Question about Kenmore 43142 Front Load Washer
Impeller or clog?
Ok, I'm pretty proud of myself, although I am also very wet. My front loader didn't drain. Following the directions jsrock516 gave justvanessa, I unplugged, detached hose - at which time a ton of water came from the impeller hole - and used the shop vac to see if there was a clog in the drain tubing. It was clear. The impeller motor is quite hot. The drum turns, the water drained out of the impeller hole, so I stuck my finger in there to see if there was a clog, but it was sort of scary. Also, when the machine cycles to what appears to be the drain time, a motor makes a noise, sort of like a hum. It's not whiny and it's not grindy. I also unplugged the little wire bundle that goes to the impeller (for fun???). I don't know what to do next. Anybody?
  • Lawson Hunsicker Aug 21, 2007
    I ordered the part. It'll be here in 2-3 days and I'll be back then. Now I just have to find a small enough screwdriver to get in there and get the old part out. You, by the way, are EXTREMELY clear about what to do, and it makes me unafraid to try. Thank you very much. I'll be back.
  • Lawson Hunsicker Aug 24, 2007
    jsrock-
    YOU ARE THE MAN!!!! The part came without directions, but it was pretty straight forward, even though it was kind of hard getting a tool in there to loosen the 2 screws that held it. I put in the new drain pump, completely disassembled the old one, and found a wooden 3 inch long cuticle pusher from a manicure set inside! This machine works better than it has in a long time and I am so proud of myself!! If it hadn't been for your answer and the confidence it gave me that you knew what you were talking about, and you understood what I was talking about, I would STILL be waiting for a service call to even start the EXPENSIVE process. At this point, I'm on my 3rd load of laundry and catching up fast, saying THANK YOU,JSROCK! You DO rock!!!! I'm a widow and don't have much money and I DID it! GOD BLESS YOU!
WOW! Thank you so much for this information! All I had to do was remove the hose from the pump unit and the business end of a pocket screwdriver fell out! You saved me $$$ and for that I am very grateful!
Posted on Aug 26, 2008
Thanks to this information, I was able to discover the problem with my machine. I swapped out the drain pump from an old unit I had and discovered a bobby pin wrapped inside a bunch of lint/gunk causing the unit to fail. Thanks to your solutions I saved myself an expensive service call.
Posted on Aug 24, 2007
  • 5,911 Answers
It sounds like you've done all the preliminaries, but now it appears you may have a bad drain pump. If the pump is only humming and water is not draining, the motor is probably bad. So...here's a few more questions to consider: 1. Is there water being left in the tub? Definitely a bad pump possibility. 2. When you had to pump open, were you able to spin the impeller? Sometimes small items like a piece of gravel can stop the impeller from turning. 3. Did you check the ENTIRE drain line all the way to the standpipe? You could have a pinched or clogged line still. If you've already tried everything, then I suggest purchasing a new drain pump. The prices vary depending on model, but they all are pretty simple to replace. Generally, there is one (maybe two) screws holding it in place. Disconnect the inlet and outlet drain hoses on the the pump, and remove the electrical connector. Make sure you have the washer unplugged when you do this. Also...to save you from a huge mess the next time, remove the drain hose from the standpipe at the wall and use you shop vac to drain the water THROUGH the drain line. That way you don't have a soppy mess to clean up afterwards. Good luck and let me know if there's anything else I can help you with.
Posted on Aug 21, 2007
  • Jeff Rockwell
    Jeff Rockwell Aug 22, 2007
    Thanks for the feedback. I'll be standing by if you need me.
  • Jeff Rockwell
    Jeff Rockwell Aug 25, 2007
    Glad I could be of some help. It makes me happy to hear some gratitude once in a while. Now you have some experience and know what to look for the next time you have a problem. Don't forget to check those pockets and keep all the things OUT of the washer that aren't supposed to be there. Good luck to you.
SOURCE:
My LG front loading machine displays error code LF when going into the drain/spin cycle. What does this code mean and how can I clear it? Thank you
I had the same problem with my Tromm front loader. I fixed it myself. On mine there are two pumps in the lower left corner, at the front of the machine where the manual drain port door is located. There is a trap in there that needs to be cleaned periodically, it traps hair, lint and large foreign objects from getting into the water lines. The two pump impellers are on either side of this trap. They do wear out and get clogged. Mine failed shortly after the warranty expired on the machine about 18 months of ownership.
When you open the trap door there is a "plug cap" (looks kind of like the gas cap on a car), that you can twist and pull the trap out. Most likely there will be water spilling out with this, so be prepared with rags, towels and a small bucket to catch it. There is also a small tube there that you can use to drain into your bucket, but it doesn't drain all of it, so keep a sponge handy to mop up with. With the trap removed you can stick your finger into the port going to the impeller pumps to see if there is anything trapped there.
Replacement parts are very hard to find for LG products, but I believe Sears still carries them, but you have to order them. There was also a place in Minnisota I found on the web that had LG parts, can't remember the name of it though.
In order to replace the impeller pumps you have to remove the top and front end of the washer to get to it, so you can use the schematic's on the Sears parts website if you want to attempt it yourself. It's not too difficult if you are handy with a Phillips screwdriver and some pliers, the hardest part is removing and re-installing the clip ring that holds the rubber boot in place around the door, without it this in place the water will leak through the door frame.
Once I got the impeller pumps out, I found the source of the problem, there was a build up of detergent residue inside the impeller that seized up the pump. This residue was undissolved powder detergent, it was like sand, caked inside the pump. We no longer use powder detergent in our washer, only liquid detergent, haven't had a problem with clogging since then (2010).
The parts cost about $100 shipped to my home, and took me an afternoon to replace. Doing the labor myself probably saved $200-250 in service charges. Around here (Phoenix metro area) it's $75 just to have the tech show up and look at it to diagnose it.
hope that helps. good luck.
Oct 17, 2014 | LG Washing Machines
Tip
F02 Error Code
This advice is for Kenmore Elite and Whirlpool Duet model FRONT LOADERS displaying the “F02” error code.
“F02” is a Long Drain error. If the drain time exceeds 8 minutes this error code will be displayed. In addition, a “SUDS” error may also be generated as a secondary error. This is an indication of a drain pump problem and/or clog in the drain line. You will need to check the following:
  1. Check the drain hose to make sure it is not kinked or clogged.
  2. Check the electrical connections to the pump and ensure the pump is running.
  3. Remove the drain pump filter and check for foreign objects and/or debris.
To check the drain pump, click on the following link for step-by-step instructions.
http://www.fixya.com/support/r3574284-checking_the_drain_pump_on_a_front_loade
If the pump motor or impeller becomes damaged and does not pump at the correct volume, the error code will not clear. If the above procedures do not correct the problem, it is recommended by the manufacturer to replace the drain pump.
on Dec 09, 2009 | Washing Machines
Tip
THANK YOU !!!!! and thanks to my 15 yr mechanically inclined son...he did do...
http://www.fixya.com/support/r385844-checking_drain_pump_kenmore_elite_front
on Aug 14, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Maytag neptune MAH5500BWW front loader didn't drain after a wash cycle. first time wife put it on spin for a few minutes and it drained, no problem. A week later that didn't work, code...
Yes you need a new control board. The fact that the motor and impeller was damaged and loosened. You should try taking your Washer in for maintenance check or call the repair man.
Jun 21, 2011 | Maytag Neptune MAH5500B Front Load Washer
My mother has a 2006 Whirlpool WFW 8300 front load washer it's in her basement here in the northeast and it is not draining properly at all, there is an error message that comes up, but as it is not my...
This is most likely a drainage error - clogged or hose kinked... I suggest you do the following:
- Check the Drain Filter (Situated in a compartment at the back if it's a Top Loader, and in the front if it is a Front Loader), there is usually a small piece of something stuck between the drain pumps impeller.
- Check that the drain hose is not kinked in any way.
Hope this helps. - J.Q
Feb 16, 2011 | Washing Machines
Kenmore front load washer not draining
You may have a drain pump that is either clogged or failed. The following link explains how to checkthe pump for clogs:
It doesn't take much to cause irreparable damge to these small drain pumps. If the motor or impeller become damaged and will not pump at the required volme, the washer will not drain and will shut down. If the pump no longer runs, you may have to replace it. The following link explains how:
http://www.fixya.com/support/r3574350-replacing_the_drain_pump_in_a_front_load
Replacement parts (if required) can be purchased at any of the following websites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
Prices vary between these sites, so shop and compare. The first three sites on the list also include helpful exploded view prts illustrations to assist you in locating and properly identifying the parts you need.
If you have any questions about this repair, please post back and let me know. I hope this helps you.
NOTE: If this a a smaller style front loader, you may not have a clean out trap on the pump. This style washer usually has a large rubber inlet hose that you remove to clean out debris. Drain any residual water, then remove the large hose from the pump. Debris commonly gets caught in this area just prior to the pump impeller.
Mar 05, 2010 | Kenmore 44102 Front Load Washer
Getting error 5e WF7708 samsung front loader. Have cleaned all filters nothing appears to be blocked. But it will not finish a cycle.
A 5E code means that the drain pump is iether clogged, with lint, impeller damage, drain hose clogged, or a loose connection on the pump connectors
Jan 06, 2010 | Samsung Washing Machines
Water won't drain and it is not clogged. and it makes a clanking noise
You may have something lodged in the drain pump causing the noise you are hearing and affecting the drain pumps ability to drain. If this is a Whirlpool manufactured front loader, the following link explains how to access and check the drain pump reservoir:
If anything has been lodged in the pump for any significant period of time it can cause irreparable damage to the pump motor or impeller. If this is the case, the pump may require replacement. The following link epxlains how:
If you have any questions about this repair, or if you need additional assistance, please post back and let me know. I hope this helps you.
Jan 06, 2010 | Whirlpool GHW9400SU Front Load Stacked...
I have a maytage epic front loader, its flashing F21-book says drain problem, How can I fix it?
HI, check the following to address this issue.
1. Clogged drain line or water pump
Check to see if there's something stuck inside the pump or the drain hose connected to the pump (pump is usually located at the bottom and towards the back of the washing machine).
2. Water Pump
If the drain line isn't clogged, you may have a problem with the water pump such as a frozen pulley or a broken impeller. If that's the case replace the water pump. Note: if you have a belt driven washer, check the belt(s) for cracks, as this would be a perfect time to replace the belt(s) if needed.
3. Drain Filter
Check the drain filter for clogs as well. This filter can become clogged overtime, preventing the free flow to exit the drain tube. It is located inside the unit, mounted on the pump housing.
**The most common issue will be an obstructed hose or, line
NOTE-If the hoses filter,and pump check out ok, this will confirm that there is a serious within the actual control sector(Timer module or control board). It should be replaced i this case.
Nov 02, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Front loader, will not spin at high speed drain
Drain strainer on output side of pump could be clogged a little.
Sep 11, 2009 | Frigidaire ATF6000ES Front Load Washer
Kenmore 43142 Front Load Washer Logo
80 people viewed this question
Sal De
fordexpert
Whirlpool
Whirlpool
