Question about InFocus ScreenPlay 4805 Multimedia Projector
Dark blur/"burnt" smudge look on screen
Great unit, no problems until recently when the right side of the screen edge became a dark "dirt" colored smudge, about 3 inches thick, now, another "smudge" across the bottom half. the bulb is relatively new and have not had any problems
  • 167 Answers
Clean the lens or get a new colour wheel
Posted on Jan 26, 2008
My samsung led tv is getting dark
With a DLP TV, getting a darker picture means it is time to change the bulb.
Feb 16, 2015 | Samsung Televison & Video
Smudge line on side of page
Smudges are most likely from the toner cartridge. If you can take your finger and run over the print and it smudges, then it is the fuser.
Aug 01, 2014 | Dell C1765nf Multifunction Color Laser...
Screen goes dark/blank once i reach the menu
Sometimes disk read problems arise when there are scratches/smudges on the surface(reading area).
Try giving it a clean, from the centre out to the edge, with a clean, soft cloth, then try again.
You could also try the disk in another PS2 to see if it's your hardware that is the problem. If it repeats in another machine, the disk itself is faulty, otherwise you might just need to get hold of a cd/dvd lens cleaner disk, run that, and see if it solves the problem.
Hope that helps.
Cheers from New Zealand :D
Jan 02, 2013 | Atari DragonBall Z: Budokai 3
I changed my toyota sienna transmission fluid but after it runs for 10 miles the color is dark again and i changed it again same thing the color of fluid became dark again . what was the problem of...
you only get about half of the fluid when u change-the rest of the old stays in the torque converter--since its so dirty u cud doit again until it clears--do not flush it with a machine-it will disable it cause dirt will get into the valve body and become stuck
Jun 19, 2011 | 2002 Toyota Sienna
2007 Sony KDL52XBR TV with blurred display for 20 min then fine
This is a known issue with the unit that you have. It is called an LCD tab bonding defect. If you want to try to repair it, you need to get the unit apart so that you can access the edge of the lcd panel. Power it on and observe the picture and then press the edges of the display and see if you can locate the point that the edge has the defect. If you can locate that point then you have 2 options, Uncovering that point as best that you can and using a heat gun to attempt to reflow the connections OR you can find something to clamp that point and hope that it holds, otherwise you are going to have to pay for a new screen. You cannot order it yourself because they wont ship to you.
Nov 19, 2017 | Sony KDL-52XBR4 LCD Monitor
Background ghost like images
CHECK IT IN THE DIFFERENT ASPECT MODES. IF THE IMAGE STAYS IN THE SAME PLACE REGARDLESS OF ASPECT. THEN YOU HAVE A LCD PANEL PROBLEM. PANEL WILL HAVE TO BE REPLACED.
Feb 27, 2009 | Televison & Video
Color separation
Convergence amp ic bad
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
http://www.hdtvoice.com/voice/showthread.php?t=28929
Or send to ptscorp.com
http://www.hdtvoice.com/voice/index.php?s=
good luck
please mark the post with a fixya
Mar 03, 2008 | Panasonic PT-51HX41 51" Rear Projection...
Black smudges on copies
Hi, try to pull out complete process unit(cartridge) with toner box .You have cleaner(blue or green color) move this cleaner from right to left side 4 or 5 times.Note that cleaner MUST be in home position-right side when you finish.Check print.
If problem still persists, you must do following:take away small grey plastic cap on left side of cartridge,then push complete charge corona(part with cleaner on top of it) to left side just enough to lift right side of corona from cartridge.Pull out that corona and you can see drum and developer roller. Turn the gear on drum,and look for smudges on black developer roller.Try to clean smudges with brush or with dry cloth.Toner will again attract to that area,but regular.
Dec 11, 2007 | Kyocera Mita KM-1815 All-In-One Laser...
Vertical streak near left edge of printouts....only affects black portion of print image
Where best to look will depend a little on the nature of the smudge. If what you're looking at is white, then you might just have a little heap of toner or paper dust on part of the LED array that paints the picture onto the photoconductor drum (look for a narrow unit that stretches full width, adjacent to the drum. Dark marks may, if you're lucky, be down to dirt on charger wires. Both respond well to cleaning with a vacuum and a soft cloth (be very gentle if cleaning the wires). I would be inclined to trust the existing photoconductor unit unless you know it's been abused (e.g. by leaving it lying around in daylight) or the coating on the drum is visibly damaged. A.
Apr 11, 2007 | Ricoh CL3000E Laser Printer
Right 2 inches on edge of screen are darker than the rest of the screen
What is the model of the TV? Samsung DLP TV's start with HLS,HLP,HLW.....
Feb 06, 2007 | Samsung TX-R3080WH 30" TV
InFocus ScreenPlay 4805 Multimedia Projector Logo
611 people viewed this question
Top InFocus Office Equipment & Supplies Experts
Jaime Hernandez
neOen
Level 1 Expert
Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
