Blodgett DFG-100 Gas Single Oven Logo
Anonymous Posted on Jun 15, 2013
Oven pilot lights but bunner doesn"t
How do you light your pilot light on an kenmore oven
To light the pilot light on a Kenmore Maxitrol oven, please follow these steps:
  1. Locate the pilot light assembly. It's usually at the bottom of the oven, behind a small metal cover.
  2. Turn the oven control knob to the "off" position.
  3. Remove the metal cover by pulling it out or lifting it up, depending on the model.
  4. Locate the pilot light and the pilot light valve. The valve is usually a small red button located near the pilot light.
  5. Press and hold the pilot light valve in for a few seconds while you use a long match or lighter to light the pilot light.
  6. Once the pilot light is lit, continue holding the pilot light valve in for another 30 seconds.
  7. Release the pilot light valve and make sure the pilot light stays lit. If it doesn't, repeat the process.
  8. Replace the metal cover and turn the oven control knob to the desired temperature setting.
Note: If you're having trouble lighting the pilot light or keeping it lit, it may be best
Amana oven pilot light
If you have a standing pilot and it is not on, you should be smelling gas in the house.
Try lighting it with a BBq lighter directly.
On some stoves, you will have to press a button and hold that button for some time ..over a minute..while you have the light to the middle of the pilot.
Do not proceed to light the pilot until there is no more smell of gas in the oven.
Oct 24, 2013 • Ovens
MY MAGIC CHEF, CONCEPT SERIES, W/MAGIC CONTROL CENTER DOESN'T LIGHT.
I have a Magic Chief Concept Series oven - Replaced the Thermo-coupler and the control switch. I now have a pilot light but the thermo-coupler doesn't get hot enough to light the burner, But if I take a lighter and put it on the thermo-coupler it will but when I take if off it shuts off after a few seconds. Could you please give me Ideas of what could be wrong
1helpful
When i turn on oven all i smell is gas i cleaned with a wire brush still nothing. also is the pilot light always have to be on and can you see it when oven is off
Most gas ovens that aren't electronic ignition usually have a pilot light.
Usually one in the oven area and one for each burner. (Sometimes shared between two burners.)
These pilot lights must lit at all times...otherwise it won't light up and you'll smell gas.
Usually the pilot light is in the very back of the oven and can be seen with the broiler drawer opened.
There is a small set screw located at the pilot light assembly in the oven and also at every burner.
This allows you to adjust pilot light up or down, thereby letting you set pilot light flame to a level that doesn't get blown out by a draft...or you can turn it off completely.
If you use that set screw to turn off the pilot light gas, you'd need to strike a match to light the oven or burners everytime you needed them.
Jul 17, 2011 • Ovens
Our 17year old GE gas oven/broiler stopped lighting today. What might be the problem? Stove burners work.
Most likely culprit is the igniter.
When you turn the oven on it opens a gas valve allowing a small amount of gas to flow thru the pilot light. The igniter then lights the pilot and when the sensor determines the pilot is lit it opens th emain gas valve and the oven lights. If the igniter fails and doesn't light the pilot the sensor doesn't heat up and it shuts down the pilot and nothing works.
The igniter is usually accessable under the oven by removing the drawer. It has a single wire attached and looks like a short cigarette made of ceramic witha metal tip.
You didn't provide model number so I can't give you part number but if you look it up here you may be able to get one from Sears
http://www.searspartsdirect.com/partsdirect/index.action?sid=PSHx20080114x00001
May 18, 2011 • Ovens
My oven makes a noise before it lights. A "whoosh"
That is common with gas since the gas fills the entire element before there is enough gas for the pilot to ignite. You have the same thing with outdoor gas grills.
2helpful
Oven pilot went out due to power outage. I don't know where the pilot oven light is. where is the pilot light to light the oven?Ge XL44
pilot over lights do not require power to stay light or should it go out in a power outage! do you have to normally light pilot with a match? if not you have a glow coil and its a electronic ignition range and power will affect it. once power is restored you should just be able to turn on over and everything would be ok.if it is a pilot light you need to remove the bottom door stick arm in to back and you'll see the pilot assembly at back if you look up! hopethis helps...
Feb 06, 2010 • GE Ovens
Magic Chef range the pilot on the oven will not light.
Is this a manual lighting pilot,do you light it?
If so you may have a bad gas valve.
If this is an auto light pilot it could be the electronic spark is bad.Im guessing the popping noise is the autospark trying to light.
Oven will not light
Most gas ranges currently available employ one of 3 basic gas ignition systems; pilot ignition, hot surface ignition system (which uses a 'glow bar' or 'glow coil' - aka an "ignitor") and a spark ignition system. The latter two being referred to as "electronic ignition" systems as they use electricity in one form or another to operate the oven heating system. Only the pilot ignition system has an actual "pilot" (which is a small but real "flame") which might need manual lighting.
If the surface burners of a range are a spark ignition type, the oven IS one of the possible kinds of electronic ignition systems and thus will not usually have a "pilot" which needs lighting. Be aware though that just because the surface burners might light via a spark doesn't necessarily mean the oven uses the spark type ignition system too. spark-anim1.90x11.gif
There is one older style of electronic ignition system which does also use an oven pilot but it is very rare and such a system hasn't been used in oven models since the early to mid 70's. It is the 'constant pilot' *electronic ignition* system
Top Blodgett Ovens Experts
ZJ Limited
ZJ Limited
ADMIN Andrew
ADMIN Andrew
Are you a Blodgett Oven Expert? Answer questions, earn points and help others
