Question about Samsung HC-P4752W 47" Rear Projection HDTV-Ready Television
Samsung projection tv
Hello i have a samsung projection tv 42 inch until recently it was working fine.The problem now is the colour is distorted and it is like there are 2 pictures in differnt colours overlapping each other ,can this problem be fixed if so can you HELP please. Thanks
  • Anonymous Mar 15, 2008
    same problem 2 years old !!!
    New Friend:
  • 13 Answers
This problem happens to many sets of all different manufacturers and models of c.r.t proj. type tv's. What has happened to your tv is most likely that one of the 2 ic's (large black modular looking things about 2" by 1" by 3/8" fastened to a large aluminum slab of metal called a heat sink) on one of the large circuit boards has SHORTED OUT. The number on these ic's is stk392-***. If the asterisks shown are 110 then there is an upgrade of 180. If say the last 3 numbers are 040 then there is no upgrade. Anyway both Ic's need to be replaced and any associated resistors in the circuit area that have burned open or got hot and changed value also must be replaced..in addition a calibration of the convergence may need to be done either according to your operators manual or factory service manual by using your remote control and/or buttons on the front panel of the tv. Sometimes a samsung will have a small circuit board separate from all neighboring circuit boards that only has the convergence circuit on it. In that case the complete board should be replaced if possible. Do not attempt to do this repair yourself unless you are expert in electronics or guided by one. Above all do not attempt to make any repairs without being sure that the set is NOT plugged in. Invariably the heat sink compound (white pasty looking material sandwiched in between the ic metal backing and the heat sink) has dried out or was not ample enough and/or the screws fastening the ic's were not tight enough to secure properly the ic's mentioned. This heat sink compound material is PARAMOUNT to allow proper heat transfer and needs also to be replaced with known excellent silicon heat sink compound that exhibits excellent heat transfer properties and will not dry out. Careful soldering and de-soldering measures must be taken as well to insure a no-damage repair procedure as well as being careful to create no solder bridges between the pins of the ic's when the new ones are inserted. Be very careful of static charge when handling all delicate electronics boards and their parts. Before beginning also make sure there are no large charged capacitors that have not been discharged using a 1k ohm resistor and a piece of wire usually an alligator type test lead. This entire procedure usually takes up to 3 hours if done properly. In addition before new compound is applied the old compound must be thoroughly removed with anhydrous alcohol(99% isopropyl ). Finally because of this problem it is highly recommended that cool airflow around the back of the tv is insured. Good Luck
Posted on Aug 23, 2007
MY TV HAS NO POWER I CHECKED THE FUSE IT SEEMS
hello have you checked the glass fuse inside the tv it will be in the power supply beware if replace the and blows again the you have a dead short circuit
regards
shaun
Apr 09, 2010 | Samsung HCN4226W 42" Rear Projection...
Samsung DLP 56" tv,distorted picture
if you say that your picture gets distorted you mean like it moves to a side? do you see a black middle block?
if it's a yes?
so its probably the light engine. you need to change it!
try this link.. http://www.discount-merchant.com/1069179-HL-N5067W-p/1069179.htm
the price is more or less depends on your TV model... $279.00
Feb 02, 2010 | Samsung DLP HL-P5663W 56" TV
Hi I have a hitachi 50 inch projection tv and
there is no tube in a projection tv it will be the conversion chips if picture colours aer distorted
Dec 12, 2009 | Hitachi 51F59 51" HDTV Projection...
When switched on colours fine after short period colours seperate causing a 3d type effect
Projection TV sets are known to have two common problems. The first problem that is common to these sets is convergence failure. When this happens the TV will usually look 3D, Wavy/Distorted, etc. It may also shutdown and blink an error code.
The second common problem with Projection TV sets is dull video, halos around objects, white looking video, or red overpowers the screen. This is commonly caused by the fluid in the lens being clouded overs.
You can find more details and solutions here on Fixya at the following link below. Or click HERE
3d884ac.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Nov 21, 2009 | Samsung HCN4226W 42" Rear Projection...
Samsung LE26R7 4BD, approx 4 years old, colour distortions
Check all of your cables on the back of the tv and your sources such as Cable,Sat box and DVD palyer to make sure they are fully inserted into the input and output connectors. Some times Component cables will work loose and you end up with a missing color. Temprature changes can affect intermittant connections. If that does work then you have a bad Main bd.
Jul 02, 2009 | Samsung LE32R74BDX 32 in. HD-Ready LCD...
Picture distortion
Sounds like convergence is off. Need new Convergence amps. Could cost a couple hundred. Check around. If it has an auto converge or manual converge try that first. Check menu
Apr 08, 2009 | Televison & Video
My 42 inch plasma has black distorted picture
hi
its cathode ray tube problem or the colour wheel...check that both please.....
thank u,,,,,,
Mar 07, 2009 | LG 42PC3D 42 in. Plasma Television
Samsung flat screen problems
you will have a years guantee
Jan 06, 2009 | Samsung HL-S4266W 42" HDTV
Red Convergence out on right side of the screen only
Projection TV sets have several common problems listed below.
Problem #1) Convergence
Symptoms:
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted
  • No Audio/Video - makes a chirping sound.
Example Photo:
Problem #2 CRT Fluid has clouded over.
Symptoms
  • Dull Video, Washed out
  • White/Bright looking video
  • Halos around objects
  • Red/Orange looking
Example Photo:
You can see more examples and find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Dec 08, 2008 | Samsung HCM4215W 42" Rear Projection...
JVC HDTV Pictrure Distortion
Your TV needs to be calibrated. Rear projection TVs are very sensitive to movement. They have 3 color canons that need to be precisely aligned so that the colors overlay each other. They are like three projectors all aimed at the same screen.
If you were to enter the User Menu on the TV, you should find an alignment/calibration choice that will re-align the colors using some on-screen help.
If you are not able to resolve the situation on your own, a certified ISF Calibrationist should be called.
And, since you've bought this TV used, it should be cleaned by a professional (the canons, lenses, etc.)
Apr 07, 2008 | JVC PD-42WX84 42 in. HD-Ready Plasma...
Samsung HC-P4752W 47" Rear Projection HDTV-Ready Television Logo
114 people viewed this question
Demonic-2011
Demonic-2011
Steve Allison
Steve Allison
