My check engine light is on. The VCM says: PAO. It previously said PAO and Fuse 3. Now it just says PAO. All fuses check out OK.
I want to get it smogged, but can't until I get the check engine light off.
The PAO you see on your dash in the VCM (Vehicle Condition Monitor) *is really* -PAD-.
I had the same beacon on my 1991 XJ6, it refers to the brake pads being worn.
Fuse 3 is a notice that there is a misbehaving fuse in your 3rd fuse box, which is located inside the center console (armrest)
Best of Luck!
JeremyM
Print
Stored fault codes may be erased from memory at any time by removing power from the VCM for at least 30 seconds. It may be necessary to clear stored codes during diagnosis to check for any recurrence during a test drive, but the stored codes must be written down when retrieved. The codes may still be required for subsequent troubleshooting. Whenever a repair is complete, the stored codes must be erased and the vehicle test driven to confirm correct operation and repair.
WARNING
The ignition switch must be OFF any time power is disconnected or restored to the VCM. Severe damage may result if this precaution is not observed.
Depending on the electrical distribution of the particular vehicle, power to the VCM may be disconnected by removing the VCM fuse in the fusebox, disconnecting the in-line fuse holder near the positive battery terminal or disconnecting the VCM power lead at the battery terminal. Disconnecting the negative battery cable to clear codes is not recommended as this will also clear other memory data in the vehicle such as radio presets.
The following are the codes for the 1994-95 models with the OBD I and OBD II systems.
See Figure 1 through 6
Fig. Fig. 1: DTC chart for 1994 ECM models
Fig. Fig. 2: DTC chart for 1994 PCM models
Fig. Fig. 3: DTC chart for 1994-95 VCM models
Fig. Fig. 4: DTC chart for 1995 PCM models
Fig. Fig. 5: DTC chart for 1995 VCM-A models
