Question about Alpine Type-R SWR-1242D Car Subwoofer
Has my subwoofer been blown?
I have single Alpine type R SWR-1242D subwoofer hooked up to an alpine MRP-M100.  I was driving one day and the subwoofer just stopped working.  I pushed on the sub and it did not feel blown out ( i blew a MTX sub a couple days earlier and could feel it when i pushed it in that the sub was dead.) .  I figured the fuse must be blown but could not find one.  Where would I look for the fuse, or does the speaker seem to be dead.
  • maniacmatt36 Mar 30, 2009
    i have a 15 inch alpine type r. i have tried all the wiring configurations possible with 2 different amps, and on either amp it will make alittle bit of sound but nothing close to deep bass, it will rattle when i turn the stereo up, making a sound like it is rattling right in the center. i have a 400.1 kicker amp and a sony xplod 1000x2. could i be that the speaker is not compatible with those amps. it is a dual 4 ohm voice coil. what might be the proper way to wire this speaker to one of those amps discribed above
Hook ithe sub up to a 9volt battery and see if the woofer moves... You will not dammage the suub testing it this way.
Posted on Mar 25, 2009
SOURCE:
What is the best amp for one 15" alpine type r?
sub spec 250watts per coil you should be just fine I have 2 typr 15s on orion hcca 2500 1 and it kicks a$$ thats 1000 watts over the rated limits of the subs only shut the amp down once these subs can take a lot more power than they say just use your common sence with the volume and gain levels
Jan 31, 2012 | Alpine Type-R SWR-1242D Car Subwoofer
I'm trying to find the best box size for my single alpine type R 1242D?
The subwoofer box ratings for this subwoofer are as follows:
  • sealed box volume: 0.57-1.0 cu. ft.
  • ported box volume: 0.75-2.0 cu. ft.
Mar 17, 2011 | Alpine Type-R SWR-1242D Car Subwoofer
How to wire 2 alpine typre r 1242 to an alpine pdx1000 mono amp??
If they are single voice coil, just hook one up to the amp (bridged) like normal and run a jumper wire from the positive of the sub to the positive of the second one, then do the same for the negative....This will give you a lower ohmage, thus better bass!!!
Oct 19, 2010 | Alpine Type-R SWR-1242D Car Subwoofer
What is the best box for 2 ALPINE SWR-1242D 12"SUBWOOFERS TYPE-R NEW SUB WOOFERS
Ported and tuned to around 37-40 hertz. After all displacement the box should be in the 2.2 cubic foot for sub and you will be very impressed. Build it yourself for optimum sound and output.
May 23, 2010 | Alpine Type-R SWR-1242D Car Subwoofer
Whats the best box for single alpine type r sub
get your manual out go to a box calculating site and youll have your answer
http://www.carstereo.com/help/Articles.cfm?id=5
go here with your sub specs
Oct 21, 2009 | Alpine Type-R SWR-1242D Car Subwoofer
Alpine 7190ET Manual
Enter Alpine car audio in your search engine and go to alpines home page and then click on support then enter in the product # SWR-1242D and it will pull up the manual.
Mar 09, 2009 | Alpine Type-R SWR-1242D Car Subwoofer
SWR-1242D wired at 4ohms
Hi!
Having to much power for a subwoofer is a veeeery good thing, it will provide a lot of control and quality sound to your sub.
But this sub is a dual voice coil at 2 x 4ohm so if you want to hook it up at 4 ohm u need a 2 channel amplifier running mono mode.
i dont recomend that you hook up in 4 ohm, its better to take some time adjusting the levels on the amp and the headunit.
This system has the potential to create a realy good bass sound if u tune it the right way.
Feb 10, 2009 | Alpine Type-R SWR-1242D Car Subwoofer
Alpine Type-R SWR-1242D Car Subwoofer Logo
544 people viewed this question
Top Alpine Car Audio & Video Experts
xxxxxx xxx
Robert Salgado
Robert Salgado
Jaime Hernandez
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
