Question about Hoover H120M Front Load Washer / Dryer
Hoover wdm120 door wont open
    Novelist:
    Champion:
  • 244 Answers
More than likely that yor pump hasnt let all the water out try getting your outlet hose from under the sink and place into a bucket low to the ground if water comes out than your door will open after a short while if water does come out than make sure your pump or drain hose is not slightly blocked if not then your pump is on its way out also if water doesnt come out of drain hose than take it off at the pump if it comes out then,then your hose is blocked m8
Posted on Aug 22, 2007
SOURCE:
Hoover nextra washing machine door wont lock / cycle start
sounds like the door lock mechanism. if this cannot signal it has engaged, to the board, no other function will work (you don't want the washer going with the door open, trust me :) )
Nov 08, 2013 | Hoover Nextra 160 HNWF 3137 Front Load...
Hoover WDM120 scraping noise heard when drum spinning with a load in washing machine.
have come across this prob before the noise you describe sounds like an underwire from a bra or the condencer on the back of the mach some had a baffle plate fitted just where it goes onto the backof your mach on some this came loose and caused it to scrape of the back of the drum hope this helps .
Jun 07, 2011 | Hoover H120M Front Load Washer / Dryer
After a power cut my washer wont work the door security light just keeps flashing! Model Hoover Vision HD
Ihave a Hoover Vision HD washing machine and the "Door Security" light keeps flashing. I have looked in the manual and it says the door is not properly shut. However the door is correctly shut and as a result the machine will not operate . The door will open or close but will not start a cycle to wash. Any suggestions please????
Apr 24, 2011 | Hoover Washing Machines
Hoover 1300 washing machine door wont open
Hi.
The door will not normally open if there is water left in the m.c. check pump, and make sure the belt is o/k, as some hoovers do not let you open the door if the belt has come off. Please leave feedback.
Thanks.
Nov 25, 2008 | Hoover Washing Machines
Programmes
Dear Flying fish,
happy to help,
Here is a location for this hard to find washer manual!
http://www.4domex.co.uk/cgi-bin/product.pl?PID=1081943
Please leave a solved rating before you leave the site,
Sep 28, 2008 | Hoover H120M Front Load Washer / Dryer
Hoover Washing Machine Door wont open. Please help the door opener feels slack! How do I get it to open. Its a hoover nextra. Thanks Lisa
Either clip on the door is faulty or its the door interlock in which the door locks into easily replaced by undoing the clip pullling back the door rubber and replacing ..
Aug 05, 2008 | Hoover Washing Machines
Hoover WDM120
this will be your carbon brushes which are situated at your motor in a plastic cover with a wire is attached if these are low then it will not spin must be at least 8ml long for it to work they start off about an 1inch in length
Nov 14, 2006 | Hoover H120M Front Load Washer / Dryer
Hoover H120M Front Load Washer / Dryer Logo
191 people viewed this question
Top Hoover Washing Machines Experts
Gerry Harvey
Gerry Harvey
Poppa Maddo
Poppa Maddo
jimorris77
Are you a Hoover Washing Machine Expert? Answer questions, earn points and help others
