Question about Gvox DV-806 Car Video Player
Stuck on parental control
Manual missing and the parental cotrol is set to PG movies. how do i reset it?
  • GVOX Vexed Aug 23, 2007
    THANKS, BUT I HAVE ALEADY EMAILED THEM MANY TIMES AT MANY DIFFERENT EMAIL ADDRESSES WITH NO RESPONCE. REAL SORRY I BOUGHT THIS UNIT.
  • 944 Answers
Unfortunately there doesn't seem to be a manual available anywhere online. However, it turns out the unit was distributed by "GrandView Tech Electronics" who seem to support nothing but are a subsidiary of Shenzhen Soling, who have a website supporting most of their units; http://www.szsoling.com/en/contact%20us.asp The apparently closest model they have online is the DVD-688; http://www.szsoling.com/en/products.asp?BigClassName=Car%20Player%20DVD.VCD.CD.MP3.ESP&ns=&page=1 (Only if the Fixya picture is accurate.) If that is the right model or not, you need to contact them for a manual on the first link or use their online help, although I think direct contact would be more sucessful. Hope this helps, I will keep looking and maybe someone out there has a manual they will scan, but Soling are the primary manufacturers so they should be able to help. :)
Posted on Aug 21, 2007
  • Nigel Ridehalgh
    Nigel Ridehalgh Sep 06, 2007
    The next thing you could try is to look on ebay for someone claiming to sell one with a manual, contact them and ask them to answer your question from the manual "to verify that they have the right one". You may get lucky without any expense.
    Good luck
    If you need help at any time to identify a quality, supported product to purchase, please ask - we get a good idea of which products are good or not from other users problem postings and from searching around to solve them.
    Real long shot, but are you able to access the on-screen menus - if so, please let me know what you get - I may be able to figure it out. Usually it would be a sub-menu of the "settings" menu, and usually would require a code to be input. parental control codes are usually four numbers - by default usually set to 0000 or 1234 although any code could have been entered by whoever set the control level. Be wary about entering a third code if there are any warning messages, but usually with in car dvd's this is not a problem.
    Hope you get lucky - if you can get the menus up and need help then please post a photo(ideally) or describe them - they may possibly be a copy of the software from an older more mainstream unit.
    Good luck, hope this helps :)
  • Nigel Ridehalgh
    Ps - if you haven't tried already, try disconnecting the unit from power for at least an hour or two (easiest way is to disconnect the car battery completely). It just possibly may revert to factory default settings, although usually this would be an option in the menus instead.
How to change parental setting?
Try this link to download the manual. It has all details.
Feb 19, 2013 | Insignia IS 20" TV040919 TV
PF2020 RESET CHILD LOCK
Turn your television and Apex DT250 receiver on.
Push the "Menu" button on the Apex DT250 remote control.
Press the remote's "Up" and "Down" buttons to scroll through the menu options. Stop when "Parental Controls" is highlighted. Press the "Right" button to select this option.
Enter your four-digit password. If you have not set your password, use the default code of "0000."
Use the "Up" and "Down" arrows to change or set the parental control movie ratings. You can select from "None," "G," "PG," "PG-13," "R," "NC-17" and "X." Once your setting is highlighted, press the "Right" button to go to the next screen.
Use the "Up" and "Down" arrows to change or set the parental control TV ratings. You can select from "None," "TV-Y," "TV-Y7," "TV-G," "TV-PG," "TV-14" and "TV-MA." Once your desired setting is highlighted, press the "OK" button to save your settings. Once the settings are saved, you will be taken back to the main menu. Press the "Exit" key to exit the main menu.
Oct 31, 2012 | Apex Digital PF2020 20" TV
My grandfather cant remember the code for parental controls. it is stuck on pg. can it be reset with out the code
Forgotten the parental control password? there is a way around this. According to the user manual (page 34) for this particular model:
Enter "788444" even if 4 digits "----" appears, then press [ENT]
to clear the current password.
Enter a new password and set the parental lock level again if required.
Note: DVD video discs may or may not respond to the parental lock
settings. Make sure this function works with your DVD video
discs.
You need the original unit's remote to do this. It cannot be done without it.
There is a .pdf of the user manual online.
http://tv.manualsonline.com/manuals/mfg/sanyo/dwm390.html
(It is free to download for personal reference in case you have lost your original copy.)
I hope this helps a tad.
Mar 07, 2011 | Sanyo DWM-390 DVD Player
How to reset the parental control code - I forgot the code and want to reset with a new one
This is what I found in the instruction manual on this and I posted it here for you. Try using 3355 for the code and everything else listed here. If that doesn't work, try the very last tip which tells you how to do a factory reset and repeat the first step using the 3355 as the code.
Here's the instructions from manual:
Parental Control
Parental Control allows you to block certain channels or programs so children cannot view
programs that are not age appropriate.
To enter the Parental Control menu, you need an
access code. The first time you enter, use access
code 3355. See "Setting an Access Code" on
page 33 for information on creating a new access
code.
You can set the following options to block
content:
• Channel Lock — Blocks selected channels
• Movie Rating — Blocks movies based on their rating (G, PG, PG-13, R, NC-17, and X)
• TV Ratings — Blocks TV shows based on their rating
• Block Options — Turns on or off all your parental control settings
NOTE: You can use Clear All to unblock the channels and programs that you have set.
NOTE: If the Block Control in the Parental Control menu is enabled, all the sub screens in POP (POP1,
POP3 and POP12) mode will be blank
Setting an Access Code m
After you enter the Parental Control menu for the first time, you can set your own four-digit access
code. If for any reason you lose or forget your access code, you can use the default code.
1 In the Parental Control menu, select Change Code.
2 Using the number pad on the remote control, enter a new access code.
3 Select Exit.
Reset the original factory defaults. Press Menu on the remote
control, select Setup, and then select Factory Reset
Jul 28, 2010 | Dell W4201C 42 in. Plasma HDTV
Player won't play certain dvd's
the password is the arrows you have to do forwrd,backward,forward,backward but use the doubke arrow keys. this should work i found the soloution the manual
Mar 12, 2009 | Disney Hannah Montana DVD Player
XBox parental control
goto xbox.com and login and turn off parent controls from there
Sep 18, 2008 | Microsoft Xbox Console
Parental password set by my kids no one fessed up how do I reset it?
  1. From a cold start with no disc in unit, press the / button simultaneously on the front panel for 5 seconds.
  2. All settings including the password will revert to the factory settings.
  3. Don't use this unless absolutely necessary.
Aug 21, 2008 | Samsung DVD-V6700 DVD Player/VCR
MAnual/Reset Parental Control Code
According to the manual, "If you forget the password, you can erase your current password by pressing the number 8 button on the remote four times, thn press the enter button to confirm the setting. PASSWORD: 8888"
A picture of an unlocked lock indicates that Parent Lock is NOT active.
Parent Lock Levels:
1: Kid Safe 5 : PG_R
2: G 6 : R
3: PG 7 : NC _17
4: PG_13 8: Adult
It also says that it takes 3-5 seconds to reset the unit to the factory default. I hope this helps! Karen
Feb 17, 2008 | Durabrand Portable DVD
Soundstorm car dvd player
This is from the soundstorm website: If your DVD player shows a "Parental Code" on the screen. Here is the factory default code. It is 3308. Once you have this code, you can go into the settings and change the level to whichever level you like. Here is a break down of the levels: Level 1 = G Rated Level 3 = PG Rated Level 4 = PG 13 Rated Level 6 = PG-R Rated Level 7 = NC-17 Level 8 = Adult Level 0 = No Parental
May 29, 2007 | Soundstorm SDVD-100 Car DVD Player
Parental control is stuck
You can try these codes 2211 or 3308 if they do not work you will need to reset the unit. You will need to unplug it for 45 minutes that will reset the TV to factory settings. Then the pass codes I provided should work.
Oct 03, 2006 | Daewoo DTQ-19V1FC 19" TV
Gvox DV-806 Car Video Player Logo
2,833 people viewed this question
Top Gvox Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Gvox Car Audio and Video Expert? Answer questions, earn points and help others
