I've developed a barcode scanning application using vb.net 2008. it has one sqlce 3.5 database file having barcodes in table. in debug mode i'm able to cconnect my db.sdf file once for reading records and filled the datagrid. after closing the connection, i'm unable to open the database faile again, untill and unless i warmboot the MC1000 device. Please help me out professionals.
SOURCE: Symbol LS 4278 Barcode Scanner - 3 Clicks
Does it beep each time you pull the trigger while the beem is on the barcode?
SOURCE: Scan button do not function
open the OTL program.
go to 1 - Test Apps
go to 6 - Next Page
go to 1 - Auto Wedge On
do the tests now ;)
SOURCE: Symbol PDT 8100 and I2of5 barcode reading problems
Normally I2of5 comes disabled as default in wavelink software.
You will need to enable it and if you are scanning barcodes of different legths, set both the maximum and minimum to 0 value. This will allow any length.
If you still have problems, get back in touch with me and send me a sample barcode as I have a verifier which will allow me to determine whether there may be a problem or not.
SOURCE: Types of Barcode that can be scanned using Symbol MC9090
It can read all standard symbologies apart from PDF symbologies unless it is equipped with an imager scan engine.
