Question about Panasonic NN-S953 Microwave Oven
Panasonic NN-S953 Microwave Problem
When in use, the light starts to dim in and out then the microwave stops itself prematurely. Help!
  • Panasonic Master
  • 8,793 Answers
Re: Panasonic NN-S953 Microwave Problem
It sounds like a problem with the inverter, control unit (circuit board) or high voltage transformer. I would recommend first that you (or a servicer or electrician) measure the actual line voltage at the outlet. It may be too low, or you may have a tarnished breaker or bad connection between the breaker and the outlet. Then try something like a toaster or toaster oven in that outlet and see if it toasts bread properly. Toasters consume a lot of current, so they are good load testers for outlets. Another good test is a hair dryer. Due to the lethal voltages involved, I do not recommend that a person without training and experience ever work on these models. You should be able to locate a Panasonic-authorized servicer here: I would mention the exact symptom when you call so the technician can bring a new inverter with him when he comes out to repair it. Might save you having it pulled into the shop. Also, you can save about $50 by removing it from the wall and taking it to the shop. It's really a two-person job for safety's sake, and having the original installation info helps a lot. If you still have questions, please feel free to follow up. I appreciate your thoughtful ratings to my reply.
Posted on Oct 05, 2007
0 characters
3 Points
Panasonic NN-H665BF starts and will run for about 5 seconds and then stops without heating up anything.
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101 [
Aug 07, 2011 | Panasonic NN-S541 Microwave Oven
My Panasonic Microwave NN-T573SBBPQ cuts out after 3 seconds. what can I do? Or am I better of replacing it?
This sounds like a magnetron problem, if it gets to hot, there is a special thermal fuse that will open up if it senses abnormal temperature rise from the magnetron and after a cool down period it will reset itself. In rare cases I have known the thermal fuse to become defective and cut out prematurely. My feeling is replace the oven! because by the time you get a appliance repairman in for a sevice call and parts you probably could have bought a new microwave oven.
Jan 19, 2011 | Panasonic NN-T990SA Microwave Oven
Fuse keeps blowing Found out we shouldn't have it
A 20 will work but I would change it to the correct on as soon as possible...
Sep 07, 2010 | Panasonic NN-S953 Microwave Oven
It is actually NN-T695SF, it will not warm food. It powers up then goes dim, then powers up then goes dim, it keeps doing that. Food comes out cold.
Hi, if it is an inverter microwave and the problem is cycling every 2-3 seconds, my experience is the magnetron has most likely gone short circuit and the inverter board is shutting down to protect itself and then restarting, hence your symptom.
DO NOT try to test this unless you are experienced with extra high voltages - the voltages present/stored in a microwave even when powered off can kill you.
Aug 13, 2010 | Panasonic NN-T694SF Microwave Oven
Microwave starts and then shuts off before anything heats up, before one minute, any ideas?
its a wiring problem. If its newwer you should haev a warranty on it, if not be better off taking it and throwing it away to be honest.
Feb 11, 2010 | Panasonic NN-S953 Microwave Oven
Panasonic NN-T994SF Microwave Oven quits after 15 seconds
my microwave shuts off after a few seconds. is there a fuse that needs replacing?
Feb 01, 2010 | Panasonic NN-T994SF Microwave Oven
Stopped heating, shuts off before time expires
My panasonic microwave model # NN-S540BFW stops after 4 seconds after you hit the start button and cuts off on its own. What is wrong with my microwave?
Jan 12, 2009 | Panasonic NN-S763BF Microwave Oven
H97 is a problem with the inverter, bad magnetron or control panel.
Due to the lethal voltages used and produced, I do not recommend that an inexperienced person work on these.
I would recommend that you contact your nearest Panasonic-authorized servicer. You can find one here:
We're happy to help and we appreciate your thoughtful rating of our answer.
Dec 13, 2007 | Panasonic NN-S953 Microwave Oven
Stops cooking prematurely
In most cases, this is a problem with the inverter or a bad magnetron.
Nov 21, 2007 | Panasonic NN-T964SF Microwave Oven
Panasonic NN-S953 Microwave Oven Logo
102 people viewed this question
Top Panasonic Microwave Ovens Experts
William Miller
William Miller
Are you a Panasonic Microwave Oven Expert? Answer questions, earn points and help others
