Question about Dell SD-616 Internal DVD Drive
My drive doesn't work sometimes
Hey all. I have a problem with my Dell SD-616 DVD drive. Whenever i put in certain disks it just doesn't run them. I know i have the right drive and whenever i listen to the drive, it doesn't make that kind of startup humming sound. I tried taking it out to see if there was any dust but i couldnt find anything then i tried updating my windows and rolling back my drive but it still doesn't work. Can someone help me please? Remember that this only happens to certain cd's or dvd's and i know i have the right specifications. Thanks in advance
    Problem Solver:
  • 6 Answers
Re: My drive doesn't work sometimes
You may try to reflash the firmware of the drive, which you find on the web site of the producer, but i would suggest there is the logical hardware problem with the drive. You didnt mention if it ever worked for you or not, why dont you just use the waranty and change the drive for the new one? Robert
Posted on Aug 23, 2007
0 characters
3 Points
What do you do to get cd out
If it doesn't eject out automatically when pressing the eject button, take a paper clip and straighten it, or you can use a long needle, now look at the portion just beside/below/above the eject button, you'll see a tiny hole, push in the needle or the straightened paper clip, press the eject while you push in the pin, you'll need to push a little harder, it'll automatically eject out.
If you need further help, let me know.
Good luck.
Thanks for using FixYa.
Oct 08, 2010 | Dell SD-616 Internal DVD Drive
My Compaq SD-616T/CPR with FirmWare F304 will read CD's but will not read DVD+R. Any Idea of why or what I might do to correct?
update the codec driver. you can use km player as an alternative if u dont have a disk for your system's dvd player come with a codec
Dec 27, 2009 | Dell SD-616 Internal DVD Drive
My pc detects the drive but it does not recognise when I put a disk it
your drive is ok but dives lence is problem cleane the lence then check
Oct 03, 2009 | Dell SD-616 Internal DVD Drive
Upgrade PC DVD player to read all DVD's?
Without knowing your make/model of camcorder I'm just giving you some basic things to check. Q,E,F,T,B MODEL?? Go to the Samsung/us/support website, enter your exact model number(i.e. sd-616Q or whatever). When you choose your model, a selection of manuals will appear. Look nearer to the top of the page--there will be some firmware updates. Check the date/version listed on your unit. if it's older than that given on the site, upgrade.
Sep 15, 2009 | Samsung SD-616 16X DVD ROM FOR DESKTOPS...
I need a driver for my dvd-rom/cd-burner. my computer says the driver is corrupt.
Dell has the dvd driver for your system under the support area of their website. Hope this helps & please remember to rate my answer. Thanks.
Jan 02, 2009 | Dell SD-616 Internal DVD Drive
Soundcard driver for samsung mv30
check this link and download the drivers
Dec 15, 2008 | Samsung SD-616 16X DVD ROM FOR DESKTOPS...
A problem with my DVD Rom
ther is no driver for n dvd rom as such................
u jus have to unplug n replug the cables n try........
second-- check in device manager if it has been disabled or not.........
device manager---rite click on my comp>>>properties>>>>hardware tab>>device manager>>> check for cd rom if it has a yellow question mark... if so rite click n enable..............
third -- format n reinstall os(xp,win98,vista).....
80% time this wrks... try!!!!!!!
ny more q; mail me
Aug 19, 2008 | Dell SD-616 Internal DVD Drive
Age of mythology
Is there a problem with the installation or is it saying you need the disk in to play the game?
If it's saying you need the first disk in the drive to play the game then download the following NO CD PATCH.
Jan 19, 2008 | Dell SD-616 Internal DVD Drive
DVD combo drive not working
Did you set your jumpers correctly? How about using a different power Cable? Different Data Cable? If all fails try diagnosing the problem. DOWNLOAD HIREN BOOT CD, WRITE THE ISO TO CD THEN BOOT FROM IT Includes HDD Diagnostics for these companies Hard Disk Tools: - Hard Disk Diagnostic Utilities - Seagate Seatools Desktop Edition 3.02 - Western Digital Data Lifeguard Tools - Western Digital Diagnostics (DLGDIAG) 5.04f - Maxtor PowerMax 4.23 - Maxtor amset utility 4.0 - Maxtor(or any Hdd) Low Level Formatter 1.1 - Fujitsu HDD Diagnostic Tool 6.61 - Fujitsu IDE Low Level Format 1.0 - Samsung HDD Utility(HUTIL) 2.02 - Samsung Disk Diagnose (SHDIAG) 1.28 - IBM/Hitachi Drive Fitness Test 4.08 - IBM/Hitachi Feature Tool 2.03 - Gateway GwScan 3.15 - ExcelStor's ESTest 3.80 - MHDD 4.6 - WDClear 1.30 - Toshiba Hard Disk Diagnostic 2.00b - SeaTools for Dos 1.08 - HDD Regenerator 1.51 - to recover a bad hard drive - Ontrack Disk Manager 9.57 - Disk Test/Format/Maintenance tool. - Norton Disk Doctor 2002 - a tool to repair a damaged disk, or to diagnose your hard drive. - Norton Disk Editor 2002 - a powerful disk editing, manual data recovery tool. - Active Kill Disk 3.1 - Securely overwrites and destroys all data on physical drive. - HDAT2 4.5.2 - main function is testing and repair (regenerates) bad sectors for devices - SmartUDM 2.00 - Hard Disk Drive S.M.A.R.T. Viewer. - Victoria 3.33 - a freeware program for low-level HDD diagnostics Hope this helps
Sep 22, 2007 | Samsung SD 616E (729507925578) Internal...
Unable to read some of the DVDs......
It's possible that the drive has died. CD and DVD drives are notorious for short lives but then I've seen some last 5 years. The lens could be dirty, just a small piece of lint is enough to cause hassles. Try using a Lens cleaner, available from all good audio shops. Some machines don't like +R disks and a firmware upgrade is needed. I've done many Liteon Drives with terrific results but if the manufacturer hasn't put one out then you're lost. It's possible you've used the wrong upgrade to fix your problem. With the prices of drives today it's sometimes cheaper to replace it. Believe me they can die quickly, my record is a week from brand new to unuseable and that was a Sony. BMW
Jun 03, 2006 | Samsung SD 616E (729507925578) Internal...
Dell SD-616 Internal DVD Drive Logo
154 people viewed this question
Top Dell DVD/Blu-ray Drives Experts
Brian Sullivan
Brian Sullivan
NewYork kyocera HP...
Are you a Dell DVD/Blu-ray Drive Expert? Answer questions, earn points and help others
