Question about Amana ARGS7650SS Gas Kitchen Range
Amana ARGS7650SS problem
Everything works well for about an hour. If the oven is in use for an extended period of time (1-2 hours) it turns off and the clock begins blinking. No fault codes are shown. Once the oven has cooled down and the clock reset button is pushed, it operates fine again, unless the baking period is an hour or more. How can I identify if it is a faulty temperature sensor? Replacement is easy. How can I identify if it is a faulty Electronic Control Panel? And where would I find installation assistance? I can't figure out how to remove the Panel? Thanks!
  • 5 more comments
  • Anonymous Jan 15, 2008
    I am having the same problem. Since my range was new, I have never been able to cook a Christmas or Thanksgiving turkey dinner!!!! Fine for an hour or an hour and a half.....shuts off and I have had it serviced three times (every other year when my turn to do turkey dinners).....cosltly and frustrating!!!! I was each time told it was the ignitor.....paid to have the ignitor replaced only to have same problem following useage for more than an hour!!!!..couldn't do Christmas dinner fully this year (used my neighbours oven.....for 30 people).....very upset. Called to report the problem and followed up with a detailed letter and every receipt for repairs.....waiting to hear.
  • Anonymous Mar 12, 2008
    The oven turns off after and hour of operation when the oven reaches more than 350 F degrees. The control panel turns off.
  • pet_dr2b Jul 07, 2008
    I have the same problem. I bought a house with this range in it already and when I was baking the oven just shut off, then the blinking thing started, and I could restart. But it really messes things up. Any help as to what the real problem is? I don't want to buy a new range if I don't have to.
  • Anonymous Aug 17, 2008
    I HATE this oven what a piece of junk in a shiny stainless steel case. Had to have costly repairs two times already, and now a loud pop and the oven shuts off. Top works, but not the oven. The other day it comes on and so I tried to bake, and it just flashes an F3 with loud beeps. Arrrrghhh!!!
  • Anonymous Oct 10, 2008
    My repairman measured the OUTSIDE of the oven because mine heats too and shuts off - the whole display panel goes blank - the OUTSIDE temp was 197 degrees! It's melting itself! I would like to know what kind of safety hazard that is and if Amana is going to replace my oven - of course it's 6 months out of warranty...
  • steve151971 Dec 26, 2008
    Oven runs for a short period of time and then the control panel shuts down. The gas cooktop always works properly. The control panel seems unusually hot. After a period of time it comes back on. Sometimes it works well at all times. Not sure where to start. Please advise. Maybe an insulation panel for the control panel?????
  • danbp1 Feb 06, 2009
    After baking for a longer period of time, eg. a turkey the oven panel just goes blank and the oven turns off
  • 625 Answers
Try this site - repairclinic dot com. there are some helps about where the screws are to remove the control panel.
Posted on Aug 21, 2007
Oven door will not lock at self clean, I get F-9 error code. This happened after wife tripped into door when open. Is this an adjustment or do I need a locking motor?
Hello there:
This code is a common
F9 Problem with door lock circuit such as pinched wire between Electronic Range Control (ERC) and door lock switch Check wiring and test operation of switchif the latch is alright unplug the oven for 1 hour and the internal reset device will reset the oven then plug in the oven and it should be all right
Sep 27, 2010 | Amana ARGS7650SS Gas Kitchen Range
Oven not heating to desired temperature
You will have to place a amp meter over one ignitor wire and turn the oven on to bake.
If the amp draw is 3.3 amps or less,replace the ignitor.
Jul 11, 2010 | Amana ARGS7650SS Gas Kitchen Range
I have a matag cre9600cce, the oven heats, but very slowly and not all the way. i set it to 350 and after an hour it is only at 210
the cre is elect so look for one of the elements not working / ( bake ) is probably is out . and the pre heat is only from the top element .. / test by open door ser to bake bottom element should go red / then set broil and it to should turn red . the one that does not repl .. mm
Dec 12, 2009 | Amana ARGS7650SS Gas Kitchen Range
WHEN THE OVEN REACHES A CERTAIN TEMPERATURE, EVERYTHING SHUTS OFF. THE DIGITAL DISPLAY GOES BLANK. THE ENTIRE OVEN SHUTS OFF. WILL WORK AGAIN WHEN IT COOLS DOWN.
I had this same problem...I needed to replace the digital pad, cost about $200 online and took about an hour to replace. The heat from the oven wears out the electrical components in the pad...good luck!
Sep 29, 2009 | Amana ARGS7650SS Gas Kitchen Range
Amana gas oven not working
SOUNDS LIKE U HAVE A WEAK BAKE IGNITIOR REPLACE THE BAKE IGNITIOR IT WILL SOLVE THIS ISSUE
Aug 31, 2009 | Amana ARGS7650SS Gas Kitchen Range
It has only heated up about 70 degrees in one hour. what is wrong with it?? it is warming up, but wayyyyyyy toooooo slowly!
remove the oven floor and turn on.look for the orange glow of the ignitor.within 30-60 seconds the burner should fire .if not, ignitor is weak(drawing less than 3.5 amps) and should be replaced.Hope this helps ,please rate my solution :)
Jun 25, 2009 | Amana ARGS7650SS Gas Kitchen Range
How long do i self clean my oven
minimum 3 hours.. anything less and oyr wasting your time.
Mar 02, 2009 | Amana ARGS7650SS Gas Kitchen Range
F2 on Amana ARGS7650SS
well the f2 code on an amana is an over overheat fault code. the best thing to do is replace the oven temperature sensor.
it looks like this
http://www.partselect.com/xq/aspx/Inventory.1508183/qx/PartDetail.htm?SourceCode=5&ModelNum=ARGS7650SS
they cost around 40 dollars but that should eliminate your problem
Jun 20, 2008 | Amana ARGS7650SS Gas Kitchen Range
Amana ARGS7650SS Gas Kitchen Range Logo
456 people viewed this question
Top Amana Kitchen Ranges Experts
Sal De
Paul Carew
Archie Ferrarini
Archie Ferrarini
Are you an Amana Kitchen Range Expert? Answer questions, earn points and help others
