Question about RCA BD20TF10 20 in. TV/DVD Combo
No Disc Error
Tried many different dvds and cds television attempts to read but sends error "no disc inserted" Tried cleaning the tray area to remove dust but unless the unit is reading it will not work, any suggestions would be appreciated
  • 2 more comments
  • snipinu Nov 02, 2007
    disc will not read dvd cleaner will not work
  • oblio Nov 12, 2007
    Get message that "no disc is inserted". Happens also when I try to run a disc cleaner. The discs go in, but I get the same message.
  • JRomulus Dec 09, 2007
    I've had the same issue, "no disc" detected. If I eject and reload the disc about 12 times, sometimes it will then read. Some other times if I pull the plug, wait 10 seconds and plug it back in it will read.
    Sounds like it might be a dirt or contamination issue. It is an annoying problem.
  • Anonymous Dec 11, 2007
    When I insert the Dvd disc in it just makes a humming sound and tells me no disc has been inserted. I have tried cleaning it, but no luck. When I first started using the dvd player all I had to do was put in the dvd and hit play I never had to do anything else.
Take a swiffer duster, and shove it in the unit. Then pull it back out. Thats exactly what I did to mine, and it started to work again. Not even kidding.
Posted on Nov 11, 2007
Go to the shop end dvdclener rezolv your problem
Posted on Aug 21, 2007
It says unable to read disc when i put the game in.
Please Rate me!
What Is It? The Disc Read error is a simple one. It simply means that the Xbox is unable to read the disc that you have placed in the drive. In the majority of instances, this error has nothing to do with the functionality of the console, but, rather, hinges on the actual disc that has been inserted into the DVD tray.
Disc-Related Errors The most common reason for Disc Read errors are related to the disc itself. Numerous conditions can keep the laser from reading the information contained within the game, DVD or CD in the DVD drive.
  • The disc is scratched - Game discs, audio CDs and DVDs can become scratched very easily. Usually this is because they have not been kept in their cases, but left in the open. Simply resting two discs atop one another can scratch the bottom disc. If discs are sufficiently scratched, the data contained on them will be inaccessible to the drive.
  • The disc is dirty/dusty - Dirt and dust can build up on the faces of discs left exposed. When sufficient dirt or dust has built up, it can block the laser beam used to read the disc, resulting in a Disc Read error.
  • The disc is the incorrect region - DVDs come in formats called "regions." These regions match the region specified in the software of the DVD player. Some games also have these regions. If the region of the DVD and that of the player do not match, the disc will not play.
Can I Fix These Errors? Repairing disc-related issues may or may not be possible. If the cause is simply dirt and dust, you can certainly repair the disc. However, if the cause is due to extreme scratching, then replacing the disc is likely your only choice. If the disc is from the incorrect region or from another country, you will have to obtain the correct region. Returning the disc to the retailer for exchange may work.
Non-Disc Related Errors As mentioned, there can be some Disc Read errors that have nothing to do with the disc at all. In this case, it's time to troubleshoot the Xbox.
  • First, simply try to reboot the machine. Often, this will flush the cache or other error and allow the game to operate or the disc to play.
  • Second, try removing the hard drive and/or memory units. Once removed, reboot the console and attempt to load the disc with the hard drive and memory out of the unit. If this works, you can simply shutdown and reinstall the hard drive.
  • Attempt to play the disc in another type of player. For instance, attempt to play the DVD in another DVD player or the CD in a CD player. If the disc plays in these players, you may need to clean the Xbox DVD player.
  • Check to make sure that all air vents are open and are able to provide sufficient airflow. Overheating can cause Disc Read errors, as well. In addition, ensure that the power supply is unobstructed and uncovered. Much like the Xbox 360, the power supply can become quite hot and can cause errors if unventilated.
  • Check for disc tray errors. Depress the eject button and watch the tray extend. If the tray partially extends and then retracts immediately, you may have a problem with the DVD drive. If your Xbox is under warranty, this can be replaced at no charge. However, if you are out of warranty, you can install a new DVD drive on your own.
  • As a note, make sure that the new DVD drive comes with the same firmware as your original console, or you may experience additional error codes after the installation of the new DVD drive.
May 09, 2011 | Video Game Consoles & Games
Kenwood kvt-911dvd disc error for dvd play?
you just bought it? take it back it may be a rare case of Dead on arrival.
Jun 10, 2008 | Car Audio & Video
Error 12 and error 17 only for dvds
iiMesisage Cause Action
ERROR-11, 12, 17, 30
Dirty disc Clean disc.
ERROR-11, 12, 17, 30 Scratched disc Replace disc.
ERROR-10, 11, 12, 15, 17,
30, A0
Electrical or mechanical Turn the ignition ON and OFF, or switch
to a different source, then back to the CD
i hope this answers and solves your problems.
Feb 19, 2010 | Pioneer AVIC-D1 Car Video Player
All my discs dont work.
Does the screen eventually read "Open Tray"?
This is a very common error, you need a DVD drive replacement. Only an experienced person can do this, if you don't do it correctly you won't be able to play games again. If you'd like I can do the repair for you, contact me at jordan@jordanselectronics.com
Jan 02, 2010 | Microsoft Xbox 360 Console
WRONG DISC ERROR WHEN PLAYING A DVD
HI,. this is a lens assembly fault. the lens is malfunctioning or, it may have stopped reading. this wrong disc code is just a universal warning that is concerning a fault if the main board doesn't receive any data(audio,video) when the disc is inserted.
Due to the integrated status of your unit, this will be a costly repair because, the entire assembly is combined together with the vcr section as well.
You will need to replace the entire assembly to fix this issue. the lens has burned out.
you can confirm my diagnosis by preforming a cleaning of the lens with a cleaning disc. if the unit continues to not read or play a CD after the cleaning, this will confirm my diagnosis.
Please rate and have a great day:)
May 23, 2009 | Bush DVD142RC 14 in. TV/DVD Combo
Will not read DVD discs.
It looks like you have a lens problem, DVD and CD use a different error correction and different track format.
A dirty lens can read CD but not DVD.
Tru first using a lens cleaner like this ones:
If it does not work you can try cleaning the lens directly with cotton and isopropyl alcohol, you will need to undo the screws at the button and to take apart the cover. Unplug power when doinfg this.
If it still does not work, since you aready reinstalled the firmware, the lens may be faulty.
You can order the lens pickup from factory and replace it.
Sep 02, 2008 | LG Computers & Internet
DVD stopped playing all DVDs
Reset you player by doing the following:
With the player on, hooked properly to your television, and on the correct station:
Open the tray
Close the tray (with no DVD inserted)
Hold the stop button down for a full 5 seconds
The CyberHome screen should appear. You should be able to play your dvd's now.
Feb 20, 2008 | Cyberhome CH-DVD 300 DVD Player
Alpine cda7998 disc error
Try cleaning the lens first, if you can take the top off and are able to see the lens, using a cotton swab soaked in 91% alcohol wet the lens, don't rub it, then blow it off with computer duster. Or try a cd based lens cleaner (Radio Shack).
Good Luck Leadispenser
Feb 18, 2008 | Alpine CDA-7998 CD Player
ERROR, NO DISK
No if the cleaning does not work, you will need to have the unit hooked up to test equipment to check if the laser is bad. It could also be a bad spindle motor if the unit will not spin. good Luck
Mar 14, 2007 | RCA RS2600 CD Shelf System
RCA BD20TF10 20 in. TV/DVD Combo Logo
142 people viewed this question
Top RCA Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
