Question about Mitsubishi WS-55315 55" Rear Projection HDTV-Ready Television
No volume on tv
On our tv there is no volume coming through the tv but there is volume coming through the dvd player. Could someone please help us asap? Thanks Ms. king 240-461-5606 cell
    Genius:
  • 1,153 Answers
Check to see if all video/audio connections are right. If you know it's all hooked up correctly then look in audio and see if anything is turned off. Maybe internal speakers. Do you have cable or satellite, or you going thru RF connector or AV inputs?
Posted on Aug 21, 2007
SOURCE:
I have an audiosonic KM3608N DVD player and an LG TV. I have perfect sound when watching TV but seemed to have pressed something on either TV or DVD remote that has caused the DVD player to play at...
Please go to audio output menu on your DVD screen check them and when on the DVD channel check your audio input menu. You could have turned on the volume limit on your DVD settings menu
Nov 02, 2017 | Car Audio & Video
NO VOLUME
first use only a coaxcil cable to hook up to tv ;second try using standard colored wire hookup (red/white/yellow if you can0 third make sure all cables are plug in tight and in the right area. If still nothing the try adjusting volume on tv and the dvd recorder before you do any of these things.
Apr 02, 2009 | Cyberhome DVR 1600 DVD Recorder
Volume not working
Make sure you have patch cables hooked up from the audio out of the dvd player to audio IN of the Television, using the same named input (Video 1, 2, Fnt, Bck, Aux) that you used for the video in.
Mar 05, 2009 | Samsung DVD-VR357
Sound output reduced
There is a volume control on the Remote of your DVD player , increase the volume in that and it should solve. Additionally check the audio output cord of DVD player if it is intact and tightly fitted.
Please rate me appropriately if you are satisfied with my answer,in case, if you want any clarification please get back to me.
Jan 22, 2009 | Sony DVP-NS57P
Bush DVD2038 No Sound
if tv has RCA(red & white) inputs,and dvd has RCA outputs,try using an rca lead for the audio.if it dont work,bin it.
Jan 08, 2009 | Bush DVD2038 DVD Player
Very Very Low volume.
The line out jack isn't amplified. Try using the headphone jack. You can control the volume using the controls on the dvd. Whatever source you are plugging it into doesn't have an amp powerful enough to boost the audio.
Jan 02, 2009 | Durabrand DVD-1002 DVD Player
Volume Problem with my TV and Home Theater system
I had the same problem with mine.The solution I found was to use an optical audio cable rather than the red and white RCA audio jacks. Hope this helped.
Dec 23, 2008 | Sony BRAVIA® DAV-HDX576WF Theater System...
Trying to install a new 50
a good way to go is to connect the home cinema kit staight to the tv though phono leads, see if your tv has a phono in and out this must not be a av socket. you should then connect it in to your cinema kit so what ever you watch comes though ur cinema system
hope this helps
Feb 09, 2008 | Televison & Video
Volume on tv not working
Try pressing the favorite button on the remote. "Favorite off" should display and the remote should work.
Dec 29, 2007 | iLO 2600 Television
Mitsubishi WS-55315 55" Rear Projection HDTV-Ready Television Logo
203 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
