Question about RCA P60921 60" Rear Projection Television
Phillips 54s915 6904
The power comes on but there is no picture. The sound comes on one side of the speaker , and the front panel controls do not work.
    Genius:
  • 1,153 Answers
There are a few reasons that pic goes out on this set. First convergence problems, meaning amp need changing, but most of the time it gives you some kind of indication before it goes out, like color problem converg. not ligning up. Second it could be verticle output gone out. This is a 7 pin IC located at back of set on heat sink. Third the sound amp is going out. This could be an indicator but most of the time you don't have any sound. But still could be a problem
Posted on Aug 21, 2007
SOURCE:
I have a 32" PHILLIPS Flat Panel TV it has a picture and no sound regardless of source.
Check if there is a function for hearing impaired or captioning. also if you are on satellite your dish may need to be re aimed. Or maybe you have HD selection issues. I checked on my controller. it is all in the menu button selected area.
Dec 18, 2014 | Televison & Video
My hyundai plasma turns on, but has no sound or picture. It's a 2006, Model E420D.
Power supply is likely but if master power and not just the regular on off has to be used set is having a control problem. Power supply would be first place to look---even if green light remains no sound might mean control (main board) or power supply issue.
Nov 05, 2012 | Televison & Video
How do you remove 2001 mazda 626 factory amp?
  • 1 Open the hood and remove the negative battery cable from the car battery. Use an adjustable wrench to loosen the cable clamp, if necessary.
  • 2 Remove the manual shift knob from the central panel by unscrewing the knob and then lifting it away. Pry the gear shift trim from the central console and then remove the Phillips screw.
  • 3 Remove the side panel to the console holding the radio at its base in the foot-well on the driver's side. Grasp the panels at the front corners and pry them from the console. Remove the single Phillips screw. Repeat the process with the panel on the passenger's side.
  • 4 Pull the center console backwards slightly from the front console of the car, revealing the bottom of the radio/climate control assembly. Remove the two Phillips screws securing the radio to the console and then pull the radio from its cavity in the front console. Unplug the speaker wires, the antenna lead, the power cable and the amplifier cable from the rear of the radio as you pull it away to remove it completely.
  • Apr 13, 2012 | Car Audio & Video
    Rear panel for a mitsibishi montero speacker removel
    1Lift the rear seat all the way up and towards the front of the vehicle.
  • 2Remove the five Phillips screws holding the scuff plate at the rear opening of the vehicle. Remove the scuff plate.
  • 3Use a panel tool to pry off two screw covers on the edge of the headliner in the cargo area. Remove the Phillips screws located behind each of the covers.
  • 4Pull the carpet away from the edges of the rear-side panel. Remove four Phillips screws located below the carpet at the bottom of the rear-side panel. Remove the two Phillips screws holding the cargo cover hooks located on the rear-side panel.
  • 5Pry around the bottom and back edges of the rear-side panel and pull the panel out far enough to access the speaker.
  • 6Remove four Phillips screws from the edge of the speaker with a Phillips screwdriver. Pull the speaker out of the door and unplug the wiring harness connected to the back.
  • Nov 12, 2011 | 1995 Mitsubishi Montero
    How do I replace speakers on a 1994 xj6 ?
    Replacement of Front and Rear Door Speakers
    Required Tools:
    #2 Phillips Screwdriver (magnetic tip is useful)
    9 mm Nut Driver
    8” or 10” Flat Tip Screwdriver
    Small awl or other sharp pointed instrument
    Soldering Iron w/solder or 8 to 10 small wire **** splices
    8 to 10 small machine screws -- #8 x ¾” or equivalent 8 to 10 small machine screw nuts & flat washers to match
    Thread locking compound “Loctite” (optional)
    6” wooden dowel of ½” diameter to be used as a drift
    Small mallet or hammer
    1) Whenever you are attempting to a remove door panel to gain access to the speaker, or any other electrical component, absolutely disconnect the negative battery cable. Battery power is supplied to each door window motor and it’s always prudent to de-energize these circuits before you attempt any panel work.
    2) XJ40 door inner panels (front or rear) are comprised of an upper and lower section, which interface to provide complete inner door coverage. Neither panel is difficult to remove nor are any specialized tools required.
    3) Remove the Upper Inner Door Panels as follows:
    It’s a good idea to store all the removed parts and screws in the adjacent foot well for safekeeping and easy access when you are putting everything back together.
    a) Using a small awl (or equivalent), remove the small “square” plastic cover for the inner door lock release mechanism (upper right side when facing inner side of door). It pivots towards the front of the car.
    b) Using the #2 Phillips screwdriver, remove the inner door lock release mechanism plastic / chrome escutcheon. It’s held in place by a single machine screw. Pull out on the door lock release mechanism and the escutcheon is easily removed.
    c) Using both hands, pull out on the wood veneer panel at the inner door lock release mechanism to provide clearance and slide the panel towards the front of the car. The panel is secured on the left side by slip-in clips and they release easily.
    d) Using the #2 Phillips screwdriver, remove the two sheet metal screws on the left side. For the front doors only, lift the bottom of the rubber ventilation boot at the front edge of the door and remove the sheet metal screw. Additionally, for the front door only, use the large flat screwdriver as a lever to ease out the single “fir tree” type press-fit connector. Neither of the rear doors contains these two additional fasteners.
    e) Using both hands, lift the upper inner door panel until it releases from the metal ridge along the window line. It doesn’t take much effort to remove the upper panel as it slides off vertically. Store it on the seats for safekeeping.
    4) Remove the Lower Inner Door Panels as follows:
    a) Using the #2 Phillips screwdriver, remove the sheet metal screw located at the upper edge of the lower panel.
    b) Using a ½”small wooden dowel or equivalent drift, place it under the lower edge of the door handle screw access cover. Lightly tap each end of the access cover using the dowel and mallet in an upward direction to release the access cover. These covers can be tight if they have never been removed in the past, but they will release.
    c) Using the #2 Phillips screwdriver, remove the sheet metal screw located in the middle of the door handle.
    d) Using a small awl or equivalent, remove the bottom door light lens by releasing it from its locator at the rear and sliding it outwards from the door.
    e) Using the #2 Phillips screwdriver, remove the lower panel securing sheet metal screw located in the middle of the bottom door light assembly. All sheet metal screw fasteners for the lower panel are now removed.
    f) Using both hands (and the large flat screwdriver, if needed), carefully pull off the lower inner door panel by release the series of fir-tree type press-fit connectors along the sides and lower perimeter. Once the panel is removed, it can be laid horizontally on the seat as there is sufficient length of wire bundle to allow this movement. It is not necessary to disconnect the wiring harness, but if desired, the connectors can be released so that the panel can be moved to another more worker friendly location.
    5) Remove Door Mounted Speaker as follows:
    a) Disconnect the speaker positive and negative conductors by releasing the electrical connector.
    b) Using the 9mm Nutdriver, remove the speed clip nut from each of the four (4) speaker fastener studs. Press the nutdriver down firmly to engage the speed nut … do NOT cut away any foam material as it is not necessary.
    c) Using the #2 Phillips screwdriver, remove the sheet metal screw immediately to the left (driver side) or right (passenger side) of the speaker as viewed from the back side of the door lower inner panel.
    d) Using the #2 Phillips screwdriver, remove the sheet metal screw immediately above the speaker. It is located just below the upper sheet metal screw securing tab on the lower panel … the screw was previously removed in Step 4a.
    e) Using the #2 Phillips screwdriver, remove the sheet metal screw immediately to the lower right (driver side) or lower left (passenger side) of the speaker as viewed from the back side of the door lower inner panel.
    f) Using the #2 Phillips screwdriver, remove the sheet metal screw immediately to the lower far right (driver side) or lower far left (passenger side) of the speaker as viewed from the back side of the door lower inner panel.
    g) Steps 5c, d, e and f will release the speaker / window lift pushbutton panel from the lower door inner panel. Removal of the sheet metal screws will allow the speaker panel to be pulled away from the lower panel by 3” to 4” to facilitate access for speaker removal.
    h) With the speaker / window lift pushbutton panel eased back for working clearance, grasp the speaker with one hand while pressing the four (4) speaker studs downward through the foam supporting material. After the studs are clear from the foam material, the speaker can be removed from the panel.
    6) Install New Door Mounted Speaker as follows:
    Typically, base XJ40 models use 3.5” door speakers while the VDPs will use 4” door speakers. Though I believe it is possible to mount either type in either model.
    a) Using the wiring supplied with the new speakers and insulated solderless **** splices, transfer the old speaker wiring electrical connector to the new speaker. Another alternate method is to simply solder the old speaker wires with connector to the new speaker terminals. This is a superior method for electrical continuity and strength of joint … although it does require some soldering skills.
    b) Install the new 3.5” speaker by easing back the speaker panel and sliding in the new speaker. Normally, the 3.5” models will mount with only two fasteners.
    c) Using two of the small machine screws with flat washers, place these fasteners through the speaker mounting lugs and press them up through the existing holes in the foam supporting material. Secure the screws with flat washers and matching nuts from the back side of the inner door panel. The use of thread locking compound (Loctite) is a nice touch to prevent loosening due to vibration.
    d) Re-install the sheet metal screws removed in Steps 5c, d, e and f. This will re-mount the speaker panel. Don’t forget to re-connect the speaker wire connector at the door panel.
    7) Re-installation of the inner door lower and upper panels is literally a reverse of the removal procedure. No hidden tricks.
    8) Perform Steps 3 through 6 for the other doors and the job is complete.
    9) Remove Rear Footwell Mounted Speaker as follows:
    This sequence is good for both 4” and 5.25” footwell mounted woofers.
    a) Using a small flat screwdriver as a lever, carefully ease off the grill.
    b) Using a #2 Phillips screwdriver, remove the four (4) sheet metal mounting screws.
    c) Ease out the old speaker and release the electrical connector for the speaker wires.
    d) Transfer the old speaker wires and electrical connector to the new speaker using solderless **** splices or by soldering the old leads to the new speaker terminals.
    e) Re-connect the speaker wires to the harness by joining the electrical connector.
    f) Mount the new speaker and re-attach the necessary sheet metal screws.
    g) Press the speaker grill into place.
    h) Repeat Steps 9a though 9g for the other footwell speaker.
    Mar 10, 2010 | 1994 Jaguar XJ6
    Loud humming sound while drying, need instructions on disassembly to properly diagnose
    Disconnect power to dryer. Open door, remove phillips screw from 4 and 8 O'Clock positions, close door. Use putty knife (preferably a plastic one to prevent scratching) to push in the two clips holding the top to the front panel, then swing the top back, revealing the phillips screws holding the front panel onto the body of the dryer. Remove them and un-hook door switch and drum light connections, allowing total removal of dryer front panel. Remove 4 phillips head screws retaining front drum support and lift it up just a bit to remove it. Reach back under drum to the left side to release belt, allowing drum to come out of dryer.
    Jan 29, 2010 | LG DLE2532W Electric Dryer
    Can't get the surround sound to play the rear speakers and small front speaker
    Sounds like it's just in 2 channel stereo mode, only 2 speakers working out of 5 and a sub, look for a selector switch for switching to 5.1 surround, as far as the no video problem try replacing the cable for the video connection.
    Aug 04, 2008 | Panasonic Home Theater System System
    Popping sound and picture goes out
    Sounds like the flyback or the picture tube. Either items can cause this. If the pop comes from the rear right side its the flyback. If the sound comes from the lower front behind the speaker grille its the tube. Let me know what you discover as I have access to any of the parts you would need.
    Mar 10, 2008 | Philips 60P8342 60" Rear Projection...
    Phillips 427220a
    After you remove the back cover inspect the power supply board for swollen or bulging capacitors. Pull and check any capacitors that you suspect to be swollen. Next, look for a sticker in the upper right hand side of the TV set. Use the values you find on the sticker to calibrate the voltages on the power supply board.
    Mar 08, 2008 | Philips 42PF7220A 42 in. Plasma Television
    RCA P60921 60" Rear Projection Television Logo
    83 people viewed this question
    Top RCA Televison & Video Experts
    Steve Allison
    Steve Allison
    matt martin
    matt martin
    Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
