Question about NEC ND-6650A DVD RW Dual Layer Burner
NEC 6500A DVD Rw
When i install any disc all it says is please insert disc it will not read any disc dvd or cd this drive is on Fujitsu seimens laptop (internal drive) is there any way to test this drive without buying a new one or is it a software problem thanks
    Problem Solver:
  • 6 Answers
This sounds like an I/O error that my laptop was afflicted by. Refer to http://support.microsoft.com/kb/891894 for some solutions to this problem.
Posted on May 10, 2008
    Scholar:
  • 53 Answers
I used to have a DVD/CDRW driver on my Sony Vaio and I had to replace it twice it died on me and I had to buy a new one every time the truth is that many things can go wrong for such small device so try this go to http://drivers.softpedia.com/get/FIRMWARE/Nec/Nec-ND-6500A-firmware-424.shtml Download the firmware, if after that it still wont work your chances are that you have to buy a new one.
Posted on Aug 29, 2007
SOURCE:
Laptop Optiarc DVD RW AD 7530 B is not reading CD or DVD media. 1.DVD icon displayed in My Computer. 2.When I insert DVD or Cd in the drive,Green light flashes and tries to read the nedia and goes off...
2.When I insert DVD or Cd in the drive,Green light flashes and tries to read the nedia and goes off within few seconds.
3.DVD drive in My Computer when clicked shows empty folder
4.Uninstalled DVD drivers in Device Manager and let windows find it on reboot
5.Issue still persists.
6.Right now external DVD RW works perfect.
Please help
Oct 29, 2009 | Sony NEC Optiarc AD-7530B 8x DVD?±RW DL...
Installed XP SP3 to my Dell 6000 and now NEC 6500a can't be found. Device manager says that the drivers are loaded by cannot find the hardward Code 41
see if its recognised in the Device Manager. Start/My computer/Control Panel/System/Device manager.
if so remove or uninstall the Drive.
Physically remove/eject the drive from the Computer. reboot then shutdown. re-insert the Drive. boot computer and see if it,s detected by the system or ( found new hardware Wizard )
re-install any drivers as requested. Installing SP3 shouldn,t do this. unless the drive was actually Virused Or failing already.
Mike @ compurepair.
Oct 16, 2009 | NEC ND-6500A DVD±RW Dual Layer Burner
NEC DVD +RW - 6650A will not read a blank DVD
i ran into this problem a while ago. I had to test different dvd's. I then looked on the manufacturer's website. there they stated which dvd-r, dvd-rw would work. once i tried that brand It worked fine.
Sep 10, 2009 | NEC ND-6650A DVD RW Dual Layer Burner
NEC ND-6650A
well, sounds like common error promblem have you tried looking and seeing if mite have bought the wrong kind of dvd's I have done this before i bought dvd's instead of Cdrw's discs.? or try dowloading www.slysoft.com thier cd player plays and reads and rewrites almost anything .. lala linda
Jun 03, 2008 | NEC ND-6650A DVD RW Dual Layer Burner
NEC DVD+-RWND-6500A
ok " click on start , go to programs, go to system tools, click on
system restore , restore to a date before you installed Itunes.
if that doesn't work try click on start , click on settings, click on
control panel , click on system, in menue click on hardware,
click on device manager, click on dvd/cd-rom drives, your drive
should be there , click on drive with right button.and a menu will come up ,delete it .
now shut down windows , and restart your computer
windows will now will see your new drive, and you can reinstall it.
Jan 21, 2008 | NEC ND-6500A DVD±RW Dual Layer Burner
NEC ND-6500A DVD±RW DON'T READ CD
I have encountered this problem numerous times and, while I'm not sure of the exact cause, the remedy that works 90% of the time for me is to create a 1:1 solution of isopropyl alcohol & distilled water and to GENTLY brush the laser with a cotton swab tipped with this solution.  Afterwards, use the other side of the swab to completely dry off the laser, ensuring that absolutely no cotton fibers are left behind.  Good luck!
Oct 30, 2007 | NEC ND-6500A DVD±RW Dual Layer Burner
NEC DVD-RW 16x DL
If you switched to a different brand of DVD's try using the brand you used before. DVD burners are tested with certain brands of DVD's and sometimes the brands that aren't on that list don't work.
Jun 11, 2006 | NEC 16X Multiple Format DVD+/-R/RW/DL...
Cannot read dvds
sounds like your dvd laser has failed if it reads other media as there are normaly 2 lasers one for reading cds and one for dvds try using a cleaning disc to clean the lenses
May 27, 2006 | NEC ND-6500A DVD±RW Dual Layer Burner
NEC ND-6650A DVD RW Dual Layer Burner Logo
261 people viewed this question
Top NEC Computers & Internet Experts
Steven Wander
Steven Wander
Thomas F. Schneider
Alun Cox
Are you a NEC Computer and Internet Expert? Answer questions, earn points and help others
