Question about Brother HL-2040 Laser Printer
Paper JAm I have a Brother 2030 laser printer. It has a paper jam and I seriously need help - any ideas? The paper jam is at the bottom of the printer instead of the top!
There are three places to clear the jam: 1. Paper tray (remove it and feel inside, clear paper. 2.Open the front (above the manual feed slot) inside is the drum - remove that and the toner cartridge, if necessary. 3. On the back - open the rear chute. You should be able to remove the paper in one of those areas. See the Brother web site for complete pictures ans instructions. http://welcome.solutions.brother.com/BSC/public/us/us/en/faq/faq/000000/000000/000026/faq000026_006.html?reg=us&c=us&lang=en&prod=hl2040_all&Cat=4
Posted on Aug 28, 2007
SOURCE:
Why won't it print?
Brother HL 2040 Laser Printer Repair solution - YouTube
? 2:25
www.youtube.com/watch?v=t4GGvm3aW7c
Oct 25, 2012 - Uploaded by nobblynoel Brother HL 2040 Printer Repair solution for multiple page jams For more Info ... My Brother HL2030 laser printer is making a groaning/grinding noise on ..... FIX YOUR PRINTER: ERROR: Printer Does not Grab Paper fromTray ...
Aug 07, 2015 | Brother HL-2030 Laser Printer
My brother printer HL-2035 keeps jamming the paper. I have changed the drum and toner and the drum light is still on when it prints. Can you help please?
I think you need to reset the consumables counter to clear the drum warning light as the printer can't automatically recognise new parts. If you've bought a genuine Brother drum unit there will be detailed instructions inside the box as to how you reset it which usually involves holding down the only button whilst switching the machine on. As for the paper jams, it could be something as simple as loading less paper and fanning it to get some air between the sheets before sliding it into the tray or it could be that you need to buy a new paper feed kit which is fairly cheap and easy to install.
Oct 07, 2010 | Brother HL-2030 Laser Printer
Toner cartridge wiil not come out? paper is jammed brother 2030
You need to open the front door and grab the toner/drum unit and pull as hard as you need to. once the assy. comes out you press the blue button on the left side and the toner cartridge will separate from the drum unit. install the new toner or remove the paper jam as required. call if you need more info. 805-520-3003 steven
Feb 13, 2010 | Brother HL-2030 Laser Printer
My Brother hl 2030 has a permanent paper led light flashing altho there is no paper jam and all covers are secure
Remove the paper tray. Lift the printer and you have to see paper feed roller it is rubber, just clean of dirt with cloth and alcohol or water.
Feb 09, 2010 | Brother HL-2030 Laser Printer
My Brother HL-2030 won't work; All LED lights are flashing
Use the software to diagnose the problem or check for a paper jam and ensure the drum and toner is OK.
Dec 11, 2009 | Brother HL-2030 Laser Printer
Paper light even after doing everything...
http://www.devicemanuals.com/guide/Printers/Brother/Brother-HL-2030-Laser-Printer-User-Manual-T0RFME56VT.html
This is the link to download the Owner Manual and User Guide, but if you don't need it, then here's the link direct to their email contact page. You can enter what's wrong and they should get back to you soon.
http://www.brother.ca/en/customer_care/online_support.asp
Hope this helps
Jul 21, 2009 | Office Equipment & Supplies
Paper feeding problem
3 possibilites.
1.. the paper pick up rollers are jammed
2. you have a small piece of paper stuck inside
3. pickup roller gearsor solenoid are damaged
Apr 17, 2009 | Brother HL 5250DN Laser Printer
Brother hl 2030
Hi here is a link to the brother site with a breakdown of the led status lights.
http://welcome.solutions.brother.com/BSC/public/eu/gb/en/faq/faq/000000/000100/000070/faq000170_005.html?reg=eu&c=gb&lang=en&prod=hl2030_all&Cat=6
There are quite a few reasons as to why the paper light is coming on.
the obvious ones are a paper jam, low paper or no paper or its expecting paper to be put into the manual feed on the front of the printer.
but there are a few less than obvious reasons as well according to brothers site.
hope this helps.
Jul 03, 2008 | Brother HL-2030 Laser Printer
Brother HL-2030 paper jam solution with service manual
actually the company is charging some dollars for the manual.i will find any free manual site as soon as possibe and send it to u.bye
Jun 12, 2008 | Brother HL-2030 Laser Printer
Paper jam with Brother HL-2030 laser printer
Being a retired electronics technician, I located and downloaded a copy of the service manual. Then proceeded to hunt for the reason why the Paper LED was staying on. I put the printer into the Production diagnoses mode, then by process of alimination opened and closed each panel and cheack each sensor switch one at a time. At which time it was apparent the problem was the rear door sensor. So I started to disassemble the printer getting instructions from the Service manaul, as most electronic equipement there is a sequence process to accompliah this. and once I found that the method of the rear door sensor operated I found the bracket was not in the right position. I put the sensor bar back into it's proper position and put the printer back to normal opperateing mode, I found my problem was solved. So I reassembled the unit and plugged it back into the compter ran a couple of test sheets and cleaned and aligned the printer head(s) made a few adjustment and everything was back to normal.
I must say that locating the Service Manual was a feat, but worth every cent I paid for it which was $9 USD. Personally i think all service manuals should be available for all Brother products for a fee, then a large number of problems can be fixed by the owners without much bother to Brother.
I ahve two of these printers and would still purchase a Brother colour printers, my next purchase is going to be a Brother color laser printer. Out of all the printers i've used on my computers I like the brother the best.
Mar 19, 2008 | Brother HL-2030 Laser Printer
Brother HL-2040 Laser Printer Logo
351 people viewed this question
James Cagle
James Cagle
Jim Keysor
ctnozil
