Question about Sony FD Trinitron WEGA KV-36FV310 36" TV
TV doesn't turn on
First off thanks for any help with this problem. My problem is that I can't get the set to turn on. when I try to turn it on (from either the remote or from the tv itself)I will here the tv click on, it then makes a pop like it is going to turn on, then a noise comes out of the speakers and it it shuts off. There are no flashes or anything going on, on the screen during this time. I also noticed that the Standby light is always flashing. The owners manual says to unplug the set for a couple of minutes and then plug it back in and it should reset the Standby light, but this does not work. Once again thnks in advance for any help with this problem........Apps
  • 1 more comment
  • Steven Alperstein Aug 24, 2007
    Thanks for the help....Had a tech look at it, he took board back to shop and I should know later today what the problem is...Thanks for your help
  • no pic Feb 16, 2008
    power up tv clicks and then clicks timer flashes 6 times
  • Anonymous Apr 11, 2008
    my shart tv 21' doesn't on and always in standby mode
  • 398 Answers
When the set is turned on, the computer senses that something is wrong and immediately shuts the set back off. The standby LED will then blink a code, a certain number of blinks, to indicate exactly why the set was shut down. It is possible that your audio output IC is shorted, as this would make a pop or strange noises in the speaker just before the set shuts down, which it does to protect your speakers from burning up. The set should be looked at by a qualified tech familiar with Sony TV's.
Posted on Aug 21, 2007
I have a Jensen (JE1909ACB) 19 LCD TV Can't get it to hook up as a monitor on my desktop. It reply's unsupported mode.
Are you using the VGA port on the Jensen TV? What is your computer's OS?
The usual reason for the unsupported mode message is that the the computer did not recognize the TV as a monitor on boot up or that the previous settings were incompatible with the TV. (For example, if you previously had a CRT connected to the computer and used a refresh rate of 75 Hz, the TV can't handle the refresh rate. It needs to be set at 60 Hz.)
First turn off both the TV and the computer. Then turn on the TV and set it for the PC input (assuming you are using the VGA port). Next turn on the computer. If you have Windows XP or later, it should find the TV and set the resolution without any input. (If it doesn't, use a different monitor and set the resolution to 1366 x 768 and 60 Hz. Then try again.) If you used the HDMI port, try the VGA port. This TV doesn't understand a computer signal over the HDMI port (only set top boxes).
I hope this helps.
Dec 08, 2011 | Car Audio & Video
I am trying to auto search my urc-4700boo remote to a emerson tv i went through all the 4 digit codes already and it didnt work so i want to try to do it on auto search but need the instructions on how to...
TRY THIS...TURN YOUR TV ON...THEN JUST KEEP PRESSING THE POWER BUTTON ON YOUR REMOTE, TILL YOUR TV TURNS OFF, YOU WILL NEED TO DO THIS AGAIN TO TURN YOUR TV BACK ON.
THIS WILL SET YOUR REMOTE...IF IT DOESN'T...THEN, START AT 01 ENTER, 02, 03 ,04 ETC,.
THE FIRST SUGGESTION IS THE BEST!
HOPE THIS HELPS!
Sep 03, 2011 | Televison & Video
My Technika LCD32-229 is just over 12 months old and has suddenly decided not to respond to the remote or on/off control on the TV. If I turn of the power at the mains for 30 seconds or so, it will then...
HERE'S THE ANSWER TO YOUR PROBLEM:
The possible reason why your TV doesn't respond to your remote is probably the battery of your remote. Maybe it has been used up to it's fullest capacity, so try checking it up. In case, it has been used up, try to buy a new one.
The possible reason why your TV doesn't stay on is still your remote control. Maybe you have accidentally set it to "sleep mode." When it is set into sleep mode, it turns on just for a shorter time. It cannot stay on longer.
So, here's what you've got to do. Check your remote. When the remote works already, press the sleep button remote again. I hope it works for you.
Thanks.
Jul 23, 2011 | Televison & Video
Tv sound only plays with dvd player not television.
problem in audio-video ( audio pin). clean this with tooth brush from inner site.
Jul 02, 2011 | Sanyo 42K30E 42 in. TV
My Samsung 20" CRT model # TX-P2036 has power
May be you should press the channel button on the set itself or there is a problem with the eeprom of the set circuit.
Jun 15, 2011 | Samsung TXP2036 20" TV
When I turn on my set, light turns green, then after 30 seconds turns red won't come on
Sounds like there is a problem with the power supply. Try unplugging the T.V. and hold the power button for 30 seconds. Plug the T.V. back in and see if that helps. If it doesn't try switching to another outlet, and if that doesn't work then you may need to replace the power supply which would probably cost anywhere from 140 to 200 for one.
May 05, 2011 | Fujitsu PlasmaVision P50XHA40US 50 in....
Sanyo television doesn't turn off either by using the remote or by turning it off at the tv.All other fuctions work using the remote or directly on the set.Even using the sleep timer doesn't turn...
Unplug the set and hold the power button for 30 seconds. Plug it back in and see if that fixes it. If it doesn't then it sounds like there is a problem on the board underneath the power button. Something isn't allowing the circuit to be cut.
May 05, 2011 | Televison & Video
I plugged in my PS3 using an HDMI cable and i get no feedback
If you just bought the PS3 use your composite cables that came with the system. Turn the PS3 on and go to the video settings, set up video input to HDMI. After you've done that plug your HDMI back into your PS3 and try turning it on. If that works go back to video settings and change the resolution to 1080p. If that doesn't work make sure your T.V. is on the same input that the HDMI cable is plugged in. If it is and still doesn't work try switching to a different HDMI port. If switching to a different HDMI port doesn't work try a new HDMI cable. If the new HDMI cable doesn't work then there is a problem with the port on the PS3 which would require a repair.
May 03, 2011 | Toshiba 50HP66 50 in. Plasma Television
Hi, please please please help..... I have just bought a new Panasonic 42 Inch Full HD 1080p Widescreen LCD TV TX-L42U2B from Argos, I also bought the HDMI cable they recommended on the same website...
hello chis, it may the ps3 your having trouble with connect ps3 to hdmi 1 reset the ps3 by doing this. press and hold the standby button on the front of the ps3 you will hear 1 bleep then 2 short bleeps after the short bleeps release the button this will reset the display setting on the ps3 you should get1080p if this dfon't work feel free to get back to me thanks
regards
shaun
Jan 08, 2011 | Sony Playstation 3 (PS3) Console
Sony FD Trinitron WEGA KV-36FV310 36" TV Logo
511 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
