Question about Samsung HLP5685W 56" Rear Projection HDTV-Ready Television
Samsung HLP5685W HDTV-Ready DLP Rear-Projection TV 2004
Was wondering if anybody can help me out here. I have had this tv for a little over 3 years without any problems. Two days ago, a dark but transparent band has appeared on the lower left side of the screen only. It tapers to very thin at the left middle of the screen, but it extends about 1 inch when measured from the bottom. You can see the picture through the line, but the color looks very funny at the transition point. Any ideas?? Thank you VERY much in advance. Ecoustics.com has a thread on the issue and says it is a defective mirror box. Samsung says it has not been an issue but dozens of others were able to get Samsung to fix out of warranty. HELP!
  • ttlc Jan 29, 2009
    We have the exact same problem, size and all, it appeared one day. It is in the lower left side as well and when the TV is first turned on it is smaller and gets larger once it has warmed up. We had our bulb change in the TV set about 2 months ago. We have a Samsung HLP5682W 50 inch TV DLP rear-project TV 2004.
SOURCE: SAMSUNG PICTURE FREEZE (LOOKS BLACK&WHITE)
got mine working better unplugged the sound and wiggled the plastic coated wire above the large fan works but freezes maybe once in a day some days never have the sound running through the receiver (surround) I shut it off and it comes back on when it does freeze figure loose connection
Posted on Jan 06, 2008
  • 208 Answers
SOURCE: Dlp problem
The unit has a defective light tunnel contained within the light engine. This part is not easily replaced and you will a qualified tech to replace it. Many service centers condemn the light engine at a much hight cost. Do not buy or let someone tell you the light engine must be replaced. This repair requires only the light tunnel.
Posted on Feb 10, 2008
  • 146 Answers
SOURCE: Samsung DLP hlp5685w won't come on
Is this 330, 80, 7.5 volts that you are reading, The B+ that is going into the ballast?
Posted on Mar 15, 2008
Slinteriors
  • 8617 Answers
SOURCE: Samsung 61" DLP 3 Blinking lights.
all 3 lights blinking means lamp has a fault the service manual says replace the lamp. If you need the service training manual for that model let me know and I will post the link as the training manual has excellent trouble shooting breakdowns for that model DLP
Posted on Mar 26, 2008
  • 4234 Answers
SOURCE: Picture shadow on rear projection Sony big screen TV
You have 2 distinct problems that should be addressed separately. Please repost the Samsung problem. I will address the Sony problem here.
If the "shadow" makes the picture seem somewhat of a 3D one, the problem is with the convergence circuit. This could be as simple as bad connections on the pins of the convergence ICs or defective ICs. If you can solder and would like to attempt the repair, update this and I'll provide more details and instructions.
Dan
Posted on Sep 25, 2008
Hlp5685w.....no picture
That was likely a capacitor that popped. Slight burning smell? You may need to have a technician come out to resolder a connection or two.
Jul 11, 2010 | Samsung HLP5685W 56" Rear Projection...
Watching tv funny noise like it blew up and turned off, bad burning smell ,now turn on tv starts to power up like normal and then nothing any help much appreciated, tv is a samsung HLP5685 56' inch rear...
The smell and sound are that of a capacitor burst. If you open the back cover you will find wax around a cylindrical object. That's it. Replace it with an exactly the same item.
Feb 28, 2010 | Samsung HLP5685W 56" Rear Projection...
Samsung dlp white dot
If the white dot is on every picture and every input and stays there for a sec. after you press the power button to turn off the tv then suspect a stuck mirror in the DMD.
Sep 29, 2009 | Samsung DLP HL-P4663W 46" Rear Projection...
Samsung HL-P6163W DLP sometimes turns on with NO PICTURE
sounds like the dmv pcb bpard cost 597.70 and about a 250 core charge from andrews electronics.
or you can look ay the price at partsstore dot com.
regards,
daniel.
Jan 09, 2009 | Samsung HLP6163W 61" Rear Projection...
What TV should i buy ? (help)
Go with the samsung it will be the best of all of repair wise!!! The other sets you are talking MONEY for repairs.Hitachis DCU module a lone retails 275.00
Dec 04, 2008 | JVC AV-56P575 56" Rear Projection...
Samsung DLP HLS5086W - spider crack
You will need to get the screen from here:http://www.samsungparts.com/part_detail.asp?catalog%5Fname=Parts+and+Accessories&product%5Fid=BP67%2D00261A&search%5Fmodel=HLS5086W You should also get the service manual for this TV set, as that will show you how to disassemble the TV set. Good Luck
Jul 05, 2007 | Samsung HLP5685W 56" Rear Projection...
Samsung HLS5086W - spider crack on outer screen
The outer screen is called a Lenticular screen, it may come as a set with the Fresnel (the inner, and the way I would actually go) the screen is very hard to replace usually on a DLP as they have a somewhat sealed upper side and alot of screws.
Open Questions:
Samsung HLP5685W 56" Rear Projection HDTV-Ready Television Logo
112 people viewed this question
Jerry Greenberg
Jerry Greenberg
