Question about Crosley CDE6000 Electric Dryer
No Heat Everything seems to work perfectly but has no heat it just blow hot air. I tried to take back panel off but was unable to see anything and I do not have the owners manual. Please help
    Novelist:
    Champion:
  • 244 Answers
It will be your thermostats that need replacing they are what control your heat should be 2 but more than likely that u only need to replace the lower heat stat which is the one on the left has u look at it with the back panel off this should resolve the problem
Posted on Aug 23, 2007
Passenger side blows cold air--what part could it be
2001 Chevy Tahoe Heat Problem - Tahoe Forum
www.tahoeforum.com > ... > Technical Discussions
Dec 5, 2008 - 10 posts - ‎7 authors 2001 Tahoe, the front heater blows a little hot air when the car warms up and then blows cold air. The rear heat seems to work fine. I changed ...
Rear AC blows hot air - Tahoe Forum - Chevy Tahoe Forum
Jul 14, 2008 - 10 posts - ‎5 authors
On my wifes 03' Yukon the rear air conditioning blows hot air no .... Pull the panel off and look at the hot/cold actuator shown in the picture.
Oct 30, 2015 | 2001 Chevrolet Tahoe
Everything seems to work??? still no heat?
dirty heater coil, clean it out so the hot air will travel thru
Dec 18, 2013 | Cars & Trucks
I have a 1996 cherokee country. When I use y
Could be the control switch itself. Or possibly the actuator that moves the door from defrost to heater. With the heater on, try switching from defrost to heat and try to hear if you can hear anything in the dash operating.
Mar 09, 2010 | 1995 Jeep Cherokee
MY HEATER BLOWS HOT AIR THEN BLOWS COLD THEN HOT THEN COLD,ICHANGED THE MOTHER BOARD, RELAY SWITCH, AND THERMOSTAT, IT IS RUN FROM A HEAT PUMP WITCH I HAD CHECKED AND IT WORKS FINE
I have a lux electric thermostat my furnace will blow out heat for about one hour to maybe three then it will start blowing cooler air,I then cut it off for thirty seconds or longer once I do that it will start blowing out heat again then it will repeat it self again what could be the problem.
Jan 07, 2010 | Heating & Cooling
Central heat does not blow hot air, just warm air weakly
Sounds like some of the elements are not working. You being in Florida they may not have put very many elements in. It was 61 degrees last week. I know because I'm a Dolphin Fan. You will need a current sensing meter to check the elements.
Jan 04, 2010 | Heating & Cooling
2002 New VW Beetle is only blowing hot air out of vents even when set on cool. I was driving and I made a turn at an intersection and all of a sudden the cool vent air turned to hot air like I had the heat...
On the bottom of the air unit is the lever that changes temps. It likes to fall out of place.I propped mine back with a piece of half-inch copper pipe a couple of years ago.Remove glove box then panel on front side of console to access.
Apr 09, 2009 | 2003 Nissan Altima
I have a amana pbh092b12mb 26" TTW 9K BTU Heat pump. i know it's cold outside (19 degress) but it just doesn't seem to work right. blows cooler air then warm. what can I check to make sure it is...
you didn't say what zone you're in but if you're north of southwest missouri you can forget about anything seeming warm below 30 degrees outside i tell all my customers to switch to emergency heat when temp's get below 25 for extended periods of time 2 days - weeks. either way you're at the mercy of the utility company on emergency heat you get hot heat and faster results heat pumps out of the box can only give you what they can generater from outside temperatures 35-55 they work great giving better than 3 to 1 but that falls off drastically when the temperature plunges
Dec 15, 2008 | Amana Heating & Cooling
My Heater blows cold air
is this a gas furnace if so does the burner ignite
Nov 25, 2008 | Intertherm P3RA-048K Air Conditioner
AC & Heat not working on air is blowing
did you forget to hook up any vacuum lines
Sep 27, 2008 | 1999 Ford Windstar
Dehumidifier
Again, if your model is one that can be used in cooler temps so as not to ice up, the heat prevents this.
Aug 07, 2008 | Maytag M7DH45B2A Dehumidifier
Crosley CDE6000 Electric Dryer Logo
85 people viewed this question
Top Crosley Dryers Experts
Archie Ferrarini
Archie Ferrarini
Craig Butler
Craig Butler
Marvin
Marvin
Are you a Crosley Dryer Expert? Answer questions, earn points and help others
