Question about Mitsubishi WS-65807 65" Rear Projection Television
TV keeps resetting
While watching the tv, the screen will blank out and when it comes back the info will be flashed up in the usual spot, but the volume will be back down to a setting of 17. At times this will happen 2 or 3 times in a row. I've run the diagnostics in the set and it flashes 1-2 (which i believe means that nothing is wrong). I have hit the reset on it and while that seems to "fix" it for a short time, it clearly doesn't. I have also unplugged the set and let it sit for 30+ minutes, but as soon as it is up and running again, it starts up again. There doesn't seem to be any rhyme nor rhythm to when it occurs. Any help would be appreciated.
    Genius:
  • 1,153 Answers
Yes, 1-2 no error detected. Maybe intermediate problem don't register. Check for loose connection in Power supply, Maybe soldering around transformer or relay.
Posted on Aug 21, 2007
Got a Samsung dnie model code spp4251x/data tv when powering up the front light comes on but no picture or anything anyone got some good info??
tv seems to turn on but no picture? - Forums - CNET
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - ... Samsung Dlp TV (HLR-5067W) it seems like the TV turns on butthere is no picture. ... the lamp is, light is visible from where the lamp is located but no picture. DLP Twon't turn on, blinking green lamp light then shuts dow ...
Jun 11, 2015
Samsung Plasma TV - Won't turn on
Jun 11, 2015
The timer, lamp, and standby/temp. light are flashing?!
Jun 11, 2015
Samsung TV Keeps Shutting Down
Jun 11, 2015
More results from www.cnet.com
TV with Black Blank Screen Repair How to Troubleshoot ...
? 3:16
https://www.youtube.com/watch?v=kFdVi2ejfzA
May 8, 2014 - Uploaded by ShopJimmy.com
TV Repair Help for a TV With a Black No Image on the Screen ...I Have A Sanyo TV I Can Hear But Black Screen Im 14 And Dont Know What To Do ! .... power button the power light goes from red to green, the screen flashes on then goes black ....Troubleshooting LCD Backlight Failure Samsung LNT-4066 ...
Samsung plasma tv repair blinking light no picture ...
Jan 09, 2016 | Samsung Televison & Video
LED screen comes on and goes black
LG LCD TV REPAIR - NO PICTURE SCREEN FIX REVIEW ...
? 5:29
https://www.youtube.com/watch?v=PWoz_-3OHIM
Jan 25, 2013 - Uploaded by Tampatec
Common LG LCD TV REPAIR - NO PICTURE OR BLACK SCREEN FIX ... I have a LG 42PM4700-UB plasma tv that justwent black. The red ... I had to keep turning on and off the TVseveral times for the screen to come back.
LCD & LED TV Repair - No Image & Blank Black Screen ...
? 5:56
https://www.youtube.com/watch?v=xUzCLgoSPGM
Sep 15, 2014 - Uploaded by ShopJimmy.com
LED & LCD TV How to Diagnose Symptom of No Image on theScreen CLICK ... Tv was working fine when left to go to store and came back to blank picture and ... my samsung tv it turns on but its completely black and no sound at all ... LG LCD TV REPAIR - NO PICTURE SCREEN FIX REVIEW - Duration: ...
LG LED TV has no picture (black screen) but still sound ...
Dec 09, 2015 | LG 47LS4500
Screen goes blank while watching TV and playing DVDs
First thing to do is replace the cable with a new high quality one. They can go faulty. If that doesn't work, check that you are outputting the correct signals from your devices, plus it is set to pick them up. If that doesn't work you might have a fault possibly on the TV.
Mar 19, 2017 | Marantz NR1602
While watching tv the screen will go blank, sound
It might be a loose solder connection inside,try to prove it,the next time it goes blank,firmly give a whack to the back or bottom of the set,if it flashes back......sholud be a loose solder conn that a competent technician can find and repair
Jun 02, 2010 | JVC AV-32F704 32" TV
Our TV whiel watching has a blank screen the comes
needs screen adjustment. knob located on flyback transformer
Nov 15, 2009 | Sony FD Trinitron WEGA KD-36FS130 36" TV
TV SREEN GOES BLANK, BUT AUDIO CONTINUES NORMAL,
Try unplugging for 36 hours. I had the same problem but with no sound and picture
Mar 03, 2009 | Sony KP-53HS10 TV
HITATCHI ULTRAVISION P50S601...POWER LIGHT BLINKING...WONT COME O
The TV is on protect mode.
Try first leaving the TV power cord unplugged for some times, let say one hour or so.
Also ensure that the fault is not coming from a faulty receiver box sending bad signal, check if you get same problem with no receiver box or dvd connected.
If that does not work, and you keep having a flashing led on front of the TV, and tv turning off by itself after a while, that indicates a fault condition.
The flashing light indicates a diagnostic state called protection.
When the TV goes on protection there are only two possible reasons.
1The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or abroken contact, identified an internal fault and kicked in , startingthe flashing light.
If you are in situation one, then theTV will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
Common faults that can occur are a blown capacitor on power board, a convergence IC has blown, or a fault on Digital board.
Check also the video cable or any external connection cable, if the cable is shorting, or the connector is bad, you can get same flashing state because of the video cable.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
Feb 25, 2009 | Hitachi Ultravision P50S601 50 in. Plasma...
We have sound but no picture i have sound but no picture. when you change inputs the word input is doubled up and distorted
There were not much info in the manual but it did suggest trying this.
1st- Unplug for a few minutes and then plug it back in. Or use the reset button look it up in the manual. MANUAL
2nd- Blank screen troubleshooting
• If you're trying to watch TV, change channels or press the ANTENNA button to switch tuners.
• If you're trying to watch something that's playing on a component connected to the TV (like a DVD or a VCR tape), press the TV
button on the remote, then press INPUT until you get to the correct video input channel.
• If you're trying to watch a component (like your DVD player or VCR), make sure the component connected to the TV is turned on.
• If you're trying to watch a component (like your DVD player or VCR), make sure the component is connected correctly.
Post back if non of these ideas work and explain if there are any lights flashing or changing colors on the front where the green light usually is. A fixya rating would be appreciated, thank you for stopping by Fixya!
Feb 16, 2009 | Mitsubishi WD-62525 62" Rear Projection...
Heard a pop and screen went blank - won't come back on.
Your Lcd Projector Lamp/DLP Television Lamp went out
its about $165-$200 to replace if not under warranty
Nov 28, 2008 | Hitachi Televison & Video
Toshiba 43A61 - No Picture, no sound
If your set all of a sudden won't come on, e.g., the screen is blank, but the LED on the under the screen next to the on/off switch keeps flashing, then there may be an internal fault on the set that needs to be reset.
To force the reset, try this:
  • Unplug the set and wait a few seconds
  • Replug and see if the video returns
Whenever the set senses an internal fault through its monitoring circuitry, it essentially shuts down the set. The flashing LED provides the indication that a fault has been detected. Removing power to the set resets the monitoring circuitry. When plugged back in, the circuitry again does a check of the system. If it finds that there truly is a problem, then the set is shut down and the LED will again flash. In this case, you need to call a service tech. Most of the time, however, the unplug/replug routine is enough to get the set up and running.
Dec 11, 2007 | Toshiba 43A61 43" Rear Projection...
Open Questions:
See all Mitsubishi WS-65807 65" Rear Projection Television Questions
Mitsubishi WS-65807 65" Rear Projection Television Logo
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
