Question about Haier 42EP24S 42 in. EDTV-Ready Plasma Television
Hdmi/dvi we bought the hdmi/dvi cable to hook up our cable box to our tv and we cant get any sound.
  • 944 Answers
Here is the link to the user manual for the TV if you need it; Check page 7 - The DVI input has next to it an audio input - DVI does not carry audio as HDMI does - you need to plug a seperate mono audio cable from your cable box to the TV at the DVI Audio input (top of page 12). The Audio needs to be in the one next to the DVI socket in order to work at the same time as the picture from the same "source" selection. Check page 18 "CATV Type" and make sure this is set to the correct one for your cable box Check page 21 that all the audio settings are logical and nothing is turned right down or muted. If none of this helps then please post back. What make and model is Your Cable box? Hope this helps :)
Posted on Aug 21, 2007
What's your problem?I just purchased a I just purchased a Sharp LC32SV40U. I'm trying to hook it up with my Shaw Direct DSR 505 receiver (DVI to HDMI. I cannot find how to get sound using this
When using this type of adapter you only feed video into the TV/monitor
you have to use a separate set of RCA audio wires to feed the audio into your tv.
Nov 24, 2012 | Sharp Televison & Video
What type of cords do I need to hook up a akia PDP4273m1 to my cable box
Which cable box are you trying to connect to the PDP4273m1? The best choice of cable will depend on the outputs available on the cable box. If your cable box has HDMI (looks like a rectangle with small cutouts on one long side) out, get an HDMI (type A on both sides) video cable and connect it between that port and the TV's HDMI in. (This connection doesn't require an extra audio cable.) If your cable box has a DVI (out, get a DVI to HDMI adapter and the HDMI cable (or a DVI to HDMI cable). Connect the DVI side to the cable box and then the HDMI cable to the TV Then get an RCA audio cable (two male ends on each side, usually red and white). Connect this to the audio out jacks on the cable box and to the DVI audio in ports on the TV.
If you do not have either of those outputs, check for a component video/audio output. Get the component video cable (with 3 RCA plugs on each end - red, blue and green) and an RCA audio cable. Match the colors on each side as you connect the devices.
If those aren't available, the S-video or composite video cables will work. The composite video cable comes with the audio connectors (red, white, yellow RCA plugs). They aren't part of the S-video cable and must be obtained separately. These are limited to standard video (no HD) so they are not the best choices with your tv.
If your cable box has SCART out, you will need an adapter for that. Most provide composite or S-video out. See for one of these. Note: you will need to match the adapter to the CART output or get a converter.
The connections should be from the left side: serial port (RS-232 for service), HDMI, digital audio out (for connecting to a home theater receiver), DVI audio In, two component video and audio in, a composite video/audio in and out and an S-video with audio in. The manual for the PDP4273M1 is available from Retrevo here: . You will need to enter a code to download the manual.
i hope this helps. Please add a comment with your cable box make/model/provider if you want more help.
(very few TVs come with the A/V cables these days. Some set-top boxes will come with the composite video cables.)
Jul 15, 2012 | Televison & Video
This may be an impossible problem to solve..we just got a Hitachi 51m200 rear projection tv. it does not have an hdmi slot although the tv says it is dvi-hdtv and our cable box is hdmi output. so if i get...
It isn't impossible at all. You may need a sound bar if you don't already have a Bose surround sound system or a boom box or something else you can use without purchasing anything. On the hdmi/dvi televisions and cable boxes of the recent past there would always be an accompanying white and red composite/RCA slot (output on the cable box, input on the television) to accommodate this. You would simply connect the hdmi to dvi cable from the television to the cable box and then the red and white audio cable. If your television and cable box does not have the red and white composite/RCA audio input and output you will need to connect the cable box to an external audio source. How to do it and what to connect it to depends on what audio output that is on the cable box (usually is on the back of it). You might need a fiber optic cable and a sound bar with a digital audio input if you have a newer cable box.
Sep 28, 2010 | Televison & Video
No sound when hooking up DVi to HDMI...
This is normal, when you go from HDMI to DVI, the sound does not get transmitted. You need a separate cable to go from audio output on the computer to Audio input to the TV. There are speaker (headphone on laptop) jack to RCA audio cables, you could also go with digital audio or even optical out if your computer and TV both have the input and outputs.
Oct 05, 2009 | Sony Grand WEGA KF-42SX300 42" LCD TV
Hdmi to dvi connection
settings you need to change the Display Adapter option, can be set as dual mode or, access the control panel and find the display settings
Jul 22, 2009 | Dell Inspiron E1705 Notebook
DVI-HDMI work but there is no sound
DVI input has no sound as normal you can use a RCA connection to get sound from the freeview box
Apr 21, 2017 | ViewSonic N3000W 30 in. HD-Ready LCD...
Samsung hlr4667 dlp \ no hdmi connectivity
No, when I bought my new plazma tv, and unhooked my old DVR box, I had to go to my cable provider and inform them. they sent a signal and WHAM I was back in Biz.
Nov 10, 2008 | Samsung DLP HL-P4663W 46" Rear Projection...
HDMI->DVI cable won't work
Are you using a HDMI to DVI cable or are you using a HDMI to DVI adapter? Sometimes, though not on all products you have to go into the menu and select which out put your using for each source and whats going through it. You might need to go into your dvd player menu and tell it not to try to run audio through the cable. That way it's not trying to force a signal through the cable that cant be accepted by the TV. That might possible solve your problem for the DVD player. Let me know if it works
Have a Great day
Aug 11, 2008 | Televison & Video
Hdmi and audio
It may be the top of set box.. Most times the sound and picture are auto detected by the set when HDMI is used. Both sound and video are carried in a HDMI cable but not with a S video cable. Try another HDMI cable *** dont buy the expensive one the tv don't care if they cost $125 or $25.
May 23, 2008 | Insignia 37" LCD Flat-Panel HDTV
No sound through ps3 hdmi
hi i had a problem, but had no pic, but did have sound, rang sony, and they said buy a new hd cable, went out and bought one, and it worked fine!!!
Jan 08, 2008 | LG 42LC2D 42 in. LCD HDTV
Haier 42EP24S 42 in. EDTV-Ready Plasma Television Logo
288 people viewed this question
Top Haier Televison & Video Experts
Jaime Hernandez
Are you a Haier Televison and Video Expert? Answer questions, earn points and help others
