Question about Sony KP-53V45 53" Rear Projection Television
Screen Flashing Have a problem with the picture constantly flashing off and on on my Sony KP-V45 53 inch TV. What do I look for and where?
  • FunkedUp Feb 26, 2008
    the screen is all blue. popping the back off you can see the red and the green tubes flashing really fast, under half as bright as blue (which isnt noticably flashing at all) Sony KP41su3
  • 398 Answers
In a Sony TV, the most common cause of the picture flashing on and off is a weak picture tube. When the set was new, it took about 5 to 10 seconds for the picture to appear once the set was turned on. This is normal. If you have been noticing that it has been taking longer and longer to first appear, this is the clear signal that one of the picture tubes is getting tired. There is a circuit called IK Blanking that monitors each picture tube and adjusts them as the tubes age, so you always see a good picture. When one of the tubes has weakened so much that it cannot produce enough brightness in the picture, the circuit shuts the picture off completely. I guess Sony does not want you to see a tired, dull picture. When the tube is right on the edge of being too weak to keep the picture on, the picture will flash on and off, and it will also take much longer beofre it first turns on. The good news is that the Sony picture tubes always respond beautifully to reactivation (CRT Recharge) but you will need a qualified tech familiar with Sony projection sets to handle that repair for you.
Posted on Aug 21, 2007
SOURCE:
Sony kp-51ws520 when turned on just has standby light flashing . the rest is all dead, no picture or voice.
Standby flashing light shows that tv got some internal problem. How many times standby light is flashing is info that provide info about what section of tv got problem.
Count standby light blinks and let me know, there would be 3 seconds long pause in blinks so count pause to pause.
Jul 21, 2010 | Sony KP-51WS520 51" Rear Projection...
Sony KP-46WT510 Picture went out (completely
Your Sony TV needs Screen (G2) volts adjustment and I'm not sure that you can do that or not by yourself.
If you are confident and know electronic stuff repair, then let me know to guide you OR call local TV tech to perform adjustment.
Thanks.
Oct 30, 2009 | Televison & Video
Sony Projection Stand by indicator flashing red
Ur FBT,Fly Back Transformer high voltage is dead, the black block of plastic with a red wire with cap hook to a CRT(Tv Tube).
Sep 14, 2009 | Sony KP-46S25 TV
TV SREEN GOES BLANK, BUT AUDIO CONTINUES NORMAL,
Try unplugging for 36 hours. I had the same problem but with no sound and picture
Mar 03, 2009 | Sony KP-53HS10 TV
Picture flashing on and off
Press Display / Info button on "TV original remote", such display will disappear.
Nov 17, 2008 | Sony KP-61HS10 61" Rear Projection...
Timer Standby light flashing No pitcher
Sony
Model # KP-53HS10
Serial # 9718217
MFG 2000
Plugged in TV. Timer Standby Light just flashes continusly. No Picture and No Sound.
Apr 02, 2008 | Sony KP-51WS500 51" Rear Projection...
Sony Trinitron KV35V35
Could be a weak Picture tube . You can try turning up the screen control but don't turn it up too much you'll get retrace lines in the picture . Turn it alittle at time until picture comes on then turn it down until the retrace lines go away . Then try turning the tv on and off to make sure it comes back on. Be careful you can get shocked if you do this while it is on and you touch one of the circuits . The control is on the flyback or the module thats on the picture tube it will say screen by it . If this does not work you could have vidoe problems or just the picture is no good . Good luck
Jan 20, 2008 | Sony KV-35V35 TV
Open Questions:
Televison & Video Logo
536 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
