Question about Kenmore Oasis HE 27082 Top Load Washer
Kenmore washer My washer seems to be working fine... When I start it (on any cycle) it begins fine, then the termperature control starts lighting up, switching up and down all temp settings and beeping about once a minute. It seems to be washing my clothes... but the beeping is annoying. I'm discouraged about this very expensive washer. I had the repairman out 2x during the warranty year.
  • Anonymous Mar 30, 2009
    WOW! I too am having the same problem. It just started this last weekend. The washer is just 1 year and 4 months old. Sometimes it works fine and then others it beeps and changes times up and down.
    I did just buy the one year warranty through sears. It was $139. for 1 year.
    It is a huge waste of money.
    If you have figured out an easy fix let me know.
  • TonyK2 Apr 03, 2009
    The same. Problem started when Sears replaced the control board due to a recall. I guess I'll have to call them back.
  • 3 Answers
Yes, changing out the control board will probably fix your problem. Trouble is the board plus shipping costs $180. The best solution: sign up for a one year warranty called "service smart" for $215, then call for service. It covers trip costs and parts and labor. I changed out my board by myself and now I have a leak problem that I cannot locate. They will be out here next Monday.
If only I knew, I'd only be out $215 instead of $215+$180. The number for the protection agreement is 1-800-827-6655 (US), 1-800-361-6665 (Can)*. They wanted to sell me coverage for my fridge too but why should I buy it until something happens to it?
(*I do not work for Sears or their affiliates...)
Posted on Mar 14, 2009
  • 5,911 Answers
This is a known problem with the Oasis. It is caused by a bad relay on the Interface Control Board inside the console. Unfortunately, the "cure" for the problem is the replace the board and/or the wire harness that connects the console to the Main Control Board underneath the console. If you attempt to defeat the sound on the circuit card you could potentially damage it to the point where it doesn't work at all. The circuit board usually runs about $120. The only inexpensive alternative is to leave the room and shut the door behind you. That way you won't have to deal with the annoying beeping.
Posted on Aug 21, 2007
  • Jeff Rockwell
    Jeff Rockwell Aug 23, 2007
    I work on these appliances and have replaced several interface control boards this year alone for the very same problem. Do you have a better solution? It would be nice to receive feedback in order to give better advice.
SOURCE:
I have a kenmore washer model#110.29832800 that will not start.if i put it in the spin cycle it turns on but will not start at the beginning of any cycle.it was working fine yeaterday.
then perhaps the timer contacts are burnt .sometimes they can be cleaned and last awhile but usually will need replacement of the timer soon
Jan 02, 2016 | Kenmore Washing Machines
Kenmore HE2 Won't Turn On
1) test the power cord for open 2) test the outlet box, see for blown fuse or c.breaker put some desk lamp and see if work 3) test inside of the control board if there fuse blown or c.breaker tripped 4( test the lid switch is closed, can be faulty or open replace 5) test the input voltage 115 if there are the control board faulty.
Jul 18, 2012 | Kenmore HE2 Plus Front Load Washer
Kenmore elite HE31 front loader will not start but has power
This seems to be a problem in the start switch diode. If all works fine, but will not push and start and all cycles seem to work when working it manually, this is in the switch timer electronic diode is not working properly. Sometimes a code will not come up, because cycles are still working when manually changing wash cycles. There is seperate switch or electronic trigger that starts the machine, and has probably worn out or not making good contact. If you can unplug machine and then take off panel, trying spraying behind start switch with electronic cleaner to free up any possible dust or dirt. Might get lucky.
Apr 07, 2012 | Kenmore Elite HE5t Washer
Kenmore Elite Washer wont start
Plug off the wall socket. Remove, reseat and reconnect every connector at least 3 times. Remove the motor control board, spray it down with electronic cleaner along with all connections by disconnecting them, spraying them down. Disconnect and connect a few times to ensure good contact.. This normally works.
Pl give me a ‘very helpful’ rating for the free help, thanks.
Jun 17, 2010 | Kenmore Elite 45986 Front Load Washer
Kenmore quietguard standard wont start.
is there any function at all? if not, check thermal fuse located inside near control panel, check www.searspartsdirect.com and enter your model # to show how to take it apart. If it has functional display lights, replace main control board after ohm test on wash motor and fill valve.
Jun 25, 2009 | Dishwashers
Lights on Washer Machine flash but Washer doesn't work
Hard Reset - In some cases the control can be non-functioning or may not accept activation from the control panel. To clear and restart the control follow the these steps:
* Unplug or turn the circuit breaker off for 30 seconds.
* Reconnect the unit to the power source by turning the breaker back on or plugging the unit back into the wall outlet.
* Press the Pause/Cancel/Stop button twice to clear the "PF" in the display.
* Start a short cycle to check the operation of the machine by selecting a cycle and pressing and holding the start button until the machine starts.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Mar 31, 2009 | Kenmore Washing Machines
Agitator
try putting a new coupler in it
Mar 19, 2008 | Kenmore 20722
Random electrical problems, sometimes it works beautifully, sometimes not!
F11 = Communication between the Central Control Unit (CCU) and the
Motor Control Unit (MCU) cannot be sent correctly.
1. Unplug washer or disconnect power.
2. Check wire harness connections to the MCU, the motor, and
Central Control Unit (CCU).
3. Check the drive system for any worn or failed components.
4. Plug in washer or reconnect power.
5. Verify CCU operation by running a Diagnostic test or any
cycle.
6. Check the MCU by looking for operations of the drive motor.
7. Check the drive motor for powered rotations.
8. Check that the serial harness at the MCU is not mounted
upside down. The wires should be to the left when facing the
MCU connectors.
FDL=
A Door Lock Error occurs if the door cannot be locked. It will try to lock
it six times before displaying the error code.
Le code d’erreur “Verrouillage porte” apparaît s’il n’est pas possible de verrouiller la
porte. Le système effectue six tentatives de verrouillage avant d’afficher le code d’erreur.
■ Door lock mechanism is broken or removed from door.
■ Door switch/lock unit failure.
2. Check door switch/lock unit.
3. Check the wire harness connections to the door
switch/lock unit and Central Control Unit (CCU).
Feb 12, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore Quiet Guard 2 keypad
Sounds like the electronic controls (smart card) are acting up. Try shutting off the power at your fuse box or shut off the circuit breaker for 1 minute them turn the power on again. This fix quite often works on electronic appliances.
Apr 08, 2007 | Kenmore 17342 / 17349 Built-in Dishwasher
Kenmore Oasis HE 27082 Top Load Washer Logo
99 people viewed this question
Sal De
fordexpert
yobo007
yobo007
