Question about JVC HD-56G886 56" Rear Projection HDTV
HDMI input Thought dvd player was broken when got green screen, replaced dvd player and all worked for about a week, then green screen returned. RCA inputs verified dvd player was working, was using same hdmi cable from old dvd player so replaced cable, green screen remains. Do I have any options beyond calling a repairman?
  • Anonymous Mar 20, 2014
    occasionally having a slight problem with my TV's color (screen is occasionally B/W) when switching it from regular cable, watching on the TV's INPUT, "HDMI-2" to the DVD player on the TV's INPUT "Comp/AV Antenna".
    Problem Solver:
The green screen is caused by light hitting the back of the tv. Either move the tv to a location where direct sunlight will not hit it or put up strong curtains. As for fixing the problem, do a search for JVC green screen reset on AVS Forum, its easy to do just dont have the info with me now. Keep in mind if direct sunlight hits the back of the tv it will do it again. I have put up some good curtians and ensure not to open them when watching the tv. Hope this helps. I am Hayward, have a nice day.
Posted on Feb 20, 2008
  • 1 more comment
  • haywardw Feb 21, 2008
    Here is the information to clear the green screen.
    Here are the proceedures for taking care of this problem:
    1) Turn on TV
    2) Make sure the remote toggle switches are set to "TV" and "VCR" respectively
    3) Press the "Sleep" button
    4) Simultaneously press "Display" and "Video Status"
    5) Press "2" (Self Check)
    6) Turn off the TV
    7) Wait for fan to turn off (30 seconds or so)
    8) Unplug TV
    9) Wait for 30 seconds
    10) Turn TV back on
    Hope this helps
  • marypoppi714
    marypoppi714 Feb 06, 2012
    OMG ! haywardw ! THANK YOU SO MUCH !! The procedure below WORKED !!! We have been messing with our TV for weeks - until we found your info below ! Thank you so much for taking the time to put this on here. T o all those with green screens - PLEASE try the procedure below - it works ! - Tara W in New Mexico - owner of a 61 inch JVC.
  • marypoppi714
    The procedure is the 1-10 steps from haywardw - it works! (sorry for the "below" references - the comment box was above the steps when I wrote the 1st comment - my bad :o) But, seriously - thank you. We had NO idea what to do and your 1-10 steps fixed it.
I just got mine repaired, the hdmi module was rooted.
same thing
hdmi green tinge on the screen with same tele, just go get it repaired if still under teac 3 yr warranty
Posted on Apr 14, 2008
How do I hook up my sony dvd player to my tv screen?
Does your DVD player have RCA outs on the back (the red, yellow & white sockets) and does the rear of your TV have the same? Some new flat screen DTV's no longer have RCA inputs and only have the flat, rectangular HDMI inputs. All current generation DVD players are Bluray and require a HDMI cable and DTV to support them. Match the connections with the right cable between the 2 devices and identify what input is being used on the TV in the 'AV' settings.
Sep 15, 2018 | Sony Televison & Video
Get RCA DVD Player to work.
ok on dvd player u wann use hdmi cable direct to tv ok then select input hdmi on tv remote to see picture
Feb 02, 2008 | Thomson Lyra PDP2860 Digital Media Player
I have a DVD/VHS player that uses RYW RCA connectors and a new 4k TV that has HDMI slots, plus one yellow and one blue round slots, neither of which fit the RCA cables. How do I connect them?
The red, white and yellow plugs from the reciever will plug into the red, white and green input plugs on the TV. Be sure to select "AV" mode on the TV and not "HDMI". The Green plug on component inputs is the Video input. Otherwise you can find an adaptor that will go to your hdmi ports via the rca jacks!!
I Hope This Help's!!
We Are Here To Help !!
Nov 29, 2017 | RCA Televison & Video
I have a Toshiba tv that is connected to Direct tv and I want to know how to connect my new Phillips dvd player to it my tv?
Flat screens normally have 3 different inputs from tv. Regular is tv coax cable, then audio/picture by using special rca cables, then last HDMI. You can use any of those inputs except hdmi because you already are using that input. You may be able to buy a hdmi splitting device that will allow both the tv and the player to input to the single hdmi input. Check Radio Shack or Wal-Mart.
May 12, 2014 | Toshiba HD-A30 HD-DVD Player
Isn't this just a simple hookup? What am I not doing?
You either need to change the input source. Currently the source is TV, depending on how you connected the DVD player to the TV, it should be composite (A/V), component video or HDMI. (S-video is also a possibility. Very few DVD players are connected on the RF (coax) input which might be channel 3 or 4 without having a converter between the DVD player and the TV.)
Look on your TV remote for a button marked Source or Input. You may also find this button on the TV. (On some TVs, this may also be accessed through the menus.)
How did you connect the TV and the DVD player? If your audio and video were connected via three RCA plugs (yellow, red, white) on each end, then use the composite video input. If you used cables with 3 RCA plugs for video (yellow, green, blue) and 2 for audio (red/white), then switch to the component input. If you used HDMI which carries audio and video in one cable (with rectangular ends), then use the HDMI input.
Some older TVs only have the Source/Input button on their original remote. Not all universal replacement remotes have this button, you may need a different remote. Those that do may require you to try additional codes for your TV manufacturer to enable the button. (The on./off buttons often will work with more of the codes for a brand.) The ones that can be programmed via a USB connection to a computer are most likely to support the function. Please add a comment with the type of TV for additional help with this.
I hope this helps.
Apr 21, 2012 | Sony Dvp-sr500h 1080p Upscaling Dvd Player
The coax input on my tv is broken off how can I connect the cable to it other than the red white and yellow cords which don't have a good connection either I have my dvd player hooked up to hdmi is there a...
the simple answer is no.
but if you have basic cable (coax) you could connect it to a vcr, tune the channels with the vcr-
connect the vcr to the TV with composite video (yellow, red/white)
Apr 13, 2011 | Samsung Televison & Video
HOW TO PLAY DVD PLAYER WITH THE TV
Instructions Things You'll Need:
  • DVD
  • RCA, component, or HDMI cable(s)
  1. Decide what type of connection to use. Look at the back of your DVD player. It should at least have RCA (red, yellow, white) output ports. It may also have component out, S-video out, VGA out, or HDMI out. These connections vary in picture quality and price, HDMI being the most expensive and providing for the highest-quality picture. Whichever type of connection you decide to use, you also need to verify that you have the same connection on your TV. Flat screen TVs typically have more connection options than other types of TVs, so you should at least have component, RCA and HDMI inputs.
  2. Connect the DVD payer to the flat screen TV. Take one end of the cable or cables you decided to use and connect to the output on the DVD player. The other end should be connected to the corresponding input on the TV. Video input connections are usually found on the sides of flat screen TVs. Once the DVD player has been connected, you are ready to use your DVD player.
  3. Check DVD player functionality. Tune your TV to the input that you used for your DVD player by pressing the button on your remote labeled "input," "source," "TV/video," Source select," "TV/AV" or the like. For instance, if you used an HDMI cable plugged into your TV's "HDMI 1" input, press the input selection button until you see HDMI 1 on the screen. Power on the DVD player, insert a DVD into the player and press play and you should now see a feed from your DVD player.
Jan 17, 2011 | Panasonic Televison & Video
HDMI out to Olevia 527 TV = Blue Screen
Hi beelzyboob.. try checking these.. since you are using the RCA (composite cables) and I assume you have them on the "DVD in" at the back, go to setup, go to input assignment and go to hdmi input. here, make sure dvd is set to" ----". Next, hit return and go down to component input and also check if dvd is set to "-----". With these settings, you should get video. This is because you are not using either an HDMI or component cable. hope this helps.. ^_^
Sep 09, 2008 | Onkyo TX-SR606 Receiver
I dont know how to hook up a dvd player
Depending on the model of DVD player and the TV you are trying to connect it to you have various inputs and outputs.
If your have an HD (High Definition) DVD Player and a HD TV the best input to use is HDMI. Both device would have an HDMI interface whereby you could connect them together.
If you have a standard DVD Player you have usually 3 other input/output options, RCA, S-Video, and Component. Your RCA jacks are colored Red, Yellow, and White. Your S-Video is a larger circular jack with several pins. The Component cable has Red, Green, and Blue.
Of the three above the Component Cable connection is going to give you best picture quality. S-Video is second and RCA is third. You just need to match up the connectors on your TV and DVD and get the cable that accommodates the best picture quality. Again for clarification below are the interface options for best quality to poorest:
1. HDMI
2. Component
3. S-Video
4. RCA
Hope this helps.
MO
Jul 14, 2008 | Televison & Video
RCA DRC8052N DVD recorder
Try the input button on the DVD remote. You may have to move it to AV1 to get a picture??? Just a suggestion.
Nov 18, 2007 | RCA DRC8052N DVD Recorder
JVC HD-56G886 56" Rear Projection HDTV Logo
932 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
