Question about Sony KV-35S36 35" TV
TV shuts off and red standby/timer lights blinks red until I power the set off. When it shuts down it does so with a very loud snap. When I turn it back on the screen is blue and has light blue horizontal lines. It usually has sound. Within in seconds it will shut down again. The set is 7 years old and works great except for this problem. When it was 2 years old it was in the repair shop with this same problem and it cost almost $300. Within six weeks it was again having the same problem but stopped and worked fine. It can go for months without shutting down. It has been inoperable for 4 hours at this time. At one point, 3 hours, I had a picture and then is shut off again. Any suggestions on how to repair would be appreciated. Also, an estimated cost would help determine whether to repair or replace.
  • 398 Answers
The most common cause for what you are seeing is a shorted gun in the picture tube. When 2 elements (heater and cathode) of one of the guns inside the neck of the picture tube touch, that gun goes full on and overloads the flyback (high voltage) transformer. If it is in the blue gun, the screen will go bright blue with light blue "retrace" lines in it. The computer senses the overload and shuts the set off. At 2 years old the tech most likely tried removing the short by arcing between the elements. This works sometimes but the short often comes back a few months later. Another attempt at removing the short could be tried, and it might work this time, but it may or may not work for long. The ony other solution is to replace the picture tube but that would cost much more than the set is worth. A qualified tech will be able to tell you if this is the problem in your set.
Posted on Aug 21, 2007
TV turns red,shuts off, stand-by light blinking 8Times
Eight blinks - Problem with the audio (AUDIO), unit goes to standby and blinks the self-diagnosis code. Check IC406 audio amp, PS401, and 402. On some projection models of Sony TV sets, this code means that T8005 (flyback transformer), or the associative components in the high voltage circuits are defective on the D board.
Feb 27, 2014 | Sony KP-51HW40 51" Rear Projection...
Klv 32s200a
There are two things you can try. Press "Sleep" until you see "off" appears. If this doesn't fix the problem, go to the "Eco" settings and set "Power Saving" to "Off", set "Idle TV Standby" to off, and "Auto Shut Off" to "off". I hope this works for you.
Sep 20, 2013 | Televison & Video
My Sony wega tv won't turn on goes into standby red light blinks 10 times then shuts off?
Look at the owner manual as the 10 blinks is a error code or Google the model number to locate that information--Sony error codes are general and often misleading.
I would if looking at the set inspect the lamp first.
Aug 28, 2012 | Sony Grand WEGA KDF-42WE655 42" Rear...
My sony kp-51ws510 color rear video projector tv when i turn it on it stays on for abt five seconds and then turns off and also the timer and standby light is flashing red
this model did have problems with bad picture tubes---screen goes bright red,green,blue and set shuts down.
set also does this to protect itself---when fails look to see if specific sequence of blinks
Apr 17, 2012 | Televison & Video
Sony TV shuts down
check for D616 open or Q603 short.
sometime D501 leaky.
Apr 22, 2010 | Sony FD Trinitron WEGA KD-36FS130 36" TV
Sony rear projection screen is red then tv shuts off
Can be 1 of 2 things. 1st the red tube just needs the voltage to it turned down. In the front of TV (you have to remove the lower front half of TV to access it) is a plastic square with 6 knobs. The from left to right top knobs control focus for blue,green red. The bottom knobs control voltage to each tube in same order (so lower right knob for red) turn SLOWLY to left to reduce voltage until excessive red and lines go away. If you over turn left or right set will turn off. If that does not fix it or if lines reappear then option 2 is that red picture tube is failing outright and needs replacement.
Jan 29, 2009 | Sony KP-57WS500 57" Rear Projection...
Tv acts like its going to turn on, but then shuts back off
sounds like high volt arcing. i would get it checked out pronto could do much more damage if it is hv arcing.
Dec 13, 2008 | Sony FD Trinitron WEGA KD-36FS130 36" TV
I have a sony wega
Generally speaking whent he set shuts itself down, the standby light will blink a code. This will be a count followed by a short pause and then the count again etc.
When teh set shuts down, count the blinks and post it here. That will indicate the circuit that has the problem.
Dan
Dec 05, 2008 | Sony FD Trinitron WEGA KV-36FS120 36" TV
TV won't turn on, red lights blinks twice.
The blinks can tell you the problem , is it 4 blinks that could be 3 different ics IC1509 Q1505 or IC502
Aug 06, 2007 | Sony KV-32FS13 TV
Televison & Video Logo
154 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
