minutes at full power, everything is fine. When cooking a second frozen dinner for 3 minutes immediately following the first one, the microwave goes into the 70% co
Your circuit board has a small chip in it that allows the settings to be changed. The chip has gone bad. Usually any good electronics repair person can fix the problem. Ask your local dealer for a reference.
Nov 25, 2014 | Emerson MW8119SB Microwave Oven
What type of adapter do i need to connect my two stock cb atennas to my cb on my 2008 peterbilt
Without seeing the ends I cant help you here but I can steer you towards Allied Electronics. Give them a call and tell them what you have. They should be able to cross reference for them or have converters available.
Mar 02, 2014 | Uniden Radio Communications
Thermostat reads 120 degrees but pool is only about 75
Your temp sensor has gone bad. It is a small tube that slides into the water manifold with two wires comming from it. Follow these to the control board and then unplug them. Now just get a new one and replace. This should fix the problem. Good luck.
May 15, 2010 | Pentair Mastertemp Pool & Spa Heater Dual...
Technic 1200mk2 has no speed control
This unit is NOT belt driven. It is direct drive, meaning, that a series of Integrated Circuits (IC's), and various other electronic components control it's speed. If it's going very fast, more than likely one of the IC's (or multiple), have gone bad. You need to take this to a service center for repair.
- OPTiC
The Technics Expert
Technics Repair
DJ Equipment
Dec 30, 2008 | Technics SL-1200MK2 Turntable
Electronic frost-free fridge ices up about once every ten days
you have a defrost problem.
3 things.
1 - defrost heater gone bad.
2- bi-metal / thermo-disc gone bad.
3 electronic timer or mechanical timer gone bad.
tnx 4 using fixya,
drcool
Sep 14, 2008 | Refrigerators
Hx-d7
You have a short in the internal power of this unit. It is going into protect and shutting itself off to keep it from damaging anymore of the internal electronics. Very likely a voltage regulator has gone bad or a power capacitor has gone bad. You will not be able to repair this yourself unless you are skilled in electronic repair. I would suggest contacting the manu and seeing if they have a authorized repair shop in your area. If not ask around and see who is a reputable repair shop in your area.
Feb 08, 2008 | JVC HX-D7 Shelf System
Garmin iQue 3600 GPS Receiver Logo
631 people viewed this question
Top Garmin GPS Experts
Marvin
Marvin
Jean-Luc Steffann
Sheldon Dedek
Are you a Garmin GPS Expert? Answer questions, earn points and help others
