Question about JVC AV-27D104 27" TV
Brightness of picture
Colors are a little red, but even with bright all the way up, dark scenes, such as night scene, unable to see picture, all other settings seen normal even hues and color tones. Cannot get copy of service manual from JVC.
  • 398 Answers
If you feel good about opening your set then you can try this: Look for the flyback (high voltage) transformer, with the thick red wire which goes to the top of the picture tube. There are 2 controls on the flyback transformer, focus (top) and screen (bottom)Turn the brightness and contrast all the way down and then increase the screen control until you see retrace lines, and then back it down until those lines just vanish. Return the brightness and contrast to normal and adjust the focus control, if necessary, for a nice sharp picture. Let me know if that brings your brightness back.
Posted on Aug 21, 2007
Color is grate on my Sharp 26" TV. However night scenes have become almost too dark to see. I have tried to adjust the settings but no improvement. Is this a fixable problem? Using Comcast Cable a
Check 'brightness' and 'contrast' settings in (usually) 'picture' menu. Use a recording (DVD etc.) of a dark scene to adjust the picture. My TV (not Sharp) has several pre-programmed picture settings. If yours has that, maybe one of them will be good. Otherwise, use manual settings.
Oct 18, 2014 | Sharp Televison & Video
I have a vizio Vt470m....the picture has always been perfect. All of a sudden when picture shows scenes with very little light (dark scenes like at night, space, low light) the black color almost look
Either the TCON board or the LCD panel has failed. Start by replacing the TCON board. If the problem persists, the panel is bad and the cost to replace it would be too high.
Mar 22, 2014 | Vizio Televison & Video
Jvc 61g787aa picture too dark on night scenes
Did you try going into the menu and increasing the picture brightness?
Jan 30, 2014 | JVC Televison & Video
Voire 46" plasma tv- best color settings, to much white
The proper way to set flat screen tv's is opposite of old school CRT tv. First, find a movie with dark scenes and pause on a really dark part. Now set brightness only high enough to see some detail - no more. then go to a really bright scene and set contrast just high enough for good brightness. You may need to go back and forth a few times to get good setting.
Dec 21, 2013 | Toymax Viore 42 in. Plasma TV
Brightness and dark scene problems
you need to check your picture menu to verify you contrast is at max and brightness level is at approx 55% . if good , call for service and have htem check the setting on the screen controls. sometime they drift with heat, cold and age. when this happens, they usually have to reset the grey scale (black and white content) of the picture. Beyond that could be a defective red crt drive pcb or red crt or small signal panel.
Apr 20, 2010 | Philips 55PW9363 55" Rear Projection...
Red rash that shows through in dark scenes. Can't
Might cause magnatic field,form.Try unplug,replug the tv an hour,move it couple inches to the left or right might help.
Dec 20, 2009 | Toshiba 50HP66 50 in. Plasma Television
I have a panasonic television that is very dark, the other colors are okay but when it goes to nights scenes, its very dark can this be repaired, the model number is ct-25G6E
It sounds like the master contrast has slipped. If you are confident with electronics, there is a little knob on the main board which allows you to set the master contrast. This is only applicable if the picture looks like it has too much brightness (like a white haze over the picture in dark scenes). Gently adjust the knob to set the correct contrast and you should be up and running. If that doesn't work, then your tube is on the way out.
Mar 05, 2009 | Televison & Video
Brightness difficulty
I had the same problem and so went into the menu and selected brightness and increased the number, and my dark pictures were much better.
Jan 26, 2009 | Protron PLTV-4250 42 in. LCD Television
Darks too dark
try to open your tv and you can find the flyback ,in flyback you can see the screen and focus to adjust.use and try to rotate the screen,it control the brightness of your unit
Oct 15, 2007 | Toshiba 32AF43 32" TV
JVC AV-27D104 27" TV Logo
379 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
