Question about Tomtom GO 700 GPS NAVIGATION BRAND ONLY $9.95 SHIPPING
Connecting speakers I have a qsc rmx 1450 amplifier and i have to pair of speakers, one pair is 8 ohm and the other pair is 4ohm. Questions 1. Can I connect the 8ohm pair to one channel and the other 4ohm pair to the other channel ? 2. How should I connect them in series or in parallel ? Thanks JPDuque
    Scholar:
  • 98 Answers
I have never heard of this brand of amplifier.. but NEVER hook up unequal ohm loads to a amplifier. the only way i could think to do it would be to hook up 1 of each sub on each side... what way you are spreading out the ohm load equally on both sides but again if you dont do your math and you run too low of a ohm load you WILL smoke that amp..
Posted on Aug 21, 2007
How do i set the switches on a qsc rmx 1450 power amplifier
All off, except The "Clip Limiter" Those should be on for your speaker protection.
Sep 14, 2013 | Audio Players & Recorders
Not putting out sound fan on light on
A common issue with the QSC RMX series amp is faulty volume pots, so i would recommend go this way first of all, let me know a bit more to improve help.
Feb 04, 2013 | QSC Audio Products QSC RMX 850 RMX850...
Amp 5050 rmx stay in clip mode
Disconnect speakers. With NO input, if clip light remains on, take in for repair as there is an internal failure. If reducing the gain and loudness keeps the clip off, then you are probably driving the amp too hard. This is common problem when the user "thinks" they need it louder but the amp speaker combination will not deliver louder. At this point, both the amp and the speakers are at risk of permanent damage requiring repair.
Sep 22, 2011 | Qsc Plx-2502 450w Per-Ch. 8 Ohms Amplifr...
I have a plad213 what load impendance am i running it i hook up 2 4ohm speakers in series bridged on that amp and how many watts RMS am i getting per speaker
2 4 ohm speakers wired in series is 8 ohms and then is dropped back down to 4 ohms when you bridge it.
2 4 ohm speakers wired in parallel is 2 ohms then dropped down to 1 ohm when bridged
(most amplifiers will not handle loads below 2 ohms)
hope this info helps
May 20, 2011 | Pyle Dryver PLAD213 Car Audio Amplifier
Im a dj and i keep blowing one channel on my amp it has happened on a 3 differant amps now
Hi.
Check speaker wiring. An amp final channel usually blows because of excessive draw from speakers. This often happens because one of the speaker is shorted inside or because of a wiring problem.
Also ensure that speakers are responding to specifications. Speakers that are out of the amp Ohms range will do the same thing in a while.
Naturally you can also blow an amp final by pumping volume to the max for a while. The transistors or the STK ICs in the final section will overheat and blow.
Regards.
Ginko.
May 30, 2010 | QSC RMX-850 POWER AMPLIFIER Car Audio...
4ohm speaker connected a normal 8ohm crossover is
This is a wrong conection.For 8ohm crossover conect two speakers in serie and one in parallel to one of a previos.Check resistans by multimeter
Dec 02, 2009 | Parts Express 80 Hz LOW PASS 4 OHM...
How to hook up 2 10 inch speakers
For best results the output resistance of the amplifier must equal the combined resistance of the speakers. So if the amps says 8 ohms and you have two 4 ohm speakers you put them is series or if the amps says 4ohms and you have two 8 ohm speakers put them in series. If it says 4ohm and you have two 4 ohm speakers best to use only one. It Depends on the output resistance of the amps. It is usually written at the terminals where the speakers are connected.
Sep 08, 2008 | Boss IQ 3KD.1 Car Audio Amplifier
Wiring
The T10001 can drive a load lower than 4 ohms. Wire the coils of the individual speakers in series to make each speaker 8 ohms. Then wire all 3 speakers in parallel and connect them to the amp. This will give you a 2.6 ohm load.
Dec 01, 2007 | Rockford Fosgate T10001BD- Car Audio...
Behringer ep2500 amplifier
Yes you can,,,,,BUT the output labelling on the AMP will tell you where you can connect the 4ohms or the 8ohms....please read these labels and connect the 4ohm speakers to the 4ohm terminals, and the 8ohms to the 8ohms terminals...
If you intend to connect the 4ohm and the 8ohm speakers in parallel then the output impedance terminals you use should be the 4ohm ones.
If there is no labelling showing any 4ohm output terminals then its best if you dont use the 4ohm speakers at all....just connect the 8ohm to the 8ohm terminals...you dont mention any crossover networks inside the speaker boxes or if you have tweeter speakers... so just stick to the basics above at present....
Cheers From YUBEUT
Oct 20, 2007 | Sunfire Cinema Grand Signature 400 seven...
Tomtom GO 700 GPS NAVIGATION BRAND ONLY $9.95 SHIPPING Logo
63 people viewed this question
Top Tomtom Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Tomtom Car Audio and Video Expert? Answer questions, earn points and help others
