Question about Epson Stylus CX3810 All-In-One InkJet Printer
I Got rough with the printer while trying to change the ink cartridges.
I was in an extreme hurry, and my ink cartridges had run out of ink on my epson stylus 3810. I was trying to get it to release the cartridges in order to see what i had to buy. I wasn't in a clear mind and forced the cartridges out. i put the new ones in, and now it only prints a little bit of yellow. and solutions short of buying another one?
Rather than waste money on a stylus, just buy a new printer. Less than $70 for a printer and you get the 1 year warranty.
Posted on Oct 02, 2007
  • 29 Answers
I would suggest running up to 9 cleaning cycles - 3 groups of 3 cleanings with a nozzle check after each group of three. If no change, then replacement would be your best solution. A good replacement would be the Stylus CX7400 for around $70
Posted on Sep 09, 2007
Hp Photosmart 6510 Black ink will not print
It is a known defect among many PhotoSmart printers, including the 6510. The black ink was programmed to fail at between 50 to 60 black print cartridges. One HP whistleblower said a bug in this programmed failure causes the black ink to suddenly stop printing after 5 to 6 black ink changes instead. When you call in, they offer to sell you a new printer! The service guy I spoke with was extremely nervous. I refused to buy a new printer, given I had put less than a ream of paper through mine. I was on hold for about 10 minutes, then told there was no supervisor, but given an email address to write to. Three weeks later, still no response. Yes, a class action lawsuit needs to happen, not just for the printer malfunction, but for the hours I soent trying to fix it, and new cartridges I bought, thinking I had bad ones.
Jan 27, 2013 | Office Equipment & Supplies
Window shows "Printer Error".
first thing to do is disconnect the printer from the power source and do a hard reset
Jul 08, 2008 | Office Equipment & Supplies
Can't get cartidge holder to stop in right place to insert new cartridge
If yours is an Epson printer, push the cartridge change button on the front panel twice. The ink carriage will retreat to the extreme right hand side. When you have loaded the new cartridge (s) push the same button twice. After a while the carriage will prime the new cartridge, the green light will come on and you may print. Other printers: For HP, open the lid with the power on. If all else fails,m I pull the plug. manually move the carriage, change the cartridge and re-power. Always try pushing the cartridge change button on the front panel first, however.
Mar 25, 2011 | Office Equipment & Supplies
Trying to change ink cartridge on epson nx515 printer. how do I move the container out from under the printer to change it?
If your printer is out of ink, it will display the ink that you need to replace. Just open the lid and press the OK button.
If you want to replace an ink before it runs out, press the Setup button then go to Maintenance and press the OK button. Select "Ink Cartridge Replacement" or "Change Ink Cartridge", then press OK. You can now lift the lid then replace the ink.
Nov 18, 2010 | Epson Stylus Multifunction Inkjet Printer/...
How do I reset the ink level indication on a HP F4235 Deskjet printer when using a refilled cartrige?
Forgive me for asking this, but roughly speaking about 80 to 95% of problems involving ink or toner are resolved by the following:
Are you using a factory new ink cartridge supplied by the manufacturer of the printer?
If you are using a refilled or third party cartridge that may well be your problem. Most manufacturers build logic into their products to prevent the use of “Other Equipment Manufactured” cartridges as well as re-filled cartridges.
They do this to prevent problems from contaminated inks causing problems with print quality or damaging the physical printhead.
If you are using the manufacturer’s new ink cartridges, then please contact their technical support group. Factory new cartridges usually have warranties on them.
Don
Dec 12, 2009 | Office Equipment & Supplies
The ink light on my printer started to flash. I
Don
Dec 12, 2009 | HP DeskJet 932c InkJet Printer
Why won't my CX9400F recognize Epson ink cartridges
The Epson CX9400F printer seems to require replacement of all the color ink cartridges, even if only the Black is empty.
I print almost exclusively in Black, but with my first change of Black, I was forced to change all the color. At the time I thought Epson did not provide completely filled color ink cartridges.
Just yesterday, I replaced Black and the printer complained it did not recognize the rest of color cartridges. So I replaced all the other color ink cartridges and now it works fine.
You might want to check out www.clickinks.com for cheaper, mail order alternatives which are Epson ink compatible, if you are not in a hurry.
ew
Feb 23, 2009 | Epson Stylus CX9400 Photo Printer
Lexmark x 3650 change ink cartridge but it still gives a message(
Hi Glesam,
The X3650 uses the No. 37 tri-color cartridge, i.e. 3 colors in 1 cartridge. Unfortunately, when one color runs out, the cartridge has to be replaced. When you change printer, you might want to consider a printer that uses at least 4 separate ink cartridges (black, cyan, magenta, yellow). This way you need to replace only the cartridge that runs out.
Rgds
S88
Dec 22, 2008 | Canon MX300 Office All-In-One Printer
Open Questions:
See all Epson Stylus CX3810 All-In-One InkJet Printer Questions
Epson Stylus CX3810 All-In-One InkJet Printer Logo
124 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
