Question about Jenn-Air JJW8530C Expressions Collection Dual Single Oven
Jenn air oven
This model has the "touch" controls.it seems i cant bake because oven is "off"
  • Anonymous Nov 22, 2007
    Oven turned off by itself while
I had the same problem. I went to the manual and it is very easy to fix. The oven control lockout was somehow set. To cnacel it just press the Cook Time and the Stop Time buttons at the same time for 4 seconds. The "off' will appear briefly and then disappear. It worked for me. Good Luck!
Posted on Aug 23, 2007
SOURCE:
F7 code flashes on jenn aire 27 inch wall oven
The F7 code indicates that the touch pad either has a "stuck" or shorted key. Depending on the oven model, you either need to replace the touch pad or the controller (clock) and the touch pad. (Some Jenn Air appliances sell the two as one unit.)
Please add a comment with your model number to get additional information on the availability and price for the parts. (Parts may be available from a number of suppliers, including jenn-air.partselect.com.)
I hope this helps.
Mar 01, 2012 | Jenn-Air 27 in. Electric Single Wall Oven...
Jenn Air W30400 wall oven does not heat.
Turn off the power to the oven.
Remove the racks.
Remove the BAKE element screws and carefully pull the element out.
Remove the wires from the element,being careful not to let the wires fall back into the oven cavity.
Use a volt meter set for continuity and touch the meter leads to the element terminals.
No reading is a bad element.
Replace the element.
If you do get a reading,the electronic control is bad.
Jul 16, 2010 | Jenn-Air Ovens
JennAir F8
Check out www.appliancetimers.com They can rebuild your clock for around $100. A new Jenn-Air is like 2 grand.
May 21, 2010 | Jenn-Air JJW8530C Expressions Collection...
Jenn air touch panel on oven beeping and flashing
throw the jenn-air out.
purchase something from another company that cares about their products.
I have had the same issue, twice. my wife managed to melt the touch pad by baking and using the burner at the same time. this has happened to countless purchasers of jenn-air **** appliances. they should be sued and forced to fix their faulty design
Aug 29, 2009 | Jenn-Air 27 in. Electric Single Wall Oven...
Oven touch pad not working properly.
Hi. this will only get worse. i would replace this defective touch pad asap if possible.
Jun 23, 2009 | Jenn-Air 27 in. Electric Single Wall Oven...
F0 fault code
Hi ,
F0 is Function key faulty.
Replace touch pad or clock assembly (also called the ERC)
You can find parts online at partselect.com , or appliancespartspro .
May 29, 2009 | Jenn-Air Ovens
Two of the oven controls do on function on SVE47500W
We own a Jenn-Aire model W27400W oven. The display module has gradually gone dim over a period of several months prior to the end of the warranty, and the display is no longer visible. It is apparent that several Jenn-Aire oven models use the same display. Does Anyone else have the same problem, and If so, are they willing to join a class-action suit against Jenn-Aire with us?
Steve Patterson
303-256-8494
[email protected]
Nov 24, 2008 | Ovens
Jenn-Air coolimg fan problem
Good Morning!
What youre experiencing could be a result of a faulty oven temperature sensor, a faulty oven control board or relay board. Youre more than welcome to send both the main control board and relay board for evaluation. Fixyourboard will test and repair both as needed for less expensive than buying new, and include a two year warranty.
5700M662 60 Jenn Air OVEN CONTROL BOARD
May 15, 2017 | Jenn-Air JJW8230D Electric Double Oven
Jenn-air expressions 27" convection wall oven model wm27460 won't heat
reset your breaker reprogram the clock try again what happend last time it was working self clean broiling etc
Dec 27, 2007 | Jenn-Air JJW8530C Expressions Collection...
Jenn-Air w156 Single Wall Oven Problem
Most likely its the EOC (electronic oven control), it needs to be replaced. If you self cleaned the oven a lot the very high heat generated fatigues computers in modern ovens.
Sep 28, 2007 | Jenn-Air JJW7530DDS Electric Single Oven
Jenn-Air JJW8530C Expressions Collection Dual Single Oven Logo
158 people viewed this question
Top Jenn-Air Ovens Experts
Nathan Van Boven
Nathan Van Boven
Jeffrey Turcotte
Jeffrey Turcotte
Are you a Jenn-Air Oven Expert? Answer questions, earn points and help others
