Question about Motorola Mobility RAZR V3
Razr and bluetooth
My Razr wont locate blue tooth device, i have followed the instructions carefully. but when i tried my friend phone it works right away. what is wrong with my razor
  • 1 more comment
  • Anonymous Feb 25, 2008
    cant get bluetooth to work
  • Anonymous Oct 26, 2008
    people can find me but i cant locate anybody. solution wasnt helpful
  • artful_foxie Oct 28, 2008
    I HAVE A MOTOROLA RAZR V3 AND A JABRA BLUETOOTH HEADSET BT160. MY PHONE PHONE DOES NOT FIND ANY DEVICES EVEN THOUGH I HAVE ENABLED BLUETOOTH. ARE THESE TWO DEVICES NOT COMPATABLE OR WHAT? CAN SOMEBODY HELP ME GET THESE TWO DEVICES IN SYNC?
  • 42 Answers
IN SETTING GO TO BLUETOOTH AND ENABLE IT THEN TRY
GOOD DAY
KZ
Posted on Feb 25, 2008
I need to connect a bluetooth to my razr
Do you need to connect a bluetooth headset , or do you need to start bluetooth file transfers?
In either case, to activate blue tooth on the RAZR V3i go to settings>connections>bluetooth (May appear as "bluetooth link") > hands free> look for device. The Razr will scan for other bluetooth devices. If you need to send files over bluetooth, turn on the blue tooth antenna, and navigate to the files you wish to send. Press the menu button, and press "copy" and select the device you wish to send it to in the devices list. If there is no device, or the device you with to send it to is not in the list, press "look for devices".
Mar 28, 2011 | Motorola Mobility RAZR V3i Cellular Phone
Setting up my blue tooth
You need to pair it with the phone, working on phone settings, what is phone model?
Aug 29, 2008 | Motorola Mobility Bluetooth Headset H3 for...
Bluetooth will not stay connected on my 2006 BMW z4
Depending how far of a range your getting, between your razr and your blue-tooth is important. Any range of 30ft or over is less likely to connect/search/and or pair with any capable blue-tooth device.
Try pair the two devices again, but remember to save the trusted blue-tooth to your device so that disconnection can be prevented only by your command.
If your blue-tooth has a short, or battery is extremely low then that TOO can cause disconnection.
Hope this information can be of a benefit to you. Thanks.
Mar 16, 2009 | Motorola Mobility RAZR V3x Cellular Phone
Bluetooth on but not detected or detects other devices
What u need to do is not just turn on the blue tooth on your phone but set it to 'find me', so that other bluetooth devices would be able to locate the device. the 'find me' option is also under the blue tooth menu.
please rate me. thank you.
Dec 03, 2008 | Motorola Mobility RAZR V3c Cellular Phone
Bluetooth not powering up
Try this ::
1. Create a link between your Motorola RAZR Phone and any Bluetooth Accessory 1.0 and up, you need to turn the Bluetooth connection "on". This is how: Go into your phone "settings". > Then select "Connection" > "Bluetooth Link" > "Set Up" > "Power" > "On". The connection will stay on until you turn it off. We recommend to turn it off when not in use to preserve battery life. 2. To connect your RAZR to another Bluetooth hands free kit or headset, go into "Settings" > "Connection" > "Bluetooth Link" > "Handsfree" > (Look for Device). You phone will scan for available devices located within the range of the RAZR, approx 30 feet away. If your cell phone is already connected to a Blue Tooth headset, you must disconnect from it to find other devices. Once you have identified your bluetooth device, highlight its name and click on the "select" button.
3. The Bluetooth device will ask permission to connect. Select "yes" and press the "select" button; after that you will be prompted to insert a PIN code to initiate a secure connection. The PIN code is sually provided by the Bluetooth device manufacturer, not the RAZR. Once the connection is made, you should see the bluetooth logo displayed on the internal screen, while the external screen Bluetooth indicator will flash.
PLEASE DONT FORGET TO RATE THIS RESOLUTION.
Nov 24, 2008 | Motorola Mobility RAZR V3i Cellular Phone
Razr pairing with blue tooth
maybe you need to activate your blue tooth or turn it on in other words. not only that but you should go to your bluetooth profile and see whats going on there
Jun 01, 2008 | Motorola Mobility RAZR V3c Cellular Phone
I can't get my phone to connect with other peoples
I assume you are trying to connect to another phone via Bluetooth. It would help quite a bit to know what kind of phone you are trying to connect to, but here is what you need to have configured on your phone for Bluetooth file transfers:
3. The Bluetooth device will ask permission to connect. Select "yes" and press the "select" button; after that you will be prompted to insert a PIN code to initiate a secure connection. The PIN code is usually provided by the Bluetooth device manufacturer, not the RAZR (unless you are connecting to another phone). Once the connection is made, you should see the bluetooth logo displayed on the internal screen, while the external screen Bluetooth indicator will flash.
4. You can now "Copy" media files to the phones nearby that you have connected to. Copy is an option while browsing through the files.
Dec 14, 2007 | Motorola Mobility RAZR V3
Bluetooth & Moto V3m operation
look if the earpiece is compatible with your new phone, usually its a compatibility issue with your equipment.
Oct 21, 2007 | Motorola Mobility RAZR V3
Motorola Mobility RAZR V3 Logo
67 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
